Page 2705 of 2776 FirstFirst ... 170522052605265526952703270427052706270727152755 ... LastLast
Results 40,561 to 40,575 of 41631
  1. #40561
    Surely this is the go....high power , low emissions , no expansion chambers....dyno proven...
    And here it is: https://www.youtube.com/watch?v=5czHDU6pK8E
    Lots of other 2 stroke stuff on youtube under "driving4answers" 2 strokes
  2. #40562
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    As I posted earlier, most of the problems with two strokes were solved a long time ago. The Junkers opposed piston aircraft two strokes were reasonably successful both with their weight and especially with their fuel economy. If you replace the blower with a modern electric turbocharger you get even better power, weight, and economy.
    Lohring Miller
  3. #40563
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Inertial Dyno Woes
    A friend built an inertial dyno based on our very successful small engine dyno. Though we had maybe thousands of trouble free runs, he has had issues. Pictures of both dynos are below. Ours is on the bench with the shield.
    His problems have been:
    Constant failures of the square key connecting the engine to the dyno
    Failures of the round shaft he replaced the square shaft with
    Slip of the shaft Locktited into the flywheel
    The only difference between his dyno and ours is the position of the clutch and the Lovejoy coupling. We have the coupling before the clutch and he has the clutch before the coupling. My thought is that the clutch is a solid connection and in our design the coupling insulates the engine's torque fluctuations from the flywheel's constant inertia better. We never did more than twist the square key. Others with dynos we copied never had any of these problems either.
    What are your thoughts?
    Lohring Miller
ID:	356303Click image for larger version.
  4. #40564
    The only suggestion I have is it seems the failures are all related to torsional harmonic twisting between the crank and the inertial mass.
    Those Lovejoy type slotted couplings with varying grades of what is probably urethane pads on the force faces , have to be very hard, or they distort and fail.
    Lovejoy also make what are called donut couplings as are used in racecar rear axle assemblies like Formula Ford etc - but I doubt they have something small enough.
    Maybe suppliers of mechatronic components for robots etc have a small donut drive coupling , that not only can take axial misalignment, but the rubber coupling itself dampens
    torsional harmonics really well.
    The other way of doing this is the camshaft drive torsional damper that was invented at Cosworth for the DFV - this has a set of small radial leaf springs that bend back and forth
    to insulate the cam drive from crank harmonics.
  5. #40565
    as seen on the
    Mark IV cortina propshaft up to and likely beyond the seira
    Cosworth also used a quill drive on both he v8 and the Norton twin
    https://www.f1technical.net/forum/viewtopic.php?t=26642
    I think some even used a hollow shaft as Torsion bar
    Triumph BSA used one on the points drive on the F750 tripple as the crankshaft tended to whip up and down.
  6. #40566
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    as seen on the
    Also used for Hillman Imp gearbox to driveshaft joints. AKA Rotoflex coupling
    (PostalDave on ADVrider)
  7. #40567
    Many of these get posted in the Oddballs and Prototypes thread.
    And it looks like our favorite 2 stroke Stuffer has some thoughts about the "Prior Art"!
  8. #40568
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Re the dynos; It was pointed out to me that our dyno had a very much thicker motor mount. I think it's possible that the engine is moving a lot more with the thin mount and that's what is causing the problem.
    Lohring Miller
  9. #40569
Name:	Happy 85th Birthday Jan Thiel.jpg
  10. #40570
    26th April 2013 - 21:55
    BMW R1200R 2009
    Gelukkige verjaardag, Jan !
    Happy birthday
  11. #40571
    17th April 2022 - 13:57
    81' suzuki TS125 , 79'GP100 ,86'Yamy RXZ
    Malaysia
    Oh how fast time goes by,and already another Happy birthday to our Mr.Jan. Wishing you good health through the year Jan
    Sent from my RMX1911 using Tapatalk
  12. #40572
Name:	Suzuki GP110 (1).jpg
ID:	356342Click image for larger version.
Name:	Suzuki GP110 (2).jpg
ID:	356343Click image for larger version.
Name:	Suzuki GP110 (3).jpg
ID:	356344Click image for larger version.
Name:	Suzuki GP110 (4).jpg
ID:	356345Click image for larger version.
Name:	Suzuki GP110 (5).jpg
    Unusual damage to the thrust side of one of the NF4 Honda RS125 pistons that we use in our Suzuki GP110's.
    I think it might be that the squish was too tight (< 0,6mm) and the piston was hitting the head while the crank was still trying to go up. There by applying severe leveraging pressure on the piston skirt.
    Would be happy to hear other ideas.
  13. #40573
Name:	Suzuki GP110.jpg
    Could the tongue on the NSR250 cylinder have caused this, as the piston is rocking over from bottom dead center? Has this been a problem with Honda RS125's? Ideas?
  14. #40574
    That piston markup on the dome is all the way round, the width of the squish , so that isnt deto, its been smacking the head big time.
    I would say that the crank is flexing - is it a hollow pin or solid - Jan has said that the Aprilia would not hit the head at 14,000 with 0.4 squish.
    And no, Honda have used the tongue idea for ever with no issues - and that hole in the piston skirt starts well above the tongue at BDC.
    At 0.6 squish depth, and that very wide squish width, what is the MSV in EngMod.
  15. #40575
    I would say that the crank is flexing - is it a hollow pin or solid - Jan has said that the Aprilia would not hit the head at 14,000 with 0.4 squish. And no, Honda have used the tongue idea for ever with no issues - and that hole in the piston skirt starts well above the tongue at BDC. At 0.6 squish depth, and that very wide squish width, what is the MSV in EngMod.
    Hollow Pin and 37.5 MSV
Name:	Screenshot (2451).jpg
