Page 2711 of 2776 FirstFirst ... 171122112611266127012709271027112712271327212761 ... LastLast
Results 40,651 to 40,665 of 41626
  1. #40651
    My blue pills look like the red pills
  2. #40652
    The R7376 plug has an identical nose configuration to the stupid expensive shorty plug and cap for less than 1/4 the price.
    Its only difference is the insulator length , thus it uses a " normal " resistor plug cap.
  3. #40653
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Red or blue...Specifications of material are the same on ngk page
  4. #40654
    But try putting the red one on a shorter plug.
    Works either way with the shorter one.
  5. #40655
    So, i finally made a calculated pipe for my violated SGM Kartengine.(bored out to 144cc)
    Running on E85 i made the other day 48.2hp to the wheel at 12700rpm
    Depending on what is correct when calculating losses it is between 51,9 or 56,7hp to the crank(my dyno reports ~10% but some says it should be 15%.
    However, I ran an BR10ECS.
    The diskussion above about that expensive NGK plug, is it known to make any more power than 'normal plugs'?
    My plug and dynosheet, and below link to a livefeed when i was dynoing it.
    Dynosheet shows before and after testing with a no calculated pipe and a calculated in Mota.
    https://youtube.com/live/1gIgPdXmPpY?feature=share
  6. #40656
    Hadn't seen this before, but why stop at 4?
    https://amcn.com.au/editorial/passio...yamaha-yzr500/
  7. #40657
    Very hidden spark Position i think
    Why not trying a cheap BR10EIx?
    And for a new pipe you need new ignition map to gain max out of configuration
  8. #40658
    I can answer myself.
    1.5-2rwhp
  9. #40659
    So there might be more lurking you say?
    Timing is as enginemanufacturer says it should be, now with 58mm bore it can make use of some more i guess.
    But i´ve got a lot higher compression also, to make use of the alcohol.
  10. #40660
    My experience is
    If you use another pipe, ignition timing never fits to manufakturers advice... if you do only one change in complete engine system setup...you need another ignition curve that fits to new circumstances...
    2 strokes are bitches 😉
    Have good times with 😀
  11. #40661
    My experience is
    Forgot to mention that from what i can see on the old sparkplugs timingmark, there isn´t much to gain, looks dam near perfect to me =)
  12. #40662
    As i can see
    Your peak power rpm changed...👍 so you should change 15 degree ignition point to this....best using programmable and set ignition correct at new resonance beginning too...this is gaining much wider powerband
  13. #40663
    I would not use an EIX plug if they were free.
    When run even close to deto, the ceramic shell around the center electrode would immediately crack, then fall of.
    Saw many, many engines killed by those bloody things - they are cheap for a reason.
    The dyno / track work has been done hundreds of times before, in many race engines.
    NGK R7376 Iridium - Platinum or the expensive shorty equivalent, simply makes more power and is way more reliable than any other plug ( including the ND Honda part number ) - end of story.
    The short body plug was originally configured for Honda racebikes with the front cylinder too close to the radiator, but in karting everybody uses them for extra elbow room
    plus of course the proven power advantage.
  14. #40664
    https://youtube.com/shorts/YVAGrbG3M...VUzrVRnbH3sraE
    Powervalve operation, twin ports.
    How far round should the transfers come?
  15. #40665
    They look fine to me, assuming they are aimed backward strongly enough.
