Page 2713 of 2776 FirstFirst ... 171322132613266327032711271227132714271527232763 ... LastLast
Results 40,681 to 40,695 of 41626
  1. #40681
    Aren't you guys getting tired of having to look at my thumb for over a week now? I know I am
    Whenever I post, it kills this thread ... the kiss of thread death.
  2. #40682
    Whenever I post, it kills this thread ... the kiss of thread death 😁
    If you really have that power, I can think of a few other forums you could visit
  3. #40683
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    General 2t tuning question
    Hello fellow sufferers, I have been stumped by something for a bit now. I drag race an air cooled snowmobile which uses a CVT (not sure of relevance but just to be complete I included)
    I always have excessive wash width of 10mm on a 69.5mm bore, and rich plugs along with a chalky white thread base ring.
    My engine responds well to jet changes, however when I go down a size from my known sweet spot EGT, the EGT increases again in a normal increment. This narrows my wash pattern, but the engine has a lean feeling on the warm up stand and my Elapsed time always gets worse. I have 130 logged passes and have rider awareness with this machine. It is a front runner (but I want it perfect lol)
    This almost suggests to me that there is a mismatch with the compression ratio and or ignition timing at peak operating rpm on the cvt. Maybe something else?
    -Comp ratio 15.5:1
    -fuel c12
    -ignition straight line 15 degrees
    -spark plug Br9es
    -stinger diameter 23.6x300 (no nozzle currently because it has always performed better better with full length stingers, maybe a much smaller nozzle than I have used is in order)
    Am I beating myself up for nothing, or does anyone have suggestions to make my setup more synergetic?
  4. #40684
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    The part of the text down to where it says "Jim Allen" is from Jim. The rest of the text is from Bill Givens. I like Jim's fixture, but both people have great insights. Jim mostly rebuilt small engines (26 cc) while Bill rebuilt larger engines.
    Lohring Miller
  5. #40685
    Lohring Miller
    Thank you Lohring.
  6. #40686
    Condyn, what is the actual cylinder displacement - ie what is the stroke.
    15.5 com is nothing for C12.
    This is 2025, why are you using a straight line ignition from the 1970's.
    Also a spark plug from a lawn mower.
    What is the " sweet " EGT at what rpm, is this derived from a dyno run and if so what power is it making.
    Many more questions to get some analysis, but this is a start.
  7. #40687
    ETEC 800
    Minnesota, USA
    Wobbly, it is 452cc. 69.5x59.6 I use the straightline ignition because at many venues that I race, the rules state that a stock ignition must be installed. It is a vintage class from the 70’s. The egt is right at 650c at 9500 rpm, 3x bore from the piston. No, I am familiar with your logical jet selection chart, however I did not have the chance to install the probes on the dyno during the last session.
    The field tests tell me that when I jet down it goes slower. I looked again with my wash light last night and I might be wrong on the wash width. It looked more narrow (around 5-6mm) I am going to take the heads off tonight to get better eyes on it. The piece that keeps me up at night is the egt continues to rise with a down jet (650 up to 670) however it makes a pop on the warm up stand at full rev and makes my pass slower by a tenth every time. Admittedly I do not always have the cht hooked up so I am not aware what the cht is doing when I jet down.
    Edit, HP 104 to the crank on a low reading dyno. How low? I do not know, but I would guess 3% based on others results.
  8. #40688
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Slower in ET or slower in MPH?
    Im wondering if the jetting down is increasing eghaust gas temp and therefore increasing the rpm at which you make peak power to the point that it is no longer in harmony with your clutching (CVT tuning, they're not really clutches but snowmobile people call them "clutches") , or to the point that the pipe is trying to rev higher than your ports will let it (?)
  9. #40689
    4th August 2025 - 22:39
    LYNX snowmobile
    New member in the forum
    Deleted due to dubbelpost
  10. #40690
    Show us a hi res of the piston.
    I was going to say exactly what Storbeck said - I believe that the " tuning " is OK, as the EGT goes up as per normal, but that then puts peak power into the rpm
    where you would have had unused overev previously.
    This would indicate that a shorter " gearing" could be used, and this would make you faster due to the torque multiplication.
    To test if you are close to pushing the outer boundaries at all, I would be looking at adding some static timing with the lean EGT setting.
    I believe 1* to 2* would pull back the EGT to the original " best power " rpm number.
    You can find out how close you are by then leaning down again, and if the EGT flatlines, that is the deto limit.
    If this is the case, then its a matter of making a decision to go back on the timing, and add some com - as I said your com seems very conservative for 110 octane.
    But - the leaner/advanced setup may be faster, you wont know without the dyno data to clutch it correctly.
    PS - cht tells you nothing about the tune - just the under plug temp, BUT most cht will go spastic when getting into deto - but you already knew that as the EGT had already flatlined or dropped.
  11. #40691
    Incorporating the changes wobbly has suggested in the TF125 model and re-running the sim has been very interesting.
    (See suggestions over the last few pages)
    This is without anything too major, IE setting the transfer heights but not changing angles etc.
    Here is how this compares to the model I was using before (With my over-stiff reed petal mistake removed).
  12. #40692
    I forgot to change the pipe entry from 34mm to 36mm.
    I have re-run it and included all 4 versions for comparison.
  13. #40693
    11th May 2024 - 06:49
    United States, CA
    Question RE: Port Edge 'Chamfering'
    So, I have a pile of cylinders I just finished ported that I am about to send off to Millenium Technologies to strip out the stock chrome bores and re-plate with Nikasil. Happy days
    I just got off the phone with the guys at Millenium and they tell me they can do "round" port edges or "45 degree" port edges, with a defined profile view drawing to establish the desired chamfer geometry for the work order.
    I have always done this myself, and I try to go for a nicely "rounded" edge with a radius of ABOUT 0.6 - 0.8mm for all port edges.
    Some recent light reading has skimmed across the notion that the transfer port edges should NOT be chamfered because the chamfered edge will cause the incomming transfer stream to spread/spray out like a fan-nozzle on a garden hoze instead of maintaining the intended tragectory from the transfer port axial/radial aiming angles.
    Instead, the transfer port edges should "just" be de-burred with the edge "broken" but not chamfered.
    Given this idea;
    How would you go about defining that on a work order?
    Should I just tell them NOT to touch the transfer port edges and do it myself?
    Perhaps put "de-burr only/ no chamfer" on the work order?
    I have the rexcut cotton mounted points that Wayne recommended for port edge chamfering of Nikasil cylinders without chipping, but I would rather let Millenium do the work.
    How about the exhaust port edge chamfer?
    What radius size chamfer should I be calling out for the exhaust port of a 52mm jug?
    -70% width single exhaust port with FOS Concept port shape
  14. #40694
    Hi Koba. Rick Ford was running an air cooled TF/TS125 with 22rwhp and that proved really reliable with little heat fade. We could get much more hp out of our aircooled GP125's but the heat fade made the extra power self defeating. We tried all sorts of tricks, like ceramic coatings and extra copper fins. The copper went all the way in to form the squish band. But air cooling was just not up to handling the waste heat from the higher HP.
    Name:  24mm OKO carb.JPG
Size:  5.6 KB Click image for larger version.
Name:	Knock Sensor Earth 2.jpg
  15. #40695
    Quote Originally Posted by ApolloMotoMoto View Post
    Given this idea;
    Tell them NOT to touch the transfer port edges no matter what.
    Jan Thiel once got a set of race-winning cylinders back from replating, that had to go straight into the bin: all ports chamfered in spite of strict orders not to do, and all power irretrievably gone. Needless to say those were the last cylinders ever to go to that replating firm.
    The exhaust port top and bottom edges should be radiused but the side edges should not be touched but only deburred, which you can do yourself after replating.
    I give the exhaust top edge a radius of 5% of the stroke which is a fair bit more than you proposed. It does alter the exhaust timing so you must that take into account before shaping the port.
Name:	Timing radii.png
    The drawing below shows the safe port shape for the benefit of piston longevity.
Name:	FOS port shape concept.png
There are currently 8 users browsing this thread. (1 members and 7 guests)
  1. koenich
