Page 2715 of 2776 FirstFirst ... 171522152615266527052713271427152716271727252765 ... LastLast
Results 40,711 to 40,725 of 41628
  1. #40711
    11th May 2024 - 06:49
    United States, CA
    Question RE: Piston to Wall Clearance
    So, part of the issue with PowerSeal ...failing... to accomplish the Nikasil plating I had originally planned for (redirected to Millenium now);
    I ended up behind the race teams testing schedule, and we have riders flying across the country for the "official test" of these engines for our next race... Good times.
    To make up some lost ground, we are going to do the test with the chrome bores, and then send those cylinder in for Nikasil replating immediately after the test.
    I still have some leftover pistons from the last batch that I had configured for Caber F-Cast rings (Chrome bore compatible).
    And now I am measuring these chrome bores to see just how lucky I am... (if I was planning to do this, I would have specifically asked for cylinders in the right size range for my pistons, in this case I told my partner they were all getting re-bored and re-plated so the bore size didnt matter.... heh)
    I had initially spec'd a piston to wall clearance of 0.060mm / 0.0023" (52mm air cooled cylinder, cast aluminum, forged piston).
    Wiseco says they have tuned their process to the point where their forged pistons no longer "need" extra clearance relative to a cast equivalent, for what that is worth.
    The best I can come up with are 3 pairs of pistons/cylinders with 0.054mm / 0.0021" clearance.
    Would you run a 52mm jug that tight?
    What factors go into deciding "how tight is too tight" for a given engine combo?
    Is there a "generally accepted" rule of thumb (that actually works...) that is merely a function of bore size?
Name:	Cylinder Measuring.jpg
  2. #40712
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Quote Originally Posted by ApolloMotoMoto View Post
    We run wössner forged pistons that are plated with ptfe with clearance 0,05 in aircooled nicasil plated aluminium cilinders bore 54.
    Wössner states the ptfe is a break in surface...but even after 50 hours it isnt worn off completely...only down the skirt you see pure aluminium...
    Ring we changing half the time!
    Grüße Wolfgang
  3. #40713
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Slightly off topic, but related to racing two strokes,
    Those who used to work with the 250 and 500gp bikes, do you remember if they use oil pumps in the gearbox, and if so, do you think the main purpose was, lubrication or cooling?
    Cheers,
    Glen
  4. #40714
    24th April 2016 - 19:07
    2001 zx9
    bop
    Testing my memory here but i recall when the TZ 250 first went to pumped gearbox oil there was a net weight saving as there only needed to be 5 or 600 mils of oil to keep the pump happy, and therefore the gearbox happy. the RGB 500 didn't have a pump but ran a heavy weight gear oil. other 500 gp bikes i believe all run pressure lube. if possible you should do so , heaps of benefits - slightly smaller/lighter gears that are well lubed take the place of heavier/bigger gears. the sliding gear slides easier during a shift as it slides on a "cushion" of +- 30 psi oil. if you have a wet clutch the oil (depending on design) can be getting flushed through taking heat with it so the clutch can be slightly smaller and still be durable. a trans oil cooler becomes a possibility too. it'll be a faster more reliable bike imo
  5. #40715
    4th August 2025 - 22:39
    LYNX snowmobile
    EngMod2T
    Viking , may I suggest you join the EngMod 2T Users Group on FB, I am an Admin so can approve you instantly.
    Looking at your sim screenshot, I see a few things.
    It has very good superposition, but to me it could maybe be improved by increasing the diffuser depression early in the cycle below zero pressure ratio.
    This can be achieved with a shorter/steeper header, and a steeper first diffuser section - these adjustments are seen as improved peak and overev power.
    The rear cone plugging amplitude is impressively high, but a little narrow in width.
    Maybe a slightly longer tailcone, with increasing multiple angles would help.
    Is that rpm at peak power ?
    Wobbly,
    I´m allergic to facebook, but I can´t resist your invitation, so I will show up there some day.
    Regarding superposition and shorter/steeper header and steeper first diffuser section:
    Earlier depression seems to be a good improvement, so I buy that.
    My engine is for a snowcross racing snowmobile equipped with a CVT-clutch,
    so overrev power is not useful.
    I might transform the gain made, to the front side of the peak in some way.
    Regarding plugging amplitude:
    Your suggestion will be tried in the future.
    What width is prefered?
    Regarding rpm:
    Yes, the engine peaks at only 8000rpm.
    Transfer and exhaust ports width are limited by the cylinder studs and crankcase interface surface.
    Also experience made from earlier similar engines, that had the peak at 9600rpm was very
    difficult to tune for various hard snow and muddy snow on the track.
  6. #40716
    That by rule violated Kartengine i´m experimenting with.
    I made some progress the other day.
    New personal record for this engine.
    But what make me most astonished is the overrev capabilites.
    It pulls up agains't 15k
    And before you judge me because of boring it to 144cc, i bought it for about 100bucks with some missing parts.
    It will never see the Karttrack again.
    See more at https://www.youtube.com/@Patricks_Projects
  7. #40717
    The 250/500 GP bikes mostly used a transmission oil pump. The very small amount of oil was stored in a low " sump " as the main benefit of this pump around system
    was to keep a huge amount of oil from being " churned " by the primary drive, reducing heat and parasitic losses - as is the case normally.
    Viking - if you want more upper front side then that is achieved by increasing the length and angle of the last part of the diffuser ,leading up to the parallel section.
    What is the geometry of your current rear cone - maybe I can suggest an alternative.
    As I said your design has good superposition, but even with that the pressure ratio rise after EPO is not spectacular - many " good " designs I have are " off the chart " past 3X.
    You can open a locked FB account, and this would normally prevent you from gaining membership - but as I know who you are, and have a license from Neels, I can let you in.
  8. #40718
    Pukerua Bay
    Thanks for the input guys, oil pump to be incorporated in the new design.
    Cheers,
    Glen
  9. #40719
    2nd July 2020 - 10:39
    2008 Suzuki RM250
    USA
    Exhaust Port Septum
    In a 3 port exhaust layout, what's a practical minimum thickness for the septum between the main exh port and the aux port? I imagine if this gets too thin that it could become overheated and cause problems
  10. #40720
    Max - 2.5mm
  11. #40721
    Max - 2.5mm
    So 2.6 mm is too thick?
    Yes I know, I can be a bastard
  12. #40722
    Haha, a bloody Dutchman that swears perfectly in German and English, how could you not like that guy.
  13. #40723
    As a german...swear it on the bible...if wanted on the coran!!!!
    ..truth is in between!!
    What we are taking about... 65 cordal main or 70?? Gp racer or daily user? 😉
    A 50cc bidalot with 65 cordal main can run 8 hours with only 2 mm bridge at liedolsheim endurance competition on save side!?
    Tell me the truth please! 😉
    Grüße Wolfgang
  14. #40724
    Wob, you're underestimating me. On the job you learn words from your colleagues that you won't find in a dictionary. I think back fondly on Miguel Sauca, the Spanish draughtsman who came with Jan Thiel from Bultaco to Garelli. So now I can also swear perfectly in Italian and Spanish. And in Dutch of course, and a little in French, and even in Finnish.
    Come to think of it, I cannot swear in Japanese. I wonder if that's a flaw in my upbringing or a testimony of Japanese civilization.
    OK, back to the harsh reality.
    Quote Originally Posted by Maxdelta View Post
    I try to answer this type of questions with a universal answer that is independent of bore, stroke, etc.
    In this case my answer would be that the width of a vertical bar between two ports must be at least 5° of center angle.
    Example: a cylinder with a 54 mm bore has a circumference of Pi x 54 mm = 169,65 mm.
    That circumference comprises a total center angle of 360°. One degree center angle has a cordal width of 1/360 x 169.65 mm = 0.47 mm. And a bar with a width of 5° center angle is therefore 5 x 0.47 = 2.36 mm wide.
    Now would be the time to say that you can forget most of what I wrote above. I can simplify it to:
    The minimum bar width must be 0.044 x the cylinder bore diameter.
  15. #40725
    Very well done Frits, thinking rationally like that obviously comes naturally.
    Sadly my immediate reaction only accounts for the obvious proven 54 bore at a 70% chordal, where 2.5mm is commonplace - so yes 2.6mm is too big.
    Also in my opinion anyone saying a 65% chordal is happy with 2mm ( even if it is a 40mm bore ) simply means its closer to a lawnmower than a race engine.
    Some might opine that Im so narrow minded it could fit between the blocks at Giza - and no a credit card wont go, been there , tried that.
There are currently 139 users browsing this thread. (0 members and 139 guests)
