Page 2717 of 2774 FirstFirst ... 171722172617266727072715271627172718271927272767 ... LastLast
Results 40,741 to 40,755 of 41608
  1. #40741
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    I'm not a Viking but I am pretty sure he's using 670 Rotax cylinders that look a lot like this (pictures from ebay ads I found on the interweb).
    The experts can opine if those are lift shafts, to me they are not the MOST squared off lift shaft transfers I've ever seen....but they don't look much like a teacup.
Name:	Screenshot 2025-08-15 095309.jpg
ID:	356525   Click image for larger version.
Name:	Screenshot 2025-08-15 095341.jpg
ID:	356526   Click image for larger version.
Name:	Screenshot 2025-08-15 095356.jpg
  2. #40742
    The Eagle Eye of Mr FOS strikes again - of course the pipe is too short at the lower rpm - dumbarse.
    And yes, I had not considered the effect of the short circuiting regime on the EGT - again an obvious error, thankyou.
    The short header and short steep first diffuser section is aimed specifically to peak and overev generation, then using a steep longer last diffuser section to regain the front side.
    Especially in engines with no PV, that ameliorates many evils.
  3. #40743
    4th August 2025 - 22:39
    LYNX snowmobile
    Late depression
    Hi Wayne,
    Currently my way of thinking on this topic is summarized in this picture.
    Attachment 356519
    My thinking between my simulation iterations was focused on why I don´t achieve a faster pressure drop in 'Pexport'.
    Even if the Rotax 670 cylinders tiny auxilary exhaust ports are modified to enough STA,
    the small auxilary exhaust ducts are very restrective and might be the problem - not the diffuser.
  4. #40744
    LYNX snowmobile
    Late depression
    Neels, whilst working late last night it occurred to me that assuming the Rotax depression wave acts along the same lines as the R3 I am testing, then we have a
    situation where at 1000 rpm below peak power, the pipe - now too long for the tuned rpm, acts to create an even sooner, greater depression at the port.
    Thus it makes me think that at BDC, there will be a large, unavoidable span of rpm where even with an inefficient diffuser, we will have excessive short circuiting, simply due to the pipe geometry and
    the port acting in concert, to pull the suction early and low.
    I dont have any " inefficient " diffuser designs to test in a big cylinder, to see the wave front shape created in that Rotax for example at lower rpm.
    I would be really interested if Viking could post the screen shot, or send me the .pack to understand what happens in this scenario.
    Here is the KZ at 1000 rpm below peak to show the effect in that engine.
    I assume we would only see the down side of this effect on lift shafts, using your excessive short circuit, scavenging model.
    I would happily send you .pack-files, but my moving schedule is to start opening the moving-boxes in October/November, and until then I am computer-lost.
  5. #40745
    LYNX snowmobile
    Lift Shaft Transfer Ducts
    Quote Originally Posted by Storbeck View Post
    Thank you Storbeck,
    this is the kind of cylinders I will use on the engine.
    Bad designed main exhaust duct, auxilary exhaust duct and transfer ducts.
    Even the inlet RV duct in the crankcase is bad.
    But the engine is legendary,
    and dominated on the racing tracks 1992-2000 in snowcross and dragracing.
  6. #40746
    1974 yz 125
    Quote Originally Posted by Viking View Post
    Thank you Storbeck,
    Viking indeed it was!
    The watercraft version was very competitive also.
  7. #40747
    Curiosity killed the,,, butt? :O
    And well worth it.
    New record again, 53.6whp 13000rpm (dyno reports 59.1 crankhp)
    144cc
    E85
    I call this engine DONE! (for now)
    I might build a strange sprintchassi to mount it in.
  8. #40748
    The Eagle Eye of Mr FOS strikes again ....
    Wob, to console you, here is proof that I also make mistakes. For example, yesterday, when I didn't get around to congratulating you on your birthday (I was rather busy in a Ferrari on a nice German racetrack, the Lausitzring). So here you go, to your health, Wob. And to mine, because traditionally my birthday is one day after yours.
Name:	Wobbly's delight-01.jpg
  9. #40749
    LYNX snowmobile
    Frits,
    I must help you keeping away from the alcohol, so instead you maybe can help me figuring out an ignition order and balance solution for my next project. :-)
    I started a pre-study some years ago,
    to find out the possibilities for a 5-cylinder engine to my snowmobile.
    Vikings like power, and 400+ hp in a snowmobile can´t be wrong.
    My initial calculations shows that 1:st order forces is zero,
    but some free moment will occur.
    Is the firing order 1-5-2-3-4 the best solution?
Name:	Concept study of 5-cyl engine.jpg
ID:	356540   Click image for larger version.
Name:	Calculations of 5-cyl balance.JPG
  10. #40750
    26th April 2013 - 21:55
    BMW R1200R 2009
    Happy birthday to you and to wobbly !
    yum yum, Hendrick's is great !
  11. #40751
    1-2-4-5-3 minimizes the rocking couple, in theory.
    As used by Audi, VW and Volvo.
    Myself and a mad mate built a 5cylinder H1 Kawasaki with this and it felt fine, long before Millyard.
  12. #40752
    17th March 2023 - 06:08
    1982,Yamaha RD125LC 10W
    Belgium,East-Flanders
    Hi, when designing a cylinder 3D printing project, I'm unsure of the minimum recommended distance between the A transfer and the main exhaust port.
    Is 5.57mm sufficient for a full FOS transfer concept with all the associated scavenging angles?
    I'm also considering rounding the piston according to the recommended dimensions on FOS OneDrive.
    I’m using a Wössner 8302D200 piston for a YZ125 2005-2021 for this project.
    If I apply the radius, will the remaining 1.56mm still be thick enough?
    Regards, Jan
Name:	distance A tranfer to exhaust.png
ID:	356554   Click image for larger version.
Name:	Original edge1.png
ID:	356555   Click image for larger version.
Name:	Original edge2.png
ID:	356556   Click image for larger version.
Name:	Radius edge1.png
ID:	356557   Click image for larger version.
Name:	Radius edge2.png
  13. #40753
    LYNX snowmobile
    Rotax 670 cylinder
    Unexpected happening. I found a cut Rotax 670 cylinder in my office.
    A-transfer duct and B-transfer duct almost similar.
    Exhaust duct length 60mm and diameter 45mm at flange interface.
Name:	Rotax 670 A-transfer duct.jpg
ID:	356559   Click image for larger version.
Name:	Rotax 670 Exhaust duct.jpg
  14. #40754
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    angles?
    Regards, Jan
    If you do it from scratch, why dont you take a domed, single ring piston?
    Cant remember any advatage of the flat ones...
    Then positioning ring gap in the middle of c port...you are more free doing minimum bridges between b and c ports...
    Have a look at oler yamaha yz pistons
    Or on suzuki rm 125...we use wössner too..
    Exhaust t port?...the bridge is a weak point...not as sturdy as triple port layoutļ
    Just my two cents ��
    Wolfgang
  15. #40755
    Wolfgang
    Hi Wolfgang, thanks for your reply.
    It's an RD125LC. I've chosen to limit my rpm to 10,000 rpm.
    If I cut out the bottom of the skirt (like with the old YZ125H), there's not much support left against piston tilt.
    I'm thinking of making my own windows (two or three).
    That way, I'll have some surface area left over to provide support against tilting.
    That's why I opted for two piston rings, for the engine speed and a bit more resistance to rattle.
    It's a VHM connecting rod (110 instead of 105).
    I haven't found any 56mm pistons with two rings, a dome, a 15mm pin diameter offset by 1mm, and a lower compression height that I can shorten or drill holes in (cylinder intake reed valve).
    Wössner did have them. That's why I was forced to use the flat piston.
    The plan is to install a torroid insert.
    On this piston, the ring gap of both piston rings is in the center of the C port. One is directly in the center, the other a millimeter off center.
    A single exhaust port (70% and safe roof) is sufficient for blowdown and low timing for the intended power and rpm.
    Therefore, I would opt for a T-port or triple exhaust port.
    I'm not sure if the distance between the exhaust and the A-port is large enough to prevent shortcutting.
    Vriendelijke groeten,
    Jan
Name:	piston windows.png
ID:	356561   Click image for larger version.
Name:	piston tripple windows.png
