Page 272 of 2773 FirstFirst ... 1722222622702712722732742823223727721272 ... LastLast
Results 4,066 to 4,080 of 41594
  1. #4066
    Have you guys measured up the RS125 pipe?
  2. #4067
Name:	RS125 Pipe Dimensions.JPG
    We haven't measured ours, but I found this on the net ........... page 270 has a lot of other info too.
  3. #4068
    Ahh, Shit it was right in front of me!
    Cheers, I'm just working over pipe designs and stuff, I've grafted a new one on but its still a heavy road pipe, I would like to make a lighter one soon. Still have much other stuff to do on the bike yet!
  4. #4069
    Cheers, I'm just working over pipe designs and stuff..........
    The maths for Blairs pipe designs are on page 200, for anyone who likes that sort of stuff.
    XL spreadsheet for the basic design of an expansion chamber, based on Blairs work ........... The spread sheet...... Attachment 223667
    I find the header section the hardest to make, page 200 shows the header section of a RG250 pipe being re used so only some new straight cones are needed to finish the pipe.
  5. #4070
    Making progress with my variable V Tech inlet tract and timing. Fitted the divider tonight and bolted it all up.
    The plan is to run it up with the valve fully open then fully closed, compare the graphs and manually switch it during a run to see what a dual curve looks like. I am ready to go, just need to get to the dyno.
    Hopefully it lasts long enough to see if it has any merit and nothing catastrophic happens, like the divider coming loose and getting caught in the rotary valve.
Name:	A3 V Tech Inlet 2.jpg
ID:	239147   Click image for larger version.
Name:	A1 V Tech Inlet 2 (1).jpg
ID:	239148   Click image for larger version.
Name:	A2 V Tech Inlet 2.jpg
  6. #4071
    17th January 2005 - 12:14
    2011 yz450f
    Featherston
    are you building a variable timing system?
    Blindspott are back as Blacklist check them out
    www.blacklistmusicnz.co.nz
  7. #4072
    Quote Originally Posted by Ivan View Post
    TeeZee's inlet idea is like the V Techs dual cam timing, with the rotary valve closing 55 deg ATDC at lower rpm and 85 deg at higher rpm. The size of the inlet tract and hence gas velocity also varies and its hoped both things together will allow the engine to pull well and cleanly from lower rev's.
    Last Sat it ran pretty well around Mt Welly using just 2 gears, but TeeZee could see it was blowing back a bit through the carb when Kel was pulling out of the hair pin. With the V Tech inlet TeeZee hopes it will pull cleanly out of the slower corners and with its great top end run from corner to corner without losing time having to change gears and a zing on the clutch will launch it out of a tight spot or enable it to dive under someone if they let the slightest gap open up.
    Anyway Ivan that's how I understand it from what Ive heard them talking about here at work.
  8. #4073
    Yeah!
    Ive got an OK Pipe but its a double skinned roadbike one. I weighed it tonight and it totals 8KG!
    I thought I would get the rest of the engine sussed and play a bit, maybe with some different road pipes and shapes and when I have it finalised make a final pipe out of nice light and thin stuff and hope the heat difference doesn't change things too much.
    I made this Click image for larger version.
Name:	Bucket pipes 2.JPG
ID:	239175 Scatter plot in excel to give a visual depiction of the differences between a few pipes.
    It isn't all that accurate but I may slowly refine it.
    Note the steep angle of the RS125 baffle.
  9. #4074
    not to thin as this is for a bucket and they spend a fair amount of time on there side
  10. #4075
    That old Honda pipe mod drawing is completely useless, it was never used by the factory in any form.The rear cone is insanely steep.
    And the so called A Kit pipes were designed to work with high Ex ports - where the customer engines all had 83*ATDC to let them rev without an electric powerjet.
    I have much better designs with a ton of dyno time on them, but of course they are all specific to 50Hp 125 cylinders, not 30Hp 100cc designs.
    Here is one that has won dozens of 125 kart titles, but again it should just point you in the right direction for the 100.
  11. #4076
    Is that a foam filter in the 1st pic? Be sure to dyno with and without it. I found that any sort of filter or mesh screen cost hp.
  12. #4077
ID:	239233 Click image for larger version.
Name:	27hp Cylinder and Graph 008.jpg
    No, not a filter, its a wind sheld to stop the wind blowing directly across the open bellmouth and upsetting the carburation. Also in the event of a crash it folds over the bellmouth and hopfully stops realy large rocks being sucked in.
  13. #4078
    Here is the A Kit spec RS125 pipe drawing.
Name:	A kit Pipe.jpg
  14. #4079
    2011 yz450f
    Featherston
    Nice so the valve shuts off at low RPM causing it to change the Inlet port sizing and not overfuel it at low revs? then when you accelarate past a certain RPM it opens right up?
    Just guessing ti doesnt have the Vtec sound of the BOOOWWWW then 6k DAHHHHHHHHHHHHHHHHHHHH
    I had a 2.2 litre Dohc Vtec Prelude thing was insane!
  15. #4080
    Yeah, I'm quite keen to tuck it out of the way so it would take a colission or real nasty ding to dent it.
    You are always full of useful info, cheers.
    Always a Bonus!
    As above
