Page 2720 of 2776 FirstFirst ... 172022202620267027102718271927202721272227302770 ... LastLast
Results 40,786 to 40,800 of 41626
  1. #40786
    The Mychron 5 needs an Expansion Box to run suspension position sensors , and according to its manual this has a set sample rate of 10Hz.
    How do you get 25Hz, but apparently even this will not detect chatter as its way too fast a rate of change.
    Aim has a software update that allows a Fourier Transform into the first derivative of velocity, but according to their own information we need up to 500Hz to see
    high speed rate of change correctly.
    https://www.datamc.org/data-acquisit...city-analysis/
    Re the jetting issue - it was not obvious at all to me that following a slower bike you would " back all the way off ", but anyway, surely the idle and transition jetting has been tuned
    such that there is no issues at idle or on initial acceleration.
    Im guessing that you have tuned the main, on the dyno, or on the track to suit the bowl fuel level height after a period of WOT.
    In the circumstance you describe, maybe the bowl level is dropping at WOT, and when you back off, as no fuel is being used - the bowl refills back to its nominal height and then when
    cracking open the gas again the fuel curve is way rich.
    This means the float valve is too small - Easy to check by adding a small breather fitting into the bowl nut and running a tube up the side of the carb.
    I had that exact issue using Lectron HV40 carbs with clear bowls on a TZ400. On the dyno when hitting WOT you could see the level drop all of 20mm by the end of a dyno run.
    The carbs had 3mm valves, fitting the so called high flow 3.5mm versions with side squirt holes, the issue went away instantly.
  2. #40787
    An age ago on a mikuki i tried bigger valve etc to try solve a problem where upright you could just make it to the end of straight at Ruapuna B but would die as soon as you opened the throttle after the corner.
    I ended up soldering an extension on the bottom of the button style jet in frustration. That fixed the symptoms kinda.
    But the real reason turned out to be that the cross carb drilling was the actual bottleneck.
    Once that was drilled out (and plug the brass ball again) normal jets could be run.
    And that wasn't the last time I encountered that.
  3. #40788
    23rd March 2015 - 21:24
    Conti RX356 V3
    True - it's only 10 Hz and yes you need the expansion to add analog inputs, for the basic setup (and if you're not really good with interpreting the data) it's plenty capable in my opinion and was my "budget" solution compared to the likes of a MXM or others with high resolution. To get the velocities I added a math channel with the first derivate of position and it easily went up to 400 mm/s - which either way is too much acc to the information I could gather.
    Guessed right - all circuits have been tuned, main been done on the dyno. it rides perfectly rolling on the throttle out of corners, main seems to be spot on as long as I'm on my pace. As its a 50cc obviously WOT is used quite a bit so your theory makes sense and thats also what I feel - that it's uber rich if I'm not pinning it till braking point but rather coasting. I'll check that - thanks
  4. #40789
    As I understand it now, even if we see a full stroke dive under brakes at 400mm/s in 1/10th of a second, then there will be only two data points, the start position velocity, and the end position.
    With chatter there could easily be 4 or more cycles, up and down in that time frame, with no intermediate data points to show this.
    Thus only one peak velocity point will be displayed, instead of what is actually happening - the front wheel going spastically up and down at a high frequency above the sample rate.
    In the digital world the Nyquist–Shannon sampling theorem, states that to accurately capture a signal, the sample rate must be more than twice the highest frequency present, thus I can absolutely believe
    that to display high frequency cyclic position changes that 200Hz could be regarded as a minimum.
    Doing the sampling and data logging is easy with a cheap stand alone processor board - but then integrating that into the Mychron with a CAN line is beyond me.
  5. #40790
    Conti RX356 V3
    Well explained, found the same answer while trying to understand the limitations of my setup in the last days.
    Besides the MXm there is also the option to use a Solo 2 DL with an AiM Analog to Can Converter which has a sampling rate of 200 Hz.
  6. #40791
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Apologies if everyone is already well aware of it but rather than starting with a dash/display and adding an expansion, one can start with an evo4s and add a display and have much more capable data logging, 5 channels at 1000hz plus you can still use the expansion through CAN to get more if needed , for sort of around the same cost (a bit more but not huge increase), and still be in the aim ecosystem of software if one is already familiar/comfortable with it.
    https://discoveryparts.com/products/...BoCQlQQAvD_BwE
    For the budget conscious the now outdated "evo 4" (note the lack of an "S") are out there pretty cheap used as people are upgrading. It uses the previous generation software, but still gets you 1000Hz. My opinion these things are an unbeatable bargain if one wants to get into datalogging on a budget. I don't recall but I think the gps updates more slowly on the old evo4 which could be a problem if track mapping is really important to you.
    https://www.ebay.com/itm/12730481203...hoCZSAQAvD_BwE
  7. #40792
    Several racebikes I look after already have the Mychron 5 2T with expansion to run 2X EGT - so I am looking for the most cost effective way of getting suspension data into
    that package.
  8. #40793
    26th April 2013 - 21:55
    BMW R1200R 2009
    I was looking on the freetech50 website, and found it surprising that the first 5 competitors in the 2024 championship were all on membrane bikes, most derbi with Bidalot cilinders. I would have thought that the rotary inlet engines would be dominating, but allas...
    And another surprise : the championship leader is on a prototype with two carburetors ! Last time I saw that was in the late 1970's with the french Moto BUT-HO made by Eric Offenstadt.
    https://freetech50.com/
  9. #40794
    Jan has said that if he were to do it again the RSA would have a rotary valve on each side - maybe the reed in the same configuration has an advantage when you cant simply
    add a 14 speed gearbox to offset the loss of front side power of the Rotary Valve.
    The two small / short reed petals would inherently suit the revs needed to get high piston speeds, and thus bmep out of the 50cc cylinder.
    EDIT - sorry I just read that having a billet machined case with 8 speeds is already running.
  10. #40795
    BMW R1200R 2009
    Indeed, Jan spoke about that on pitlane.biz and also here at kiwibiker if I remember correctly. The 2 rotary valve 50 cc has been done by yamaha in 1961-63 I think. Wasn't even water cooled.
    I did not follow the freetech championship for the last couple of years, but was surprised that the rotary valve is no longer the winning technology.
    Now imagine a 50cc based on a Rimar billet crankcase, 8 speed gearbox, rotary valve equiped with Neil's sliding gibs, a Lectron or SmartCarb carburator equiped with a TPS and electronic Powerjet, a temp sensor in the exhaust for tuning.
    Wouldn't that not be -theoreticaly- a better base than a derbi with reed valve ?
  11. #40796
    IMHO, a single front rotary valve with gibs, plus the cylinder backwards for a straight pipe, PWM - PJ , deto feedback ignition , Servo PV on all 3 ports would only need 6 speeds, due
    to a huge power spread, and would easily destroy even the twin reed engine that is currently SOTA in the class.
    Using a Honda RS gearbox that had a huge range of options available would fix the issue I have seen of the 50"s dropping out of the power in some slow corners, or doing a block pass.
    Here is a 500 twin using this layout, being drawn now.
    With twin Rotary Valves across the front driven by the balance shaft to allow 90* firing in parallel cylinders, like the 250GP KTM.
    EDIT - I just saw a video of the last round and No34, a Kreidler with side Rotary Valve was easily the fastest in a straight line, but got blitzed in the twisty bits.
  12. #40797
    On a kart track reed engines have (or can have if you jet them) beautiful throttle response. Just the change from my 1/2 piston/reed RG to the full reed Derbi was evident in at least 2 corners and probably more where creating a stable platform helped grip.
    I had a Borrowed fast for the day KE100/RG400 barrel for a while. I could ride it fairly effectively but it was borderline dangerous coming on power if you were near full lean.
    I thought they ran on full size tracks?
  13. #40798
    That's exactly what the sliding disc valve cover gibs are for.
  14. #40799
    17th March 2023 - 06:08
    1982,Yamaha RD125LC 10W
    Belgium,East-Flanders
    I would like to second that. Please keep us informed about your project. Metal printing is very interesting!
    Hi, I've made it this far with the transfer ports and exhaust.
    The C-port and inlet port are the next step.
    Does anyone have any comments, tips, or suggestions for improvements to the duct shape, B-hook, or other suggestions?
    Footprint of the crankcase original Yamaha RD125LC-10W to all scavenging angles FOS concept.
    Regards
    Jan
Name:	Tranfer ports 1.png
ID:	356615   Click image for larger version.
Name:	Tranfer ports 2.png
ID:	356616   Click image for larger version.
Name:	Tranfer ports 3.png
ID:	356617   Click image for larger version.
Name:	Tranfer ports 4.png
ID:	356618   Click image for larger version.
Name:	Tranfer ports 5.png
  15. #40800
    Jan, with the exhaust duct shape in your drawings you are leaving a lot of blowdown flow on the table. The pictures below may show what I mean.
    Never mind the center bridge and the auxiliary exhaust ports in my pics (although it would be good if you could accommodate these).
Name:	radial exhaust flow.png
ID:	356623Click image for larger version.
Name:	radial exhaust flow concept.png
There are currently 21 users browsing this thread. (2 members and 19 guests)
  1. pirkka1
