Page 2722 of 2776 FirstFirst ... 172222222622267227122720272127222723272427322772 ... LastLast
Results 40,816 to 40,830 of 41630
  1. #40816
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    JVH, just something to try - when the main port duration is 190* to 192* with the pipe length adjusted to suit, I have found more overall power due to a naturally very wide band of superposition prior to EPO.
    This is the difference between a resonating pipe and a tuned pipe:
    1. A tuned pipe is a pipe where the pressure pulse reflected from the reverse cone arrives in time to push over scavenged fresh charge back into the cylinder;
    2. A resonating pipe is a tuned pipe that builds stronger pulses by combining the new pulse with the residual pulse from the previous cycle to build pulses and suction pulses of substantially higher amplitudes.
  2. #40817
    17th March 2023 - 06:08
    1982,Yamaha RD125LC 10W
    Belgium,East-Flanders
    Months ago, I read somewhere on a forum, perhaps here or on Facebook, that an exhaust only starts working properly at timings of 190°. I have no idea why.
    With this in mind, I tried first 185°. It produces a better power curve than the single exhaust port. So I thought, yes, 185° will be fine.
    With your explanation Neels, I now understand what I read about 190°. A pipe will probably only starts resonating at 190°.
    I'll definitely try that in Engmod.
    Just a question for information. I learned in Mechanics that when designing machines, engines, bridges, etc., you have to pay attention to the natural frequencies of the structure.
    When the load or operating conditions generate a frequency close to or at the natural frequency of the structure, this leads to total failure.
    For example, as everyone knows, a platoon of soldiers shouldn't walk across a bridge in rhythm, or the bridge could resonate and bend further and further until it breaks.
    This applies to solid matter, but apparently a gas can also resonate? A resonating exhaust.
    Apparently, those resonating gases don't cause fracture.
    I once read from Frits that the waves in a 2-stroke exhaust are not the same as the sound waves in a trumpet, for example.
    Difficult material for me to dig deeper into.
    In any case, I'm going to try a 190° version in Engmod and then come back here.
  3. #40818
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    "No idea at all how many degrees of difference there should be between main and aux ports"
    JVH... why go to a limit with the bridges on a triple exhaust when you have much chances to gain enougth blowdown. ..?
    Stay on the save side and gain long reliability!? Thats nice to have
    If i remember coreectly once frits told us 5 degree for every bridge between every port in a cilinder ...
    Such a nice thing like a printed cilinder...them i would change case transfers too
    Maybe, if case is sturdy...only a big one per side!? So you are more free with directions of cilinder transfer !? good thing ...
    Grüße Wolfgang
  4. #40819
    Grüße Wolfgang
    I think you misunderstood my question. I meant the difference in height between the main and auxiliary levels. Not the degrees that represent the width of the bridges.
    Wobbly already pointed me in the right direction and answered.
    Thanks anyway.
    Groeten Jan
  5. #40820
    The waves are essentially the same. Waves moving through a gas are local compressions of the gas where the molecules are closer together.
    Compare it to circular waves on the water surface when you throw a stone into a pond. You see that the wave tops move outwards from the point where the stone hit the water, even though the water itself does not move, which you can see by looking at what is floating on the water.
    The difference between exhaust pulses and a trumpet sound is not in the nature of the waves, but in the way you can describe their behavior.
    For the trumpet sound you can use acoustic rules. And I deliberately write acoustic RULES and not acoustic LAWS because they are not laws. Those rules are derived from gas dynamics laws, simplified with a lot of assumptions that are acceptable as long as the sound pressure does not exceed a certain limit.
    The wave pressures in a two-stroke exhaust exceed that limit by a factor of over a thousand. So forget about acoustics when you are dealing with waves in exhaust systems.
    Now you may remember where you read it Jan .
Name:	Helmholtz Blues.jpg
  6. #40821
    This may also allow more timing split with the Aux ports, so their differing ( longer ) duct length has less effect on the wave amplitude generated by the main port into the diffuser.
    But this may not show up as a huge difference in EngMod as there is no mechanism in the code to define the Aux ports duct length, only an assumption on my part - dangerous.
    Main exhaust timing adjusted to 190°, main to aux = 3,8° instead of 2,3°.
    Transfers and blowdown fully balanced. Pipe tuned lenght to 10k exactly.
    Result: bmep rises from 13,58 @ 185° to 13,93 @ 190°.
    1hp more but...lost a lot of front and mid power.
Name:	difference 3 port 185° exhaust vs 3 port 190° exhaust.png
  7. #40822
    That's a nice visually understandable comparison
    Indeed. You can't imagine all the things I've read from you.
    But remembering it all...that's no longer possible at 55.
  8. #40823
    Liedolsheim 2025 - The Short Report
    Here is a short report on the racing at Liedolsheim.
    It's not too detailed, basically due to laziness and a lack of ability to make things interesting in written form.
    I decided to take a look at this race after asking a very helpful person on here for info on different race options.
    I was surprised to see a countdown with a small number on it, so off we go!
    The race has been run since 1994, on a 1KM Kart track.
    There are 3 classes, badly summarised here:
    *Open 50cc
    *Restricted 50cc (Aircooled, other stuff)
    *125cc 4T "Stock"
    There is the usual practice, qualifying etc. We turned up at just the right time, as the bikes were being rolled out to the dummy grid.
    This was really cool, it was oddly familiar for me; basically buckets.
    The classes are a little different but almost all of the bikes would have worked for NZ bucket racing. Likewise, NZ 50's and some 4T 125's would have fit here.
    Le Mans start, always fun! This time uneventful, other than the slight jump with people running at the raising, rather than the drop of the flag.
    Then, lots and lots of exciting racing.
    There were about 6 teams showing really good early pace.
    The fastest were really impressive but after the time wore on, and on, and on, it started becoming clear that there were two main contenders.
    #29 and #91.
    Other bikes were faster in a straight line and for short runs but these two really both had a lot of things working right.
    The rider changes and refuling were done well, all riders were fast, they cut through traffic very well (and cleanly).
    8 hours.
    8 hours is a fucking long time.
    That is 8 1-hour shifts on the bike, the teams have a maximum of 3 people.
    I've done a 1 hour shift on a 50 before and it wrecked me pretty badly, It's another level (Respect!) to then go and do it twice more.
    So, this kind of racing, the nerds can crunch some numbers on pace, time laps left etc.
    It was amazing to see it was still a competitive race until the end!
    Then there were beers, music and things.
    Bloody good time, I met some cool people there.
    Something that was really good was the lack of crashes, there were a few, I got a good eyeful of a decent highside- that was, picked, up, taped up, back out!
    moto5.de has more info.
    So, if you are reading this and are able to take a look next year; it is well worth it.
  9. #40824
    JVH, so the next question to ask is have you tried to use my 1.5 X duct length - 75% area ideas, now you have converted to a 3 port.
    You will be making your own pipe, so the cylinder does not need to be " stock appearing ".
    This will pump up the peak and overev considerably, allowing a much longer pipe to assist the front side.
  10. #40825
    Hey Mal thank for the report.
    Full size tracks are so much easier than karts . You've done Battle of Buckets vs 2hr. But yeah 8hr I wouldn't be much chop even when I was fit.
  11. #40826
    JVH, so the next question to ask is have you tried to use my 1.5 X duct length - 75% area ideas.
    No, I used the same 50mm exhaust duct length as with a single port.
    I've saved your PDF about duct design V3.0 somewhere and will check what lengths and diameters it prescribes.
    So far, I've always pressed the calc button in engmod and used that exhaust exit diameter.
  12. #40827
    These were my immediately thaughts too...a pipe that peaks at 9000 maybe...and you get back frontside...and maybe 190 degree is to very early to pipes proper resonance job ...maybe that depends on curvature of upper side ex you use too...
    Is engmod today able to do a propper ignition curve itself that suits to given circumstances?
    What does it look like engmod is calculating with?
    Is it a flat line ignition?
    Further i miss a clear resojnance dip?...as seen usually seen in a dyno graph?
    No crtics to you! Maybe its just the way engmod works...
    Thanks to the involved specialists!!
    Grüße Wolfgang
  13. #40828
    25th January 2019 - 01:33
    Southwest of Germany
    #29 and #91.
    Hi koba,
    it was a pleasure to meet you and your family.
    Btw #29 has won the race. He is known as koenich.
    Well done Daniel😁
  14. #40829
    JVH, the 50mm duct is WAY too short - and yes Neels has put the 75% area guide in the code, and that is the result you get when pressing the duct exit radio button
    when having input a 3 port.
  15. #40830
    23rd March 2015 - 21:24
    Conti RX356 V3
    Great you enjoyed it and nice to meet you
    Thanks for the flowers gents!
