Page 2725 of 2775 FirstFirst ... 17252225262526752715272327242725272627272735 ... LastLast
Results 40,861 to 40,875 of 41611
  1. #40861
    23rd March 2015 - 21:24
    Conti RX356 V3
    Let me know once they are available
  2. #40862
    27th July 2025 - 21:44
    Jawa 638
    P
    Thank you DSE. Yes, I prefer to be called just Frits, without the 'Mr' or even the 'Dr' that Germans seem to be so fond of.
    And of course everybody is free to use the nickname he or she prefers on the internet, be you would make me happy if I could call you by your first name too.
    The most import radial transfer angle is the leading direction angle of the A-transfer port. Why make it 40° instead of 30° if you still enjoy the freedom of the designing stage?
    Attachment 356727 Attachment 356728
    I understand you.
    Of course, I'm not German, but where I was born and raised, at an early age, respect for people older than you is embedded in education, and even more so for those from whom you study.
    I do not know the correct equivalent in English, as I could in general. If I offended you, please excuse me.
    My name is Slava, among colleagues and friends.
    Now, regarding the radial angle of the purge channel, I will have to clarify.
    I assumed that for an engine with a cylinder volume of 250 cubic centimeters, I would be able to use a backup crankcase from the 193 cc engine, which I had designed and manufactured earlier. And on it, the attachment points of the cylinder are very close. And it is difficult to deploy the purge channel. Now it becomes clear that I will have to design and manufacture a new engine crankcase. .
    Here he is, 193 engine.
ID:	356730   Click image for larger version.
ID:	356731   Click image for larger version.
  3. #40863
    Jawa 638
    P
    Your engine has a 69,5 mm bore and a 65 mm stroke so it's definitely short-stroke which as you may know, is unfavorable for the specific angle.areas in a two-stroke engine.
    Your 129 mm con rod length is less than twice the stroke. If I were free to design an engine, I'd use a rod/stroke ratio of 2,2 , so noticeably longer than you are planning to use.
    I also understood the axial angles, I'll also redo them and show them. There is, however, a slight problem in this, in my opinion, when processing the sleeve, but I think that a 5-axis machine can handle it.
    I also realized from the connecting rod that I would have to postpone the workpieces and "draw" a new connecting rod.
    On the 193 engine, by the way, I have a connecting rod with a ratio of 2.15.
    I've been wanting to make a connecting rod like this for a long time, but somehow I can't get my hands on it. Now you'll definitely have to do it with a 2.2 ratio.
    (p.s. - again, he writes nonsense, the ratio of the length of the connecting rod to the stroke of the piston, Google interprets in its own way..)
ID:	356732   Click image for larger version.
ID:	356733   Click image for larger version.
ID:	356734   Click image for larger version.
ID:	356735   Click image for larger version.
Name:	Connecting rod(1).jpg
  4. #40864
    Jawa 638
    P
    Your posts raised a number of questions. And I guessed wrong with your 'jumper' so now I will simply ask instead of guess: what is a graduation channel?
    I'll be watching more closely what Google translates.
  5. #40865
    Quote Originally Posted by Gradella23 View Post
    we weren't able to find the right match with the original cagiva gear spacing, so we always lacked the right timing in super slow corners.. this low revs config helped us covering this problem.
    anyway we'll develop some more during the off season to gain something revving higher.
    in the coming weeks i'll have a pair of derbi (but euro3) cylinders to begin playing with. I want to finally develop a credible alternative to the very good bidalot kit.
    I cover this problem with clutch abuse.
    (Not close to the same power level).
  6. #40866
    13th April 2022 - 19:08
    None
    Florence, Italy
    it helps!
    unfortunately we were racing with an almost 90kg street production bike Cagiva Prima, against some handmade and/or proper racing bikes with magnesium rims, great suspension, and weighing 65kg so having some more power down low was even more valuable
  7. #40867
    Quote Originally Posted by DSE View Post
    I assumed that for an engine with a cylinder volume of 250 cubic centimeters, I would be able to use a backup crankcase from the 193 cc engine, which I had designed and manufactured earlier. And on it, the attachment points of the cylinder are very close. And it is difficult to deploy the purge channel. Now it becomes clear that I will have to design and manufacture a new engine crankcase. Here he is, 193 engine.
    Thank you, Slava. I see that your “freedom of the design stage” is not unlimited, as I had assumed until now.
    A connecting rod/stroke ratio of 2.15 is acceptable. But a 250cc single with a cylinder sleeve and an exhaust centre bridge is asking for thermal problems.
    Your pictures have made me curious. How do you use an engine without a gearbox on a kart? Does it get an automatic clutch or a CVT transmission?
    I find the spark plug caps interesting. Where did you find them?
    As for Google Translator, I don't use it anymore. The translator from Deepl.com is much, much better.
  8. #40868
    23rd July 2017 - 21:59
    n/a
    canada
    Hello, I'm looking for a 67.5mm cast piston with an 18mm pin.
    I'm from Canada and I can't find anything good here or in the United States. Do you know of any brands in your country? Thanks.
  9. #40869
    Jawa 638
    P
    I bought these ignition coils when my friend was making a programmable system. This is from Suzuki's outboard motor. Coil tips: - fluoro-rubber. I use a centrifugal clutch (pictured below), but this decision is not final.
    I found one here: - ..https://aliexpress.ru/item/100500860...type_rcmd=core
ID:	356739   Click image for larger version.
ID:	356740   Click image for larger version.
ID:	356741   Click image for larger version.
  10. #40870
    Jawa 638
    P
    I'm looking at such a model, I would probably try it.
    I'm falling asleep now, and I'm going on a business trip tomorrow.
    I'll answer any questions in a couple of days.
    https://www.bmikarts.com/Bully-34-Tu...M_p_20809.html
    Regards
  11. #40871
    2nd August 2011 - 11:11
    Connecticut, USA
    Rotary Valve Balance
    Frits, Wobs or others: Is it important to have the rotary valve drive balanced to offset the imbalance of the rotary valve itself? We are thinking there may be additional power to be gained with a balanced disc.
  12. #40872
    Quote Originally Posted by dtenney View Post
    In theory yes, without a doubt. But I have no idea how much extra power it would yield; never measured it.
  13. #40873
    I have seen a couple of engines with the center boss of the valve weighted on one side.
    But most dont seem to worry about it.
    The force is a constant circular out of balance vector, not a cyclic one.
    Bearings be they ball or roller dont mind constant radial forces, within their load rating of course - cyclic ones where the elements have wildly varying loads is what creates issues.
  14. #40874
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    fluorine rubber ( fkm in germany also known as viton) has nothing to do with special marine use. Its a rubber with one of the best oil and heat resistance and is used in all ngk rubber spark plug caps and in many sealing rings too...
  15. #40875
    11th May 2024 - 06:49
    United States, CA
    Curious if anyone here has any experience with 3d printing functional intake parts, reed valve boxes, reed valve bodies, carburetor mounting flanges, etc.
    Bonus points for experience with ethanol/methanol fuels using 3d printed intake parts.
    For a few reasons I am attempting to come up with a working solution for 3d printed reed boxes for my application.
    3-4 different carbon type filaments have been used in standard FDM style printers, and so far have failed pretty miserably.
    Following a thread from a few different manufacturers that are actually selling retail 3d printed intake parts, I have my latest round of test parts back, printed out of Nylon PA11 and Nylon PA12 (expirimenting between the two) printed on an HP MJF machine, the important distinction being that its not a filament deposition technology, but instead a "powder bed fusion" technology.
    Pictured below.
    The darker "flange" that bolts to the cylinder is Nylon PA11, the lighter reed box that bolts to the flange is Nylon PA12.
    Will post back with the results from testing these samples.
Name:	AMR GP90 Reed Box and Mid Plate 1.jpg
ID:	356744   Click image for larger version.
Name:	AMR GP90 Reed Box and Mid Plate 2.jpg
ID:	356745   Click image for larger version.
Name:	AMR GP90 Reed Box and Mid Plate 3.jpg
ID:	356746   Click image for larger version.
Name:	AMR GP90 Reed Box and Mid Plate 4.jpg
ID:	356747   Click image for larger version.
Name:	AMR GP90 Reed Box and Mid Plate 5.jpg
