Page 2727 of 2774 FirstFirst ... 17272227262726772717272527262727272827292737 ... LastLast
Results 40,891 to 40,905 of 41608
  1. #40891
    Meths was a formula 3,2 etc thing.
    Never buckets in my knowledge.
    Mike?
  2. #40892
    Yes, certainly not in my time. I have heard Fletlander lament the loss of methanol. Maybe I have just heard rumors and imagined it was totally open fuel in the beginning. Anyway I would just love to be able to apply a bit of chemistry to my bucket racing.
    Alcohol fuel was only allowed as was supercharging turbo etc with 100cc Four strokes. These were the days of 130cc four strokes and 104cc two stroke, ie pre 125cc ac 24mm carbs.
    I have one of the old rule books ACU from the 90's.
    i dug out a book it was pre 92-93
    MNZ was called NZACU then
  3. #40893
    I do remember experimenting with methanol in my AC50 bucket racer when I was in the Air Force. Probably because I had it lying around for my other bike. Never raced the bucket with it. I think in the air force days that nobody cared. With the state of tune back then it wasn't needed so as far as I recall there was nobody using it. I hardly knew Neil back then so he might have been. A bit of Methanol for the FZR would be nice although even on petrol it's still tuned reasonably cautiously so currently not required.
  4. #40894
    27th July 2025 - 21:44
    Jawa 638
    P
    fluorine rubber ( fkm in germany also known as viton) has nothing to do with special marine use. Its a rubber with one of the best oil and heat resistance and is used in all ngk rubber spark plug caps and in many sealing rings too...
    Thank you for declaring the brochure, as I understood from the first sentence of your post.
    But I couldn't quite understand the meaning of the second sentence.
    Probably because of a problem with Google translation.…
    Well, let's get back to the ignition coils that were discussed.
    I have not puzzled over why the manufacturer used this material, which we are discussing, on the spark plug caps. I just needed an ignition coil with two terminals and certain electrical potential characteristics. And I bought it.
    From my own practical experience, I can say that I have used this type of elastomer to protect steel parts during coating, in particular chrome plating. Galvanic electrolytes could not destroy the protective covers made of fluoro-rubber for a whole year. There were about thirty chrome plating cycles....
    Why is seawater scarier to use than electrolytes?
    The composition of Viton may vary depending on the manufacturer and the specific product, but in general, it includes the following components.
    ....let's turn to the reference books:
    Fluorinated rubber, which provides high chemical and thermal stability. This material contains fluorine and other chemical groups that give it certain characteristics.
    Seals, fillers, and modifiers that can affect the mechanical and chemical characteristics of the material.
    Stabilizers and antioxidants, the main task of which is to prevent degradation of the material under the influence of heat and the environment.
    Various additives can be introduced to improve the processing, mechanical properties and other characteristics of Viton.
    It is important to note that the specific compositions of Viton may vary from manufacturer to manufacturer and for different products within the same brand.
    Viton (FKM) is a group of fluorinated elastomers with different chemical structures, and its operating temperature may vary depending on the specific type of Viton.
    Viton (FKM) material has several features that make it popular and valuable in various industrial fields, some of them:
    Chemical resistance – the material can withstand aggressive chemical environments, including oils, solvents, acids, alkalis and other chemically active substances.;
    Thermal stability – Viton is capable of operating in a wide range of temperatures, both low and high. This allows it to be used in conditions where preservation of sealing and insulating properties at elevated temperatures is required.;
    Mechanical strength – the material is resistant to bending, stretching and tearing. This makes it suitable for applications where it is under mechanical stress.;
    Oil and fuel resistance is what makes it valuable in the automotive and aviation industries.;
    Elasticity – Viton can retain its sealing properties even under compression, bending or stretching;
    Radiation resistance – the material is useful for use in the nuclear and aerospace industries;
    Insulating properties – Due to its chemical resistance and elasticity, Viton is also used in insulation and sealing products such as gaskets and rubber seals.
    Can you name a really strong argument against using this material in spark plug tips???
  5. #40895
    Yes, alcohol was allowed in 100cc fourstroke, as was supercharging, in fact fuel for such was open. Vinduro rules allow supercharged fourstroke, fuel open, but unfortunately recently have outlawed EFI.
    Buggers, I can't win.
  6. #40896
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Quote Originally Posted by DSE View Post
    Indeed we missunderstood us !
    FKM is one of the best Materials for the use in spark plug caps in general, no matter if marine, offroad or street.
    Thats the reason why NGK uses it in every Rubber cap
  7. #40897
    Methanol is really tolerant of running rich. I know it hurts thinking about it but a carb wouldn't be all that bad with methanol. Add an ECU to handle everything else. Pretty much what I'm doing with my McIntosh. I'm using the original Zenith carb, with JATO mods, and the intake manifold, because that's the rule, and putting my Link ECU on to run everything else. The ECU will be in charge of boost control and ignition and monitor all the usual.
  8. #40898
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Is efi outlawed, or is it that you must run a carb? Maybe you can run a carb then also supplement it with an injector?
  9. #40899
    Blah
    Quote Originally Posted by Storbeck View Post
    It does specifically outlawed EFI, but if I wanted to I could just ignore the rule and enter in the Vinduro trail bike class, no points, just participate. But I not that old just yet. 😁
  10. #40900
    Im tempted to do a tandem twin, disc valve, twin exhaust port per cylinder, water cooled, powervalve .... you know, the works. Wouldn't that be fun in Vinduro. 125cc.
    34 flat slide too big for a 63cc ? ( over bore allowance).
  11. #40901
    Honda did a disc valve behind the cylinder twin 125 in about 1984-86
    Frits i think has posted pics of it.
    2x 24mm i think would be ample giving good drivability.
    Had a ribi frontend
    https://www.motorcyclespecs.co.za/mo...nda_RC125M.htm
    Although looking at this pic it might be cylinder Reed
    They definitely did a behind the cylinder disc at the same time maybe on a single?
    This was the honda behind the cylinde disc of the same period Frits posted.
    it looks more 250 due to the clutch cable on the left like a 350/500CR also that twin has a left foot kick. Right side drive.
    Gillera did a twin 125 maybe a few years before?
  12. #40902
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    We fired up the TST100 with its 3D printed crankcases the other night. Pretty happy with how it went considering.
    First learning with the injection, my primary injector was way too large and I lost control of fueling low down, it'd either lean bog or flood. Easy fix though. At the moment it's running a typical alpha-n map, but once the new injectors turn up, we'll swap over to the custom software.
    https://www.youtube.com/watch?v=0LkzgFYekEk
  13. #40903
    Rob, what would be a suitable rod and piston combination for a 63cc disc valve engine?
  14. #40904
    1974 yz 125
    Practical or not, a 125 twin would be kinda cool.
    There might be interesting things you could do with electronic controls on a carb. Maybe controlling float bowl pressure somehow or pwm controls on jets, that sort of thing. I play with watercraft that use diaphragm controlled carbs always thought it could be interesting to control fuel pressure in the diaphragm with a computer controlled bleed of stone sort. No idea if it would actually work in any useful way
  15. #40905
    34mm carburetors, only because I have a couple. I'll look for something smaller.
    If its a disc valve engine I could hide all EFI stuff behind the 'carb ' cover. Not the first time I've done this. Pre 75 VMX, there was no actual rule so to avoid upsetting anyone I hid my EFI system all behind my Kawasaki 350 intake cover, and never plugged the laptop top in at an event. But with Vinduro it's an actual written rule., no EFI.
    I can live with carburetors.
    I don't know enough about diaphragm carburetors.
There are currently 124 users browsing this thread. (0 members and 124 guests)
