Page 2728 of 2774 FirstFirst ... 17282228262826782718272627272728272927302738 ... LastLast
Results 40,906 to 40,920 of 41608
  1. #40906
    13th April 2022 - 19:08
    None
    Florence, Italy
    Rob, what would be a suitable rod and piston combination for a 63cc disc valve engine?
    When i was thinking about designing a cylinder and crank kit for the italjet formula 125 twin, i was eying the kawasaki kx60 vertex piston, 43mm bore with one ring.
    and a 85 or 90 mm conrod
  2. #40907
    Frits Overmars makes a cameo appearance in this video
    Lexus lfa exhaust. for those with short attention spans about 16.50
    https://www.youtube.com/watch?v=crEeOEs4ZP0
  3. #40908
    We fired up the TST100 with its 3D printed crankcases the other night. Pretty happy with how it went considering.
    First learning with the injection, my primary injector was way too large and I lost control of fueling low down, it'd either lean bog or flood. Easy fix though. At the moment it's running a typical alpha-n map, but once the new injectors turn up, we'll swap over to the custom software.
    https://www.youtube.com/watch?v=0LkzgFYekEk
    Sounds fantastic Glen. Look forward to seeing it on track.
  4. #40909
    Frits Overmars makes a cameo appearance in this video. Lexus lfa exhaust. For those with short attention spans about 16.50
    World fame after all
    https://www.youtube.com/watch?v=crEeOEs4ZP0#t=16m47s
  5. #40910
    Quote Originally Posted by Gradella23 View Post
    I actually have a KX65 cylinder here somewhere, I must dig it out.
  6. #40911
    Pretty sure i have one here too. Sing out if you want it..
  7. #40912
    Thankyou.
    I'll likely cast my own but I might take a look at the transfer arrangement.
  8. #40913
    Thankyou.
    they aren't that good tbh, flat roofed things.
    if you were going to copy anything i would copy the ktm65 2009 on.
    The ktm 50 was designed as a 65 and shrunk down.
    this is what they look like
ID:	356795Click image for larger version.
ID:	356796Click image for larger version.
ID:	356797Click image for larger version.
    this one is only $149nzd a few hunded kms away
    i wonder why lol.
    https://pronorthparts.co.nz/65-sx-20...230138000-278/
    this is their piston
Name:	Screenshot 2025-10-09 7.14.16 PM.png
    For the rod in 12mm gudgeon you can go up to 98mm with a ts90/100. They have those weird Suzuki 19mm crankpins,
    but Honda on the mbx80 nrs50 are 91mm to suit the 12mm se pin. 18mm big end pin
    Yamaha pw80 is 12mm pin and 20mm bigend 94mm
    Derbi senda is a 90mm on in 16mm be pin
  9. #40914
    Where could we use this little beauty
    https://youtube.com/shorts/id6LxB2RN...XDlYC34mK6zF5V
  10. #40915
    https://www.youtube.com/watch?v=WZgAPV5M5Es
  11. #40916
    11th May 2024 - 06:49
    United States, CA
    Dynamic tailpipe restrictor nozzle.
    Larger diameter at low rpm, closing down as RPM's rise to extend the effective resonant range of the pipe, similar in concept to a powervalve on the exhaust port.
  12. #40917
    26th April 2013 - 21:55
    BMW R1200R 2009
    Quote Originally Posted by ApolloMotoMoto View Post
    Frits Overmars allready designed that, with a solution that is mechanicaly more easy to operate. (linear motion for the restrictor in the tailpipe)
  13. #40918
    BMW R1200R 2009
    This idea could well evolve into a Mark II version of your 'double sliding gibs' on the rotary valve !
  14. #40919
    United States, CA
    Correct
Name:	end cone bleed valve.png
  15. #40920
    Not at all what I had in mind.
