Page 2736 of 2776 FirstFirst ... 17362236263626862726273427352736273727382746 ... LastLast
Results 41,026 to 41,040 of 41630
  1. #41026
    I am almost feeling guilty about bringing this up, as they are Italian.
    But I am looking for a not so common Brembo caliper for a pre-89 project.
    I know I can buy a new repo or get one close enough like a ktm60/65, but as I am in pretty deep now and a bit of an anorak.
    As best as i can discover they were oem on a few bikes of the late 80s and early nineties they are a Brembo calipers As used on the TY250, Aprilia Climber, Montesa Cota, and I think a few others, like I possibly husky al ktm Gas Gas .and Fantic.
    DR50 Big.
    Grimeca and AJP later made a similar one used on a lot of debris, like the Senda and the early ubiquitous early 98 to 01 KTM 60/65. Which if i can't find a cheap one ,is what i will have to use.
    Anyone have a lead on one or know other bikes that have them? i found a few but Shipping on eBay from the EU or US is almost criminal or the sellers dont want to?
    I tried the usual cross matching through pads etc but they used similar pads on other Brembo and Grimecas?
    They look very similar to a Yamaha RD350 caliper only smaller and not cast iron the Yamaha ones which i always thought was a licensed Lockheed Copy?
    The Brembo also have square pads.
    pic to be attached if KB lets me.
Name:	Screenshot 2025-10-26 7.00.04 PM.png
ID:	356896Click image for larger version.
    Last edited by husaberg; 29th October 2025 at 19:54. Reason: ps Dave the TZRD NF has a tank and seat now:)
  2. #41027
    18th August 2015 - 20:39
    2005 honda hornet
    italy
    Having not had any response from my many attempts to contact Franco , and receiving no feedback from the Flenghi brothers Filippo /Thomas I contacted a friend
    Marc Marcelet.
    He is also a very good friend of Roland and he has asked him to contact Filippo in person ( in Italian as he speaks little English ).
    They have agreed to fulfil my normal " contract " for the R3 development work, but I fear I have been " tarred with the same brush as Franco " and am now PNG.
    Really pisses me off, having started working with Claudio well over a decade ago and I have turned down work from others feeling loyalty to TM with such a long association.
    We shall see what Roland can find out - I know he worked at TM, but Franco never had a kind word to say - nothing unusual about that though.
    The latest info is that Franco was fired as he was spending all his time trying to get his own KZ engine homologated, ran out of time, and the Lenzo thing is just a stop gap.
    did you know that TM was sold to a fund, the same one that owns the OTK group (tonykart/vortex) & vegatyres?
  3. #41028
    Several people with Tinfoil hats have said its a "Mafia " fund - just conjecture I imagine.
  4. #41029
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    Carb Needle
    I am wondering if anyone has experienced having a carb needle snap?
    On my PWK. I've recently snapped two through a clip slot.
    Seems to happen after landing a jump
    I am guessing it's either a worn slide or the body.
    But before I order another needle and a new slide. thought I would ask
  5. #41030
    That's some weird shit. I had some debris fall in (trackside jetting) ans it caused the needlejet damage so it would scratch and hang up a needle (ie stick) had to turn up a new insert.
    But snap??? That's weird. Genuine PWK not a clone?
  6. #41031
    In the Dellorto 30mm carbs I use they have a washer sitting on the clip, and the screw in needle holder has a spring that pushes down on that washer.
    Thus the needle can float.
    It does of course and that wears the needle parallel and the tube, eventually making the transition and mid go rich.
    The cure was to put a washer on both sides of the clip, insert the holder loosely and fit the slide.
    Then push the slide up and down a few times and lock the holder.
    This clamped the needle in place.
    It did two things - eliminated the wear issue, and weirdly it reduced deto, allowing leaner mains and higher EGT.
  7. #41032
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    There are many adtermarked and copy pwk in the universum Needles and clips too.
    Some needles are of bronze / cusn with clips that look that they ar made of brass or copper berylium..
    CUSN is not very break ressitant...and the brass clips loose tension very quick.
    Mayby the clip slots have been worn out before breaking?
    Steel clips as in keihin origina dont loose tension and keihin needles have best precision
    Grüße Wolfgang
  8. #41033
    I am wondering if anyone has experienced having a carb needle snap? On my PWK. I've recently snapped two through a clip slot. Seems to happen after landing a jump. I am guessing it's either a worn slide or the body. But before I order another needle and a new slide. thought I would ask
    A throttle slide tends to tilt slightly backward-forward due to the inlet flow pulsations it is subjected to. And as you guessed, this tilting becomes worse as the slide and/or the carb body become worn out.
    In some throttle slide-needle combinations the needle fits so tightly in the slide that it cannot accommodate this tilting. The needle is then subjected to bending stresses and breaks at its weakest point: at one of the notches for the clip. The needle then remains in the throttle closed position while the slide is open, resulting in a lean mixture and a seizure.
    You could enlarge the needle bore in the slide, but I'd leave a short piece of the original narrow bore, so the needle is still centered but can swivel just the same.
  9. #41034
    2001, Honda, RS125
    Thank you for the replies.
    Genuine Keihin, Yamaha needle
    I've pulled the carb down. I can't see anything obvious.
    The needle in carb in the other CR appears to have the same amount of movement (front, back, side to side)
    Nothing money can't fix
  10. #41035
Name:	PJ Cut Off (1).jpg
ID:	356918 Click image for larger version.
Name:	PJ Cut Off (2).jpg
    1980 Suzuki GP125. Tried a power jet cut off on the old Suzuki. Used an air solenoid that was triggered at 11,500 rpm to collapse the fuel being drawn up the power jet tube.
    Idea worked pretty well, red line. It will be interesting to see if the extra drive is noticeable on the track this weekend.
  11. #41036
    11th May 2024 - 06:49
    United States, CA
    Another interesting bit to add...
    Attempting to do some further research and I tried to explicitly point google search AI at the kiwibiker.co.nz domain for a directed search and it returned this:
    "The search returned no results, likely due to the website being unreachable or inaccessible at this time, as indicated by previous search results suggesting connectivity issues with the domain. I am unable to access the content of the forum to verify if the specific terms you requested are present."
    Interesting, no?
  12. #41037
    United States, CA
    Tried a few different ways to get the google search API to reach Kiwibiker.co.nz, but apparently its innacessable, and apparently there are many other reports of innacessability to this domain from other users.
  13. #41038
    17th April 2022 - 13:57
    81' suzuki TS125 , 79'GP100 ,86'Yamy RXZ
    Malaysia
    doing good from my part here in Malaysia , they happened to me before, usually it just coverage problems. Especially on school holidays, connection will go very lame or not moving at all.
    Sent from my RMX1911 using Tapatalk
  14. #41039
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    This turned up on my FB feed this morning
    (PostalDave on ADVrider)
  15. #41040
    maybe Jan will add some translation ans text ad some more pis this is alli have
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4944
There are currently 148 users browsing this thread. (0 members and 148 guests)
