Page 2737 of 2773 FirstFirst ... 17372237263726872727273527362737273827392747 ... LastLast
Results 41,041 to 41,055 of 41592
  1. #41041
    19th June 2011 - 00:29
    maybe Jan will add some translation ans text ad some more pis thisis alli have
    I'm a Jan
    there is nothing technicaly interesting in the text, it is what we would call nowadays "clickbait" news : an article based on a photo that tell's you no more than what you can see in the picture.
    I presume those days they already had some crowdfunding that raised 16.000 gulden (1 gulden is slightly less than half an euro) and there is some little talk about the successes of 1968-69-70 and the preparation for the next season.
    what strikes me the most in the article is that at that time, aparently they didn't have an hydraulic press, for example to rebuilt cranks.
  2. #41042
    an article based on a photo that tells you no more than what you can see in the picture.
    Except: the picture is lying! Jan Thiel never intended to place the exhaust pipe above the engine but he did not want to give anything away at that stage, so for this photo he rotated the cylinder 180°, with the exhaust port on top.
  3. #41043
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    More from FB. The text accompanying it is obviously AI generated as this engine is described as a 350 twin (so I left that off)
    (PostalDave on ADVrider)
  4. #41044
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    I do some manual machining for my projects and I am wondering how were the outer radiuses on engine mounts made on this Jamathi engine?
    I have some ideas, but want to know how it was made back in a day?
  5. #41045
    Just as easy now as it was back then. The case supported thru the mounting hole in a 3 Jaw on a dividing head set vertically - with a long series cutter machining the whole surface in
    several passes.
  6. #41046
  7. #41047
    Quote Originally Posted by Peljhan View Post
    Cast them.
  8. #41048
    Cast them.
    Go all Bert Munro and use a file.
    note these conrods
ID:	356969Click image for larger version.
    later ones were caterpillar axels heated up power hammered into a fillet holes machined and roughed out but then finished with handtools
    i think he could knock out one in a weekend.
    Early ones were i think from ford truck axles.
  9. #41049
    11th May 2024 - 06:49
    United States, CA
    Unintended Post
  10. #41050
    United States, CA
    I am attempting to track down an ignition coil that may not exist, or may be quite rare.... (or it might be very common but no one really knows what it is...).
    I need CDI ignition coils for a project I am working on with ....really low.... inductance values.
    I know Wayne uses high(ish) inductane Crane Cams PS91 coils for the 2-into-1 IgniTech DC-CDI setup to pump up the amps driven into the spark kernel.
    But, I am playing with a different... expression... of the CDI circuit; and I am tuning for a faster rise time for the first high kV spike that "strikes the arc" (in addition to dumping some decent amps into the damped oscillation "tail"...)
    The expression of the circuit I am playing with drives a requirement for ...medium... turns ratio in like the 30-60:1 range and LOW inductance....
    Like uH scale primary and mH scale secondary. Anything over 1 Henry on the secondary is useless for my efforts...
    IgniTech is one of the only people on the planet that publish inductance numbers with their coils; unfortunately no secondary inductance reported for the IC-CDI-F; but with its 80 uH primary inductance it is in a class of coils that are so rare they might as well not even exist.
    Anyone of you know where I can find coil that are in the same "family" as the IgniTech IC-CDI-F, and by that I mean EXTREMELY low inductance?
    I am really tring to see if I can find anything confirmed lower inductance than the IC-CDI-F ....anywhere on the planet..... before I go have custom coils wound.
  11. #41051
    Quote Originally Posted by ApolloMotoMoto View Post
    Honda NS400\250 small type CDI coil MP 02, with primary 0,18 ohm, but secondary 4,1 k ohms.
    https://www.ebay.co.uk/itm/183162158...+400+coil&epid
    https://www.ebay.co.uk/itm/177335855...parms=amclksrc
  12. #41052
  13. #41053
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    26hp on pump gas is a bold claim! Seriously impressive if verified.
    As someone who has built their own dyno, I can make it say what ever I like and you don't know what bullshit other "calculations" the software is doing in the background either. It would be a great move for Alex to take it to a known and respected dyno to verify.
  14. #41054
    Seen your latest Video Glen, impressive. post it here to please.
  15. #41055
    Pukerua Bay
    Thanks Husa, link here for those interested.
    https://youtu.be/TDSJnMOpniE?si=lUE6hioRmveY-Dxy
    I'm looking forward to getting the engine back together and progressing the EFI. The first tests with the acceleration enleanment (think inverted acceleration enrichment table) is showing to be incredibly responsive.
    Cheers,
    Glen
There are currently 62 users browsing this thread. (0 members and 62 guests)
