Page 2741 of 2776 FirstFirst ... 17412241264126912731273927402741274227432751 ... LastLast
Results 41,101 to 41,115 of 41630
  1. #41101
    eek
    It sure as hell isnt the ignition system, but for the 10,000 th time, are you using a " proper " fine wire race plug that needs 1/2 the gap voltage to ionize.
    I am a pensioner so No, not been but I have one and will try it. The NGK R7376-10 is so damned expensive.
    First thing to look at is when the piston is at TDC, does the piston side cutaways expose a lump of Aux real estate , connecting the case to the Exhaust duct
    thru the side port ducts. That will run like shit.
Name:	Expose Ports.jpg
    Looking at the old Suzuki piston in the single exhaust cylinder it looks very possible that the side exhaust ports may be opening into the crankcase at TDC.
    I will have to take the good cylinder and piston off to check ........
    Cylinder off will be the first move.
  2. #41102
    The best place to buy the NGK plugs is JDM Planet - very reasonable shipping as well. But here is another idea I have been using for some time now.
    A NGK R0373A is the 10mm version of the R7376 , and is cheaper, plus it enables a minimal boss intrusion into the chamber when using a Toroidal dome
    to reduce the shadow or masking effect on the loop flow across the dome face.
    This idea was proven ( though sworn to secrecy ) via a World Champ winning big bore snowmobile project.
    The small resistor caps to suit are cheaper as well - I got a bunch from a British Bike parts place in ChCh I think.
    And yea, if your Aux are linked to the case - the jetting goes completely to shit.
    Same thing happened when I cut the skirts short on a " stock " World Champ Jetski with a 2: 1 pipe setup.
    The fuel curve went out the window completely, and it was only due to having pumper carbs with Aux venturi's that allowed the thing to be dialed back in.
    Made a shit ton of top end power, and won a title with zero chance of any tech seeing what had been done.
  3. #41103
    5th January 2013 - 13:23
    89 KX500
    USA
    Attachment 357296
    FireBall PS92N
    PS91 or PS92, 3 Ω or .82 Ω, which one is preferred?
  4. #41104
    4th April 2021 - 03:00
    1976, Simson S50
    About the dip in the powercurve: Maybe not thge spark is lost in this rpms, but AFR is crazy wrong? Looking at the curve it is about the rpm of maximum torque. Have you made any changes to your scavening or your diffusorcreation? Once your scavening is less stiff than before, or your main Depression pulse is much stronger so sthe scavening colapses as it hits, leaving a lot of burned gases inside, as the this maindepression pulse gets weaker scavening becomes stiff enough again and AFR gets back to normal.
    Had such phännomena by testing diffusor dimensions on non full race cylinders. Got good good curves with mild diff anngles, by increasing them torque an power rised, until a point of 18°+ main diff angle, curve startet at the same RPM with even higher torque, dipped than completly around max torque rpm and after this again went on with more torque than before, but in the region of the heavy main depression pulse great dip in the torque/powercurve, so to much Depression for the stiffness of this scavening.
  5. #41105
    The coil I used was a PS92N, built for Nascar CDI systems.
  6. #41106
    The man says:
    "Ive got a thing thats unique and new.To prove it I'll have the last laugh on you.Cause instead of one head I got two.And you know two heads are better than one."
    Just maybe it's true:
Name:	2 Heads.jpg
  7. #41107
    Kentastic, that was a line from a Joni song - she's older than me, but I would hope some much younger ladies would like that version of me, due to obvious physical enjoyment.
  8. #41108
  9. #41109
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Damn you Husberg! I now know what I will be doing this Xmas.
    I got a little weirded out when I check out the JDM Planet site it's a car parts site but they do have all types of NGK plugs for reasonable prices.
    . . . That shit's Nasty.
  10. #41110
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    I have removed the PJ in that carb by clamping s piece of square steel in the vise, hold the PJ end square on the bar, and tap the body directly next to the pressed in ball.
    The PJ tube and the ball easily came out doing this.
    Thank you!
    this worked. Now to find your post about putting the 0.2mm hole into tube to atomize the fuel coming out of the PJ
  11. #41111
    Thank you!
    Here's a mod I have done on many Yamaha racebikes with the electronic solenoid PJ - move the PJ to the top of the bellmouth and shorten the dump tube so it
    only protrudes around 15mm into the bore . I cut the tube end at 45* facing the reeds as this atomizes the fuel stream much better than the stock small hole does.
    The slide has to be well past the tube end for flow to begin , having a low down tube richens the fuel curve way too much in the midrange.
    The only other way is to use a truth table in the ecu to switch the flow depending upon TPS and rpm , but this is problematic to tune , causing jerking response on part throttle , mid corner.
    Cutting the tube short works on Lectrons as well , when having to use large PJ flow ( 50 + ) to get the top end tune correct without shagging the midrange jetting.
    Re the tiny bleed hole in the TZ powerjet tube - I always thought that this was a good idea to emulsify the fuel as it exited the dropper.
    But years ago i did some wet tests on the flowbench with a VCR video camera ( pretty trick shit stuff back then ).
    The Mikuni was a horror scene when played back slo mo,with huge "gobbs" of fuel exiting the main and powerjet.
    We then stuck on a Lectron - wow, lovely fine mist of fuel from the back of the flat needle face - and it flowed 12% more air - size for size with a venturi 2mm smaller behind the slide.
    Next is the current state of TeeZees GP125, here is the latest dyno curve digitised with 16% added to simulate crank power.
    Then there is the sim with an actual RS early model pipe.
    Then there is the new pipe of my design.
    Of most interest is that in this case the sim is giving slightly too much crank power - but the shape and peak point are all but perfect.
    I would be confident now that any change in the sim, would be reflected in reality on the dyno.
    In my experience the later Dynojets like a twin roller 168 with Eddy current load control to slow the acceleration rate down ,seem to read around 5 to 10% lower
    so this would put the sim and the dyno reading very close, as the shape is spot on now.
    This causes a problem with Ignitechs that are used with only a capacitor, as at startup the solenoid is powered up, dragging all the voltage out of the ECU, so I convert the ECU output
  12. #41112
    2001, Honda, RS125
    Thank you Husa,
    I gave up after an hour.
    Not sure where I recall the 0.2mm hole from however
  13. #41113
    First off, still nothing has been achieved to get Neels ( Vannick ) from being unblocked on here.
    C'mon guys this is getting ridiculous.
    The hole in the PJ dump tube idea came about when I first got access to Robert Taylors new portable dynojet.
    I wanted to make something similar to the newly available Dialajet , and Intelajet setups from Thunder Products that had a fixed fuel jet, but made it adjustable by bleeding a variable amount of air
    into a small volume sitting on top of the PJ tube.
    This operated just like a normal main or idle air corrector, bending the fuel curve such that as the bulk air flow increased, the fuel flow was gradually decreased, countering a 2T carbs
    natural tendency to run richer and richer - even though power is decreasing.
    The other advantage was that bleeding air into the PJ circuit also helped to reduce droplet size due to better emulsification.
    The short story was that I could never get that system to make any better power.
    But during the dyno session I looked at the PJ's on a late model TZ250 and it had a tiny hole in front of the PJ tube - doing that made better top end overev power.
    At the time I was also cutting the engine side of the emulsion tube shrouds off at an angle, making the top of the shroud a small radius facing the airflow, tapering down at an angle to no cut on
    the carb floor facing the engine.
    This was tested and proven during the dyno work at ZipKart on the Rotax 256.
    So at the last minute I filled the 0.2mm front hole in the PJ and cut its end off at 45* facing the engine - this was better everywhere.
  14. #41114
Name:	F81M 3Ex Ports (1).jpg
ID:	357473 Click image for larger version.
Name:	F81M 3Ex Ports (2).jpg
ID:	357474 Click image for larger version.
Name:	F81M 3Ex Ports (3).jpg
    Ok, at first glance. Uncovering the exhaust ports at TDC does not look like it is the issue.
    But a more careful look may be warranted as the cylinder could be slightly rotated and that may expose an edge of an exhaust boost port.
  15. #41115
    2001, Honda, RS125
    Thanks for the insight Wob!
    I'll get some more tubes made up and go for the 45 angle on the discharge
There are currently 115 users browsing this thread. (0 members and 115 guests)
