Page 2747 of 2773 FirstFirst ... 17472247264726972737274527462747274827492757 ... LastLast
Results 41,191 to 41,205 of 41593
  1. #41191
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Interesting stuff, husaberg. I just checked out EMOT's site and they don't appear to list this Hi-temp paint anymore. As a typically Buckeeter I was thinking more about my cooling mod's as relates to a existing set of crankcase's but if one had a blank design sheet, I too would go for a cooling jacket between the gearbox and the crankwell. I am starting to look at the cooling of the lower half of a Two Stroke like how boy racer's think of there intercooler's on there turbo engine's.
    . . . That shit's Nasty.
  2. #41192
    Swede Patrick mentioned he made his one mixing welding anti-splatter ceramic coat and paint
    This stuff is likely very close to what the emot was using not sure how it would cope with petrol
    https://insulationcoatings.com.au/th...ation-coating/
    https://www.u-buy.co.nz/product/8BKH...4tB1sdOpvTaFmo
    this can be purchased down to 1.5 lters
    https://www.carboline.com/products/p...4900-Aluminum/
    https://www.tegrastate.eu/p/inral-sp...-white-glossy/
    but I would get a can of ceramic splatter and a can of high temp exhaust paint and spray 50-50 into a lid and voila....
  3. #41193
    1971 suzuki T350R
    the best island
    It's good to know there are options. I would like to know wobbley's opinion on Hi-temp coatings. As he strikes me as a man who doesn't put up with things that look like they work but are more show than go.
  4. #41194
    I just checked out EMOT's site and they don't appear to list this Hi-temp paint anymore. As a typically Buckeeter I was thinking more about my cooling mods as relates to a existing set of crankcases but if one had a blank design sheet, I too would go for a cooling jacket between the gearbox and the crankwall.
    I don't know whether Martijn Stehouwer ever offered that Russian insulation varnish on his EMOT website. It's rather specialized stuff and most people who might be interested in it know Martijn personally, so there was no need to advertise it. There are bound to be other useful items that aren't listed on his website; it can't hurt to send an email.
    A cooling jacket between the crankcase and the gearbox is definitely a good idea. But it doesn't necessarily have to be a liquid jacket.
    Most plastics have poor heat conductivity, especially compared to aluminium. I once worked on a 125cc Rotax kart engine, which was actually a 250cc engine into which Rotax had placed a 125 cc crankshaft. There was plenty of space around the crankshaft in the crankcase, which I filled with a plastic ring that I had cut from a 4-inch water pipe.
    It worked great. Not because of the reduction in crankcase volume (which was actually more favorable for power than the small crankcase volumes of the “real” 125 cc engines of the time), but because it significantly reduced contact between the fuel/air mixture and the hot crankcase walls.
Name:	crankcase heat shield.jpg
  5. #41195
    1971 suzuki T350R
    the best island
    Attachment 357659Click image for larger version.
    Thanks for the idea about the plastic pipe as a heat gap, Frits. There are larger cc versions of the engine I am looking at using, which get the cc's by longer stroke's which should mean more room in the crankwell for a larger crankshaft so hopefully making room for the shorter (and hopefully smaller diameter) stroke crank I want to use and the plastic pipe heat gap.
    P.S. I may well send Martijn Stehouwer a email about the paint but I will wait until the new year.
  6. #41196
    Frits friend Roland Holzner when he designed the Modena KZ engine, engineered a " plastic " insert that completely lined the intake surfaces from the reed block mount face , all
    the way thru the case up to the Transfer duct entries.
    Thus the inducted A/F never actually contacted the hotter metal, except down the sides of the crank.
    It somehow got through the CIK tech inspection of the 50 units for homologation, but quickly the CIK banned it from any future engines.
    EDIT - easily replicated using 3D printed fuel resistant polymers.
    The ceramic coatings I have used were developed to prevent heat from migrating through to the metal substrate - I have not had a look or had any experience with coatings that do the reverse
    ie ,preventing heat from migrating from the substrate out to the coatings surface - mind you, the coating used on the inside of 4T headers is so effective the pipes are only warm to the touch on the outside at idle.
  7. #41197
    I loved the fact that Gnani , in the second video, demonstrated his own home made Timken/Falex 2T oil testing machine.
    This method of oil test has been completely rubbished by the self proclaimed 4T lubrication experts - Lake Speed Jnr being the worst and most " loud mouth Yank " annoying.
    But in the dyno testing I did of Synthetic Vs Castor and oil mix ratio's, the piston skirt wear rate and form, was absolutely analogous between reality and the machines results.
  8. #41198
    If our new water cooled crankcase idea springs leaks and is too difficult we will try the plastic liner idea.
    We are about to test a 50cc motor that has water circulating through the casting cavities around the crankcase.
  9. #41199
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    This method of oil test has been completely rubbished by the self proclaimed 4T lubrication experts - Lake Speed Jnr being the loudest and most " loud mouth Yank " annoying.
    Many years ago (like 30-40 years) Dirt Bike magazine did a big dyno shootout of various oils, using a DT1 Yamaha, which got a fresh piston and rings after each test. IIRC the autolube was disconnected and they ran premix. Castrol R came out near or on top.
    (PostalDave on ADVrider)
  10. #41200
    1971 suzuki T350R
    the best island
    Do you mean you are going to run coolant throu the cavities that attach the engine mounts that are normally empty air? if not, what do you mean? I abmit I do not follow what you mean with this picture.
  11. #41201
    10th April 2013 - 09:59
    Honda NSR 50
    Netherlands
  12. #41202
    Do you mean you are going to run coolant through the cavities that attach the engine mounts that are normally empty air?
    Yes, trying to see if we can run coolant through casting cavities that are normal empty air.
  13. #41203
    1971 suzuki T350R
    the best island
    OK, Cool, Good luck with that, Don't get me wrong I think that it may be possible. It would take lot and I mean alot of plumbing to get that to work. I would be very interested to see how you get on with this.
  14. #41204
    I have high hopes for the idea. My biggest concern is the very narrow sealing surfaces, water tightness could be a problem.
  15. #41205
    Yamaha and others use a fix that is awesome I have seen on a modern "450 oiler "to use but likely a little time consuming to machine.
    That said they don't rip don't leak and are reliable and only need matching /inserting once.
Name:	Screenshot 2025-12-31 11.02.44 AM.png
ID:	357664Click image for larger version.
Name:	Screenshot 2025-12-31 11.03.16 AM.png
ID:	357665Click image for larger version.
Name:	Screenshot 2025-12-31 11.08.52 AM.png
    I am pretty sure if you had a mini cnc and a scan of the gasket ai could maybe get it close. or at least close enough to run a simulation of the tool path with a pen.
    Whilst I don't currently have a NSR500 on the bench, I can see the witness marks as well as the grooves in these pictures
ID:	357667Click image for larger version.
ID:	357669Click image for larger version.
    Team ESE is practically NZ's version of HRC so i cant see them not having the technical capacity....
