Page 2749 of 2774 FirstFirst ... 17492249264926992739274727482749275027512759 ... LastLast
Results 41,221 to 41,235 of 41608
  1. #41221
    F4 and F5 Miniature Road Racing. (Buckets)
    MNZ Rules. (Motorcycling New Zealand)
    Appendix W - Minature Road Race https://mnz.co.nz/wp-content/uploads...Appendix-W.pdf
    Appendix A - Championship classes https://mnz.co.nz/wp-content/uploads...Appendix-A.pdf
    Appendix X - Technical https://mnz.co.nz/wp-content/uploads...l-Appendix.pdf
    Fuel is covered in Technical 12 and Nitro in Technical 12e. So Pump gas and/or Av gas for F4 F5 and not Ethanol, Methanol or Nitro. Total party poopers.
    Appendix D - Fuel specifications https://mnz.co.nz/wp-content/uploads...Appendix-D.pdf
    I don't think i will ever understand the MNZ thought process.
    they have classic classes but change the capacity to be outside of what was in the rules in those eras.
    like allowing GP 250cc 2 stokes in F3 when the periods only allowed 125cc.
    For f1 there is no allowance for 4t twins vs 4t 4's so its 1300cc 4's against 1300cc twins when thse era rules were 750cc 4 's vs 1000 twins
  2. #41222
    Rob, where does it say that ethanol is not allowed for buckets?
  3. #41223
    Good question, I may be wrong but I thought the specs (Appendix D) specified the amount of Ethanol permitted in petrol. So Ethanol at 100% is not permitted. Best fact check me about this.
    Persionaly I would be happy with no fuel restrictions at all for Buckets.
  4. #41224
    Pump gas max 10% Ethanol is specified.
  5. #41225
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    When I read my copy of Jan Thiel's Book he hinted it was hard to work with the Italilans. But I now understand he was playing it down.
    I ALWAYS worked very well with the Italians, except rumi, who was a real piece of SHIT..... and the most dishonest person I ever met..........
  6. #41226
    No, rules say the maxim amount of ethanol in unleaded petrol is 10%.
    It is there for allowed to run 85% ethanol in 15% LEADED petrol.
    Ethanol is not banned outright, as I was led to believe, although methanol is.
  7. #41227
    Persionaly I would be happy with no fuel restrictions at all for Buckes.
    Personally I think the less restrictions the better. But what if someone discovers a fuel that delivers 5% more power and costs 500% more than regular petrol? In the end everybody who does not want to be left behind has the same power again but now everybody has to pay five times the price. A fuel rule can protect you from situations like this.
    Having said that, I am a huge fan of E85: more power than just about every racing gasoline I know of and at the same time easier on the engine and cheaper than regular petrol.
    Too bad you seem to have to mix it with leaded fuel, which I detest.
  8. #41228
    25th August 2022 - 19:08
    RS125
    Spain
    Yes, the Modena KK1 is very interesting. But it's only used on the reed valve and intake ports, not around the crankshaft. I always wonder if it would provide more power, at least noticeably.
    Frits friend Roland Holzner when he designed the Modena KZ engine, engineered a " plastic " insert that completely lined the intake surfaces from the reed block mount face , all
    the way thru the case up to the Transfer duct entries.
    Thus the inducted A/F never actually contacted the hotter metal, except down the sides of the crank.
    It somehow got through the CIK tech inspection of the 50 units for homologation, but quickly the CIK banned it from any future engines.
    EDIT - easily replicated using 3D printed fuel resistant polymers.
    The ceramic coatings I have used were developed to prevent heat from migrating through to the metal substrate - I have not had a look or had any experience with coatings that do the reverse
    ie ,preventing heat from migrating from the substrate out to the coatings surface - mind you, the coating used on the inside of 4T headers is so effective the pipes are only warm to the touch on the outside at idle.
  9. #41229
    I also detest leaded fuel.
    Unfortunately this is how the rules are written, the wording will be changed presently I'm sure.
    I ask, when the fuel rules are changed, let E85 be allowed for 100 fourstroke supercharged, like it used to be.
    Continue the ban on methanol and I'd be all for a ban on leaded fuel also, outright.
  10. #41230
    Yes, absolutely agree about E85. Apart more power, you can adjust bike all day in exhaust fumes and still feel good.
    More power not only with a two strokes. I've tried E85 on 4t Yamaha R6, VFR 750 (RC24 RC36), VFR 800 and Suzuki GSX 400 Bandit. With the right adjustments all goes faster.
    Yamaha R6 2003 original injectors for gasoline has 4 holes, but with E85 real difference in power comes with 12 holes injectors from Mitsubishi Lancer 2. (shape is the same like on R6 2003). Injectors with 6 and 8 holes from 1300cc bikes still too lean.
    But, as many time was discuses, E85 does not mix with fully synthetic racing oils. I haven't found a single that will mix without separation. Add photo with just few of them. The worst was autolube oil, separate after few minutes.
    All castor base oils I've tried mixed very well with E85. The only exception Castrol A747, separation not as clear like with the fully synthetic, but it seems that 747 synthetic additives insoluble in ethanol.
    And vice versa, only few castor base oils mix with usual gasoline.
  11. #41231
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    My Apologies, The dangers of trying to read between the lines.
    . . . That shit's Nasty.
  12. #41232
    1971 suzuki T350R
    the best island
    methanol
    I have ever had anything to do with E85, so don't have a opinion on it. But the little I have had to do with methanol makes me think for practical reasons at a track, that it would be best to keep methanol out of bucket racing.
  13. #41233
    A link to everything you wanted to know about the Aprilia RSA 125 engine. Words with Pictures:- https://forums.kartpulse.com/t/peak-...-rsa125/9958/3
  14. #41234
    My design package, plus some wood from the wood shed. Best bit is when it's complete, its cast into a usable alloy component. At minimal cost.
ID:	357687   Click image for larger version.
  15. #41235
    6th January 2026 - 18:40
    1998 Honda NSR
    The Triangle
    Good Day all,
    I hope you don't mind my jumping in. I used to skim through this forum and Pit Lane maybe 10+ years ago for 2 stroke related learning. About a year ago I started designing on CAD a Honda 2 stroke cylinder which ended up having an experienced and talented 2T fiend join in to help produce something quite sweet. We had a few cast, he machined, had plated and recently he has started testing.
    It the time January a year ago when I mentioned doing the cylinder design he suggested doing one for the Yamaha v 80 type engine which is very popular where I am from. So about 4 - 5 months ago I began designing a cylinder around the 3 duct to make a 4 transfer port / 3 boost port type cylinder with a bridged exhaust. As these engines have a massive C port and duct normally I wanted to take advantage of this port rather than stretch the B ports around dramatically towards the C port.
    The goal is not to make a firebreathing GP cyl (lol) but to have a much higher performance cyl than was is currently used with the ability to work with the "chopped out" non expansion chamber pipes many use but also workable with the guys that use expansion chambers as street going bikes. I have given the ext port a generous top radius, curving about 3mm from top to edges from memory to ensure for a wide power curve that works with the 3 speed gearboxes. The timing is currently at 130 / 190. I have been using Frits axial angle formula to begin setting the A / B and C ports
    The one aspect of the 3 boost ports which I can call the pair of C ports and centerline D port is the effect of changing the pair of C ports axial angles. I set them to converge to mimic the hook typically on the B ports. I have looked at Bidalot cylinders and they look to keep the axial angle similar to the B ports, where Voca, DEA and others have the angles of the "C" ports angled close or the same as the D port. Ultimately I'll want porting that encourages a broader port curve and my gut feeling is to have the ported angled upwards towards the head rather than across the piston.
    Cheers
