Page 2759 of 2773 FirstFirst ... 17592259265927092749275727582759276027612769 ... LastLast
Results 41,371 to 41,385 of 41591
  1. #41371
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    one of the very few reasons an Ignitech will not produce accurate ignition curves , is EMI. You MUST use resistor plugs and caps. The other issue is the proximity of the trigger or any other input/output
    wiring to the coil charge wires.
    They are on opposite ends of the loom plug for a reason.
    I always run the coil wires on one side of the bike ( or whatever ) frame, and the triggers etc on the other side.
    These simple things remove 99% of issues.
    Also depin any unused loom wires, DONT coil them up to operate as very good antennae.
    Thanks, Once again for pointing this out, I was just today moving a bike with a ignitech mounted on it, which I have been having ignition problems with for a while and I checked where the unshielded pick up coil wires are running. It is within 5mm of the Ignition coil. I think I now know why I was having problems.
    . . . That shit's Nasty.
  2. #41372
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    The RSW Vs the RSA is not even a close apples for apples comparison regarding the physical layout and many other detail changes - I have serious difficulties attributing
    the RSA power increase to simply 25cc of CCR = going from 1.238 to 1.227 = only 8/10ths of 1 % change.
    That % would be 0.4 Hp in 54, sure, absolutely worth doing, along with at least 5 other changes with far more significance.
    But the RSA had its own downsides - the rear valves gear drive, and the front mounted bent pipe that also negatively affected the bikes weight balance and thus its handling.
    Jan has said that given the opportunity to do it again, he would far rather have a valve on each side, not one on the back.
    I did an ENGMOT-simulation with a disc on each side: no good.
    The idea for the RSA came from the flowbench, I saw how much the conrod obstructed the flow.
    The result somewhat disappointed me, but I still had some ideas about the internal flow in the crankcase.
    But then I retired, and development went the wrong way.
    I am still convinced that 60HP would have been possible. but instead a 'Honda-type' exhaust port was tried...........
    How STUPID can you be: 3HP less............
    I still don't understand this, after all the problems we had at DERBI, where ALL exhaust bridges broke...
    We also saw that a bent pipe lost some power.
    In the design phase I proposed having an insert in the crankcase, between cylinder and crankshaft so that experiments with in-crankcase flow, turning vanes and case-volume would be easy and quick, I am still regretting this was not done: it was the only way to reach 60HP... as the cylinder had reached its limit.....
  3. #41373
    27th May 2019 - 05:49
    Puch
    Winnland
    Quote Originally Posted by Wobbly
    From having done many racebike sims and then having used a DynoJet to to test the project built directly off the sim result, the average loss from crank power, down to the roller and thus including the built in fudge factor - is close to 14%.
    I have to ask it. Including fudge factor: Dynojet reads 100 hp, then you put additional factor of 1.14 wich means 114hp from engine? And if we get fudge off, there is 80 hp real power in dyno roll?
  4. #41374
    Jan , I have not looked into the twin rotary valve concept, and I should not assume anything about how Neels modelled this, but being a single dimensional model
    I have doubts that the flow regime into the case itself can be replicated correctly ( whatever that may be ).
    This is also affected by the fact that Neels has very recently updated the code to more accurately replicate the inlet duct extension, past the valve, and this has proved to give much better results.
    Re the DynoJet numbers, all I can report is what my results were from many sims, and subsequent rear wheel Hp numbers.
    So yes, I built a 485cc Banshee based racebike that made 102 RWHP, the sim said it was 58 Crank per cylinder.
    Another 3YL/4DP TZ250 made 80 Hp on a Dynojet, the sim said 46/cylinder - so I can be pretty damn sure that when I finally fit the modified 3XV cylinders and new pipes where the sim says 55Hp/cylinder
    that bike will read at around 95RWHP.
  5. #41375
    Wasn't there multiple cnc set of case done not long after the the 2t were booted out of GP that took Aprilia cylinders
    I can't recall what it was called but pretty sure it was Dutch and i have some pics...
    edit
    Dolf van der wood
    https://www.kiwibiker.co.nz/forums/a...hmentid=304664
    https://www.kiwibiker.co.nz/forums/a...7&d=1413067355
  6. #41376
    Wasn't there multiple cnc set of case done not long after the the 2t were booted out of GP that took Aprilia cylinders. I can't recall what it was called but pretty sure it was Dutch and i have some pics...
    edit Dolf van der wood
    Those were the twin-disk Aprilia cases, designed by my friend Dolph van der Woude, who also gave Aprilia their first 250cc GP win and who also designed the Aprilia 250cc V-twin, and produced by Thijs Hessels.
Name:	Hessels twin-disk 01.jpg
ID:	357825Click image for larger version.
Name:	Hessels twin-disk 00.jpg
ID:	357826Click image for larger version.
Name:	Hessels twin-disk 04.jpg
  7. #41377
    1971 suzuki T350R
    the best island
    If there is a flat disc cover at each end of the crankcase. How does the primary drive work? and of cause, do you know wither it was ever finished and ran?
  8. #41378
    To the best of my knowledge it was never finished because the whole purpose was to built a better 125cc road racing engine. And this endeavour was killed off by the FIM decision to substitute the 125cc class with 250cc (cheaper, cleaner and more reliable, haha!) foulstrokes.
    I do not feel at liberty to answer your other questions, except: ask yourself how you would drive the twin(!) balance shafts.
  9. #41379
    1971 suzuki T350R
    the best island
    I am wondering if that boss of material above the gearbox housing and behind the flange the cylinder would mount on, Has something to do with it. A row of thin gears or chain down one side maybe? After that I am out of ideas.
    I am thinking two sightly smaller carbs that equals a one large one would generate better carburation at low to midway slide openings maybe?
  10. #41380
    https://www.kiwibiker.co.nz/forums/s...post1130312865
    Jan had mentioned a long time ago he was plaining on starting with twin 34mm
    https://www.kiwibiker.co.nz/forums/s...post1131030731
    In regards to the primary here is how the exactweld did it
    https://www.kiwibiker.co.nz/forums/s...post1130703351
  11. #41381
    1971 suzuki T350R
    the best island
    I must say I am very interested in the twin disc set up as LangTuning are working on a twin intake (using reeds) right behind the A and B ports on each side. I am very keen to know how it performs. It may the start of something very interestly. Who knows? That seems to be the way with 2 strokes if one gos to far out side the box of currant knowledge. One just has to build it and see.
  12. #41382
    Here you go DP. The technical rules of Langtunings's 'TunerBattle 2026' specified 'inlet on the cylinder' , otherwise the reed valves would have found a place on the crankcase. The engine has a bore and stroke of 57mm x 56mm and produces 50 rear wheel-HP at 11600 rpm.
Name:	Kevin Lorenz Tuba 2026-01.png
    Here is designer Kevin Lorenz explaining the how and why: https://www.youtube.com/watch?v=5bm7xMG0dSs
Name:	Langtuning Wintertreffen 2026-01-24-02.jpg
    There's another video in the making showing the cylinder preparation. I will post it here as soon as it's ready.
    Here you go:
    https://www.youtube.com/watch?v=EoteWuwdAUw
  13. #41383
    1971 suzuki T350R
    the best island
    The Germans are interesting,They are either must stick to the rules with no end to it or when they do leave the reservation things get interesting real fast
  14. #41384
    1971 suzuki T350R
    the best island
    After watching that first video, some thoughts, The cylinder has first class exhaust ports and Transfer ports design. I take it the rules mean it must have Air cooling? otherwise if it had water cooling I think it would be even better.
  15. #41385
    Is there an easy way to translate a whole .docx, maybe someone can post the 2026 Tunerbattle on here
There are currently 135 users browsing this thread. (1 members and 134 guests)
  1. Wos
