Page 2761 of 2774 FirstFirst ... 17612261266127112751275927602761276227632771 ... LastLast
Results 41,401 to 41,415 of 41608
  1. #41401
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    Thank you for the explanation. It matches what I am seeing. My customer sent me his datalog Which seemed strange to me because there was random downward spikes in the rpm logs which mostly occurred late in the races, or at the end of a long straightaway. His wash was non existent but the transfer windows/ducts looked somewhat wet. The plugs look like they have flecks of aluminum on them, but it must be microscopic damage because the pistons look undamaged, unless the flecks are coming from the ring grove ( which I have not asked for a photo of ) where it is getting pounded by the ring. Click image for larger version.
ID:	357855Click image for larger version.
  2. #41402
    A normal ring has a bright shiny bottom surface from being pressed down and moved back and forth into the Exhaust port.
    That ring has serious deto, the bottom ring groove face will be torn up.
    The EGT dropping at the end of the straights is a sure and obvious sign deto is occurring.
    Kart datalog gauges have warning lights to show just under the max achievable EGT value and prevent damage.
  3. #41403
    23rd July 2017 - 21:59
    n/a
    canada
    Question for Wayne. You already said that on a 2-cylinder engine with a Y-pipe, you cut the piston skirt on the exhaust side so that the exhaust port remains slightly open when the piston is at top dead center. Is this a fragile area? If I run tests on the dyno, can I go to 1mm per step? How many millimeters did you leave the port open when you were finished? Do you remember, to give me an idea please?
    Thank you .
  4. #41404
    The initial engine was a " stock " SeaDoo 951, this had the skirt 3mm above the port floor.
    This created havoc with the tuning of the pumpers, that were already severely reverse jetted at about 2 1/2 B - 1/4 T.
    That wasnt possible with the cut skirts, and the needles ended up near closer together.
    It was near on 4 boat lengths faster to the first buoy, and won a title at Havasu.
    Another cheat on that engine was a clear ceramic coating on the piston crown and combustion chamber, inboard of the squish area.
    The tech officer commented that it was no wonder we had won so easily, as the squish was shinny metal, and inside that was real burnt black - and no one else had that clearly defined pattern.
    I said " yea I tuned it near death ", which was close to the truth.
    Later we did a stroked/big bore open class SeaDoo at 1140cc with twin pipes and fuel injection - the cut skirts did not work in that scenario.
  5. #41405
    That's what Epstein said
  6. #41406
    Reminds me of a visit to the doctor where I told him my anus was painful - he said where exactly, my reply was around the entrance.
    He said as long as you keep calling it an entrance , it will keep on being painful.
  7. #41407
    Almost wet myself larfing!
  8. #41408
    For more information there is this unwanted but apparently thoughtful Xmas gift. Free to anyone wanting to bone up on the subject. Very in depth.
  9. #41409
    n/a
    canada
    It couldn't be clearer, thank you Wayne.
  10. #41410
    23rd March 2015 - 21:24
    Conti RX356 V3
    Several racebikes I look after already have the Mychron 5 2T with expansion to run 2X EGT - so I am looking for the most cost effective way of getting suspension data into
    that package.
    Bit older but might be still of interest - just saw that you can expand the Mychron 5 and 6 with an ACC3 - Analog Can Converter which runs @ 1000 Hz, not limited by the 25 Hz of the Mychron.
    https://www.aim-sportline.com/en/pro...tion.htm#start
    Can purchased for all sorts of inputs, e.g. 2 x TC and 2 x Analog 5V for suspension or 4 x Analog 5V.
  11. #41411
    In reality, how useful would Engmod2 be for optimizing my AG100, twin port?
    Or my new disc valve engine with the VVT sliding gib. Also twin port.
  12. #41412
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    As soon as you have activated your copy I will send you a pack file of the Greeves Oulton with two exhaust ports and exhaust pipes. So no problem with the first part. I am working on the second and third parts - variable disk valve timing and inlets on both sides. It can already do a 3 cylinder Volvo Penta (designed by Konig) that has two rotary inlets on the center cylinder.
  13. #41413
    How great is that?! ^^^
    I would suggest that even without the custom development, I'd expect a model with the same port areas etc. would give a good idea of the balance to strike between transfer and exhaust area etc.
    I'm not sure if that makes sense or not, basically I think that if you were to make something as close as possible in the sim it is still likely to give a good idea on where to focus development efforts.
    I think.
  14. #41414
    Welcome to the real world finally Neil.
    At the moment you have absolutely no idea of the most important relationship in the whole design, that being the Blowdown and Transfer STA for the required Hp at the required rpm.
    Exhaust port STA is pretty much irrelevant, except when using the available radio button to calculate the estimated duct exit area of 75% of the Exhaust Effective Area ( for a Triple or T port ).
    That is designed for high bmep engines, for single port lower bmep scenario's it uses 90% exit area ( maybe something for Neels to check on in the old twin port code ).
    The current paper on this technology is in the Files section on the EngMod Facebook site, but I am updating that geometry at the moment as the NDA on all that stuff has now expired.
    TM has been sold to an Italian finance ( read Mafia ) group, and they now wont release in house CAD files to me for development work.
    Even with a new NDA, so they can go to hell ( I will use much stronger language than that when I finally tell them ).
  15. #41415
    Let me know if I can be of service Wayne; I still have a fair vocabulary of real-world Italian. I also know some of the faces behind the history; they invited me to Brolo a couple of times until I said thanks but no thanks.
There are currently 70 users browsing this thread. (0 members and 70 guests)
