Page 2766 of 2774 FirstFirst ... 1766226626662716275627642765276627672768 ... LastLast
Results 41,476 to 41,490 of 41606
  1. #41476
  2. #41477
    15th May 2017 - 14:26
    2002 Aprlia RS125
    F5, the ConcoursdeDungHeap was for my Kawasaki 100, the one that had the disc valve and reed valve setup, I belive.
    The current 'bucket' , single cylinder, is loosely based on a TF, but re cast cases to accept a rear disc, balance shaft, twin exhausts. The gearbox is TF but I've made new gears to close up the ratios, water cooled cases running 98 with 10% ethanol. Sliding gib disc case, 'special' vairable pipes, both length and cone angle.
    A semi serious attempt, actually it's a 125cc for Vinduro but I've been asked about a 100cc version. Easy enough with wooden patterns, cylinder will be the bugger as it will have to be special for 100cc , no compromise square bore and stroke.
    Ive been emboldened by the success I've had with this AG100 (125) Vinduro Hustler, picture for reference, in three years its finished every event its been entered in, astounding given my reputation, this definitely wouldn't win ConcoursdeDungHeap.
    Did you wire cut the gears or did you have a set of hobs?
  3. #41478
    As luck would have it, I have a gear hobb.
    Also a number of form cutters, for making powervalve components.
ID:	357971   Click image for larger version.
ID:	357972   Click image for larger version.
  4. #41479
    Hmm. Did you make pv parts for Wobbly a ways back? I have some in my CPI Cheetah 496.
  5. #41480
    Years ago we made some parts.
    I like his curved valve system and might well use it in my next cylinder.
    Those powervalve parts in the picture are out of my Autogyro engine.
  6. #41481
    Ha. I had some early TSS assemblys, but flat ones. Had a feeling they were made almost one off before the curved ones. . When you were in my garage it would have been to the right of us. Didn't realise you'd made them. Also the bypass thermostat i think you made. So thank you.
  7. #41482
    2002 Aprlia RS125
    How did you cut the spline on the inside?
  8. #41483
    Slotting machine and rotary table.
    I also have an old shaper, done them on that in the past.
  9. #41484
    The flat blade setup used the slot as was CNC cut by CPI.
    The cylinders and curved blades Neil did were my design and were two stage, way better power everywhere up the front side.
    And yes the 100 bypass thermostats were my and Neils work as well.
    I have one left I use on the dyno.
  10. #41485
    I probably still have the programmes for those.
  11. #41486
    Something else ....
  12. #41487
    13th April 2022 - 19:08
    None
    Florence, Italy
    Piston port
    hello guys,
    do anyone has a hint on where to find useful discussions on piston ported high-output engines in this forum?
    the search button is a little bit of a nightmare for me...
    i have some designs in the works and i'd love to know more about that
    thx
  13. #41488
    Quote Originally Posted by Gradella23 View Post
    There are a lot of pictures on this thread you can browse:-
Name:	Screenshot (1274).png
    Also, maybe check out pages 1000 & 2000 They have collections of links that may be relevant.
  14. #41489
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    hello guys,
    thx
    The pinnacle of piston controled inlets was probably the yamaha tz 125,250,350, up until 1981 or so. There is quite some info on the internet.
    Also here is what Graham Bell thaught were relevant numbers:
Name:	Screenshot 2026-04-15 at 12-12-22 Graham-Bell-Two-Stroke-Performance-Tuning.pdf.png
ID:	357975   Click image for larger version.
Name:	Screenshot 2026-04-15 at 12-01-06 Graham-Bell-Two-Stroke-Performance-Tuning.pdf.png
  15. #41490
    None
    Florence, Italy
    thanks andreas, i'll take a look to the yamaha engines.
There are currently 57 users browsing this thread. (0 members and 57 guests)
