Page 2767 of 2775 FirstFirst ... 1767226726672717275727652766276727682769 ... LastLast
Results 41,491 to 41,505 of 41622
  1. #41491
    Quote Originally Posted by Gradella23 View Post
    hello guys,
    do anyone has a hint on where to find useful discussions on piston ported high-output engines in this forum?
    the search button is a little bit of a nightmare for me...
    i have some designs in the works and i'd love to know more about that
    thx
    Don't know about discussions, but Blair's recommendations worked well for me. In the end, the guideline for a piston ported high output engine would look something like this:
    • effective area at the bore 1.05-1.15 (from memory) times the carburetor area
    • inlet as straight (in all directions) and as short as possible
    • start with low inlet timing (e.g. 80/80 on a high performance engine)
    -> get the piston with the longest and widest skirt on the inlet side you can get, which will allow you to have a bridged inlet port which makes things (increasing area whilst keeping timing down and increasing unobstructed (by the piston) opening timing) much easier.
    -> having a boost port is overrated and piston ported engines are much less noisy than reed engines.
    -> if inlet length and inlet timing are off (e.g. too long in both cases), this can mess up your carburation and increase off powerband blowback in a huge manner, also killing all the power before the pipe comes on. (80/80 and carb directly at the cylinder was a quite safe starting point for me)
    -> expect to have to run very small main jet sizes compared to reed engines, as there will be no blowback when everything is in tune.
  2. #41492
    ...having a boost port is overrated and piston ported engines are much less noisy than reed engines.
    Haufen, I agree with most of the above, but why would an engine that does not suffer from blow-back, require a smaller main jet?
  3. #41493
    Very generalized idea's I dont agree with - a TZ250 that has a 20mm phenolic spacer between the 34mm carb and the cylinder will not run AT ALL without the spacer, impossible to tune.
    A TZ 350G - 6 port with the 38mm long body carb, makes around + 2 - 4 Hp everywhere if you cut the bellmouth extension off and add a 20mm carb spacer, comes on earlier, revs on harder, and easier to tune.
    Means you can cut 1.5mm off the piston inlet timing edge, that would normally overkill the mid power.
    If you then cut the small cylinder extension off on an angle such that there is no step at the top, to lift the carb angle, and port the inlet like a G model TZ250, where the port roof at the bore is just above the ring, with
    a tongue hanging down to support the ring gap, this adds another couple of Hp up top.
    An engine like this won dozens of pre 82 Junior races with a 70 year old pedalling it.
  4. #41494
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    What noise are you talking about? Inlet, mechanical or exhaust?
    This comment combined with Wobbly's on the inlet length: Inlet tuning on a piston port inlet is critical and it is very sensitive, it is a good idea to experiment with the length by using a spacer between the cylinder and the carburetor, not after the carb mouth!
    The inlet should end at the end of the bell mouth, the extra piece that Wobbly cut off screws up the pulse shape as it is partially reflected by the bell mouth and partially reflected by the end of the extension. This smears the wave shape and lowers its amplitude.
    If you have to run an airbox, either have the bell mouth end in the box or use a big connecting tube between the bell mouth and the box, at least twice the outer diameter of the bell mouth.
  5. #41495
    To frame the post above, here's what I think I understood Gradella is planning and how I derived my recommendations:
    I assume he is building a piston ported engine from scatch. Without further details, the recommendations turn out pretty general, of course. But what I think he was after and what my intention was, was to provide him with a robust baseline that works right from the start and from where he can then start optimising. I imagine having to fix a system you have no experience with, first, can be quite frustrating.
    I once converted a cylinder reed engine to piston ported. For this, I used the dyno calibrated EngMod model of the reed engine (large vforce reed) and converted it to piston ported in the sim (Gradella, if you don't already use EngMod, this would be a good time to start. And if you already use it, you could post the file or send it to me and / or some of the members if you would like feedback). This is basically where the recommendations above were derived and which worked perfectly in reality.
    To get the engine to rev on the dyno, however, I first had to deal with some real world problems, the sim did not tell me (at least not directly). The jetting.
    I started out with the carburetion from the reed engine, which was a 155 main on a 38mm carb. Only to find that the engine did not rev past 8k or so. I was just about to check and change the ignition before I decided to try an even smaller main jet, first. And step by step I moved to smaller and smaller jets and found the new ideal jet size to be 132, on the same 38mm carb that is.
    I did not analyse the reason for the small main jet to the very detail, but the reed engine had some visible blowback, whereas on the piston ported there was nothing at all (with this inlet length). Also, EngMod gave very good BSFC numbers for the piston ported engine, below 400 g/kWh if i remember correctly. What I was most interested in at that time was: "is this a safe jet size to run?" and both observations (end EGT numbers) confirmed me that it was.
    Any reasons and explanations as to where the root cause for the small main jet is from the members here are welcome. What I wanted to tell Gradella with this was: once you've got it running, don't be afraid to lean it down, especially if you happen to have experience jetting a comparable engine with a reed valve.
    Do you happen to have pictures of the modifications and / or the engines? It's hard for me to put the words into a bigger context without knowing the engines or inlet shapes etc. On this TZ the carbs seem to be placed pretty close to the bore, which looks like a good starting point to me. https://motorrad-fuchs.com/en/single...,TZ_250_C.html . With "short and straight" I wanted to provide a baseline in the recommendations, it's easier to add a couple of mm in most cases. If you need 2x 90deg bends and the minimum length is 15cm before the carb can even start then this is not a partucilarly great prerequisite to start with.
    In one of your other examples you made the port bigger and tilted the carb also reducing effective intake length all at the same time if I understood correctly. Were the changes made one after another (not always possible, of course)? Maybe the size and the length were positive and the tilting negative, power wise?
    What would be your recommendations for a piston port intake if starting from a blank sheet of paper?
    Compared to the reed setup, it felt like inlet noise was completely gone and the engine was a lot quieter. I even had people come over and ask me what I had done to make the (race only) engine so quiet on several occasions (often followed by kneeling down, nose and eye right up to the carb bellmouth, opening the throttle and then saying things like "I can see your rod, amazing").
  6. #41496
    expect to have to run very small main jet sizes compared to reed engines, as there will be no blowback when everything is in tune......
    If blow-back occurs, mixture that has already picked up fuel during its first passing through the carb, gets a second helping on its way back out, and a third helping when it is finally sucked in. By then it carries about three times the amount of fuel it was suppose to receive. So engines displaying blow-back get more fuel from a given main jet than engines with no blow-back. That is why your remark made me wonder.
    I also wonder why the reed engine displayed visible blow-back. Tired reeds maybe?
    One reason that piston port induction can live with small main jets is the stronger suction pulse through the carb, compared with a reed inlet system.
    Compared to the reed setup, it felt like inlet noise was completely gone and the engine was a lot quieter. I even had people kneeling down, opening the throttle and then saying things like "I can see your rod, amazing").
    Yup, I noticed that too. Piston induction and rotary disk engines produce a more pleasant intake sound than reed engines.
    "I can see your rod" brings back memories of looking into the rotary inlet of an engine on full song on a friend's dyno, seeing a red-hot con rod and casually asking about the fuel-oil ratio
  7. #41497
    All I was saying is that recommending the " shortest intake possible" is absolutely not realistic to actually run in many cases - that TZ250 picture is of an early model with limited port duration, the later engines had alot more
    timing, and needed the factory added spacer to get the intake length matched to the port - remove that and it becomes impossible to tune correctly.
    The TZ350 had the 5mm cylinder casting extension machined at an angle, such that nothing was cut off the bottom edge, so maybe 2.5mm of intake length was lost, but the duct was alot straighter - adding power.
    Then a 20mm spacer was added, after the bell extension was removed - adding power.
    Then the intake timing was increased, as the mid power with the longer tuned length was dramatically increased and the combination of the two worked perfectly - adding power.
    All of this conjecture simply goes away, if you sim the thing in EngMod to find the perfect combination of timing duration, and inlet tuned length, as I did to see what was possible with the old 1980 - 350 engine.
    The short carb and longer tuned length was super obviously superior - confirmed again when shorter/bigger Lectrons were added with a longer spacer again - adding power.
    The Lectron's were tipped up to almost dead straight in relation to the duct axis - not possible with the Mikini carbs as under brakes the fuel level at the front of the bowl rises
    and fuel spews thru the pilot jet on closed throttle.
    The 15* bend to the left on a CR125 inlet is a 2 HP loss in 40 HP for a SKUSA engine over a dead straight RS125 manifold.
    EDIT - Frits, the reason reeds can have " blowback " or more accurately " standoff " is due to the wave bouncing up and down the inlet tract off atmosphere is alternately returned as a + or - wave, depending upon if the reeds are open or closed.
  8. #41498
    I remember being able to see the rod on my MB reed engine.
    It had just thrown me to the ground. Roughly.(for the python fans).
    Aftermarket rod was indeed visible, or some of it as it cleft the cases in twain.a bit.
    I'd been running an RD piston and Mike of this parish exclaimed that it was likely the Yamaha parts trying to get out.
  9. #41499
    We use 20:1 oil ratio. This rod has not failed but I noticed our cranks getting really hot on the dyno. They were hot when we were pulling 12,000rpm now we are pulling near 15,000 rpm they get really really hot.
    How do the 20+ RWHP Dutch guys get their cranks to survive at 15-18,000 rpm?
    I suspect that crankshaft flywheel heating is the major source of power fade we observe after a generous number of dyno pulls.
  10. #41500
    TeeZee, what oil are you using.
  11. #41501
    My casually asking about the fuel-oil ratio was a tongue-in-cheek way of saying that there was no oil at all in that fuel. I advise 1:20, same as you.
    The 20+ RWHP Dutch guys rev between 15.000 and 16.000 rpm. The front runners have about 24 RWHP. I do not know of anyone revving to 18.000 rpm, let alone survive at those revs.
    You're right about the crankshaft heating. That is one of the reasons for me not to use direct fuel injection yet. Dry air is not very effective at cooling the con rod.
  12. #41502
    Frits, what is the actual problem with the 50cc racers crank reliability.
    We run the 125 KZ engines to 14800 all day, and the basically same configured OKN 125 direct drive engines are rev limited at 15,000 with no reliability issues at all.
    That level is of rpm with a 54.5 stroke is 27M/s, with a 40 stroke in a 50cc its only 20M/s.
    I know some were a bit upset when I opined after watching a few video's, that the Freetech guys were hardly pushing the envelope, not much more than a chainsaw when you look at the piston speed - why is that ?
  13. #41503
    I remember when I was at Orbital and we were initially dealing with Mercury, this being prior to the Optimax engine. The engineers were talking about the Rouen 24 hour boat races. To prevent both seizures and failed bearings, they filled the carb float bowls with straight petrol so the engine would start without loading up. Then, after starting, the fuel was fed from the tanks…..this was on an 8:1 ratio. Oil is good (and now expensive).
  14. #41504
    I was brought up using dreadful Suzuki commuter parts. If you revved the crank regularly to 13,000 the life was short, a yearly rebuild was not soon enough. I think they upgraded the rods slot a bit but not much change. They were 15mm be pins. Perhaps they whipped enough to cause issues. 17mm yamaha parts made for years of reliability at 13 - almost 14 peak.
    Too slow i realised the old rules of engagement were constraining me to a fictional peak revs.
    But Perhaps even with much less mass the smaller bearings be and main and thin be pin constrain rev reliability where a 125 size setup despite the much bigger mass is a sweet spot?
    Just conjecture with no evidence.
  15. #41505
Name:	Shell Advance Ultra2.jpg
    Shell Advance Ultra2 Full Synthetic.
    We bought several boxes of 1liter bottles. A job lot cheap, end of line runout. We have used lots of it over the years and still have a dozen or so bottles left. It has been a good oil, no oil related engine failures so far.
    With these you could hand the apprentice a one liter bottle of oil and a 20 liter fuel container. And tell them to go Ardmore airfield or Pukekohe and fill it up with Avgas and tip that pack of oil into into it. Bring it all back. If you got a full 20L container and an empty 1L oil bottle there was a pretty good chance you had fuel at 20:1. Helpers who tried to mix fuel 20:1 5L at a time often got it wrong.
