Page 2772 of 2776 FirstFirst ... 1772227226722722276227702771277227732774 ... LastLast
Results 41,566 to 41,580 of 41630
  1. #41566
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    The Garelli looks nice and it is a shame that twins were not allowed to compete against the 125 singles.
    Two 50ccm cylinders could have ca 10% more blowdown time area than a single125 ccm but of course also 10% more combustion chamber area so ultimate power would have been more or less the same.(Aprilia 54 horsepower and two Kreidler27 horsepower?)
    Engine and transmission of the twin lower mass than a single with balance shaft and much nicer two stroke sound.
  2. #41567
    Quote Originally Posted by MINGRET01 View Post
    I'm not sure where to introduce myself in this forum, which I've been following for a while. I own several classic motorcycles, including a 125cc Garelli twin-cylinder from 1985 that I've just finished restoring. I now want to disassemble the fork, but I don't know how. Perhaps Frits, who is on this forum, knows this type of fork and could help me.
    Bonjour Bruno, I actually worked on that front fork myself. Back then we called it ‘White Power’, the original Dutch company name, but because certain groups started using the same name for racist activities, the name became tainted, so nowadays it’s called WP.
    At the time, I focused on the hydraulic stop, which was designed to prevent metal-on-metal contact when the fork was fully compressed.
    The problem was that the hydraulic stop worked in both directions: when fully compressed, it also impeded rebound. I remember milling a couple of slots, which solved the problem. But unfortunately now, forty years later, I no longer have any documentation regarding this fork or my modification.
  3. #41568
    17th December 2025 - 05:21
    250 TZ 1982
    FRANCE
    Thank you for your reply.
    Do you remember how to disassemble it?
    I can't figure out how to remove the tube from the sheath.
  4. #41569
    Do you remember how to disassemble it? I can't figure out how to remove the tube from the sheath.
    It might be a hex socket screw from underneath, but I’m not sure anymore. As I said, it's forty years ago and I have done a lot of other things since then.
  5. #41570
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Dear Specialists
    What are the reasons for doing a ignition curve like the orange one?
    There is advance added at higher reves? Look at the red circle !
    Picture borrowed
    Thanks! Grüße!
    Wolfgang
  6. #41571
    19th June 2011 - 00:29
    my guess : a soft rev limiter
  7. #41572
    A soft rev limiter can be an option, but there is also another possibility.
    Delaying the ignition timing at high revs is intended to increase the exhaust gas temperature in order to bring the resonance frequency of the exhaust pipe into line with those high revs.
    However, a late ignition timing, sometimes even after Top Dead Centre, means that combustion pressure development above the piston becomes less effective, sometimes so much less that it no longer compensates for that adjusted exhaust resonance. In that case, it is better not to ignite even later at those high revs, but rather slightly earlier again.
    Below are the power curve and the ignition curve of a 100cc direct-drive kart engine that delivered its maximum power at 18.200 rpm but would only reach its maximum speed of 21.000 rpm by setting the ignition slightly earlier again at that speed.
    It should be noted that the exhaust system of this engine – which had no centrifugal clutch and no gearbox – was deliberately designed not to be very efficient in order to avoid the notorious torque dip at two-thirds of the maximum torque rpm.
  8. #41573
    Adding advance back in over the pipe has been used for years in JetSki racing, where the max rpm is limited by cavitation in the pump.
    It is used to achieve the same effect as adding advance up the front side at low rpm.
    The pipes reduced efficiency at clearing out exhaust residuals means the combustion flame speed is also low, and the extra timing pulls the peak cylinder pressure back closer to the mechanical optimum of near 15* ATDC.
    At rpm past the pipes most efficient range ( around peak torque ) the same thing occurs, so adding advance past peak power means a longer pipe can be used and the extra timing allows overev to the hard limit of the pump.
  9. #41574
    Hello, I'm Bruno from France.
    Attachment 358033
    I now want to disassemble the fork, but I don't know how. Perhaps Frtis, who is on this forum, knows this type of fork and could help me.
    Attachment 358034
    Bests regards
    Bruno
    Pull off dust seal, look for a snap ring. Remove top cap, unscrew from damper rod. With snap ring removed you use the two tubes as a slide hammer and pull apart. Use a heat gun to warm the area by seals. There's bushings in there.
  10. #41575
    What are some of the causes of this dip?
    Obviously many possibilities, let's say on a engine that has had some time spent on jetting and a good ignition curve.
  11. #41576
    The torque hole is not jetting or ignition curve related.
    There are an infinite number of port timing/tuned length combinations that will work in a specific rpm range.
    The more efficient the pipe design, combined with port resonance, giving good superposition over the desired rpm range - the more " out of sync " that combination will
    be at around 2/3 torque peak rpm.
    That effect can be very much ameliorated by a PV, as that changes the effective port timing, but without this band aid, the better your design combination is - the worse the effect becomes.
    You see the effect in EngMod, where no matter what you do there is a drop in TubMax that is impossible to " tune out ".
  12. #41577
    Specialists
    Thanks to you!
    If we bring back some more combustion pressure to camber and cylinder by adding advance in overrev. Think
    Isnt there a danger of overheating and Detonation?
    Specially if we put in to much added advance to early?...at a pipe that is not yet completely out of its effective rpm Range?
    Dankeschön!
    Grüße Wolfgang
  13. #41578
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Saw this on one of the bookface pages:
    I'm not so interested in the port, but the comment about pressure.
    Tim seems to be a very knowledgeable guy, and I've seen this idea of measuring pipe pressure mentioned by other sources that also seem to be at least well above the average bookface commentator.
    But....seems like actual pressure at any given point in the pipe is going to vary widely as positive and negative pressure waves bounce back and forth, so to talk about some single number you would have to be talking about an average.
    I suppose that is useful as an indication of pipe exit restriction?
    Any merit to it?
Name:	pipe pressure.png
  14. #41579
    Yep, we used this as a metric to control the outlet restriction on a World Champ Jetski.
    The two cylinders dumped into a single oversized stinger tube to bump up the front side power. - as this reduces the pipe efficiency at lower than the tuned rpm's.
    Then the ECU controlled a RPM/PWM water nozzle from the ski's pump to gradually flood the stinger, during testing we changed the nozzle such that at 100% open the pipe pressure was 2.8 psi ( yes average of course ).
    That was the max power number off the dyno with two normal stinger inserts.
    Edit - re the adding advance past peak power - it is only at peak torque that the scavenging and trapping efficiency is at its highest.
    Even at peak power the engines overall efficiency has already started to drop, and it is only helped by the linear relationship Hp = Torque x RPM - the constant is irrelevant.
    If the RPM has increased faster than the Torque has dropped, then Power keeps rising.
    You see a similar effect with electronic power jet operation, switching off fuel just past peak Hp, offsets the carbs natural modus operandi of continuing to supply more fuel and air, even though power is reducing.
  15. #41580
    4th August 2025 - 22:39
    LYNX snowmobile
    Piston Work
    Wolfgang, the question regarding deto first forming due to a lean transition jetting has been driving all the best tuners in the World up the wall, forever.
    No matter what " normal " fixes have been tried, the throttle response always suffers, and both the driver and the stopwatch complain bitterly.
    We have to run the mad rich pilot inner and outer jets to cool the piston , and the pipe, when in the overrun down into a second gear hairpin, and although reducing more airscrew or
    going fatter on the emulsion tube, or higher fuel level is better against the brake on the stand, its worse on track.
    The result is low speed WOT deto, but as you will see on every title winning KZ piston picture, its just the reality of doing what is fast, not technically " better ".
    Large pilot jet did not help.
    Large main jet did not helped either.
    The engine run rich for the first two laps, then really good for four laps,
    but the race ended on the sevent lap.
    In March 11 1995 - I promised to the 'GOD of POWER' to never ever again
    racing with a fan cooled engine.
There are currently 43 users browsing this thread. (2 members and 41 guests)
  1. koenich
