Page 2773 of 2776 FirstFirst ... 1773227326732723276327712772277327742775 ... LastLast
Results 41,581 to 41,595 of 41632
  1. #41581
    Quote Originally Posted by Viking View Post
    Large pilot jet did not help.
    Large main jet did not helped either.
    The engine run rich for the first two laps, then really good for four laps,
    but the race ended on the sevent lap.
    In March 11 1995 - I promised to the 'GOD of POWER' to never ever again
    racing with a fan cooled engine.
    Whats the class fuel rules?
  2. #41582
    4th August 2025 - 22:39
    LYNX snowmobile
    Pump gas - unleaded.
  3. #41583
    Sadly I have absolutely no compassion for you what so ever.
    There is absolutely no excuses for that to happen, if its mad rich everywhere, then another element of the tune is 100 Km away from being optimum.
    You only have fuel, ignition and timing to look at.
    That amount of detonation would have dropped the EGT a huge amount, you could have easily stopped before it created havoc if you were watching the gauge connected to a fast probe.
    Tough love buddy.
  4. #41584
    LYNX snowmobile
    Tough love buddy.
    I have no compassion myself for me. The race was the last for the season,
    in a support class for a competiton in European Championship,
    so nothing to lose for me as my Swedish race season was already over.
    I raced the engine the whole season without any trouble.
    In winter time the ambient air temperature is -10°C or lower, and includes snow-smoke, that gave enough cooling.
    The race in springtime of March had air temperature of +10°C with no snow particles in it.
    It´s a two cylinder engine, with the cooling fan on the right side blowing diagonally
    over the heads and trough the cylinders fins.
    Airflow around the left halves of head and cylinder on the engine left side are limited.
    The overheated piston shows the main damages diagonally on the left side.
    The right cylinder piston of the engine has no damage at all.
    I only use EGT during testing, never in race events.
    It did not came as a surprise, I knew that the warm weather would be a problem for my engine...
  5. #41585
    What Wob said, but Does your rules allow for e10 or suchlike?
    Alcohol buys you leeway both in tuning latitude as it tolerates mixtures being ballpark as long as its over-rich, its also very forgiving into adding lipstick to a thermal pig that a AC2T engine is.
    If it this class they are a bit more open than you may think
    24-25 International Snowmobile Racing Rules Copyright 2024 VINTAGE OVAL RACING COMPETITIONFUEL REGULATIONS
    NOTICE: It is advisable for all competitors to have their fuel tested at the event, before competing.
    1. A contestant appealing a fuel disqualification must bear the expense of the fuel analysis and handling.
    2. Allowed gasoline and lubricants:
    a. Only a commercially available pump gasoline that complies with these rules is allowed. (The term “pump gasoline” includes fuels dispensed
    from service station pumps and racing fuels that are commercially available in fuel cans and drums.) The gasoline may be mixed with
    petroleum, vegetable, or synthetic based lubricants. The use of oils, fuels (including gasohol), and additives that provide power-boosting
    characteristics are forbidden.
    b. Only motor fuel compounded of standard pump gasoline and an acceptable lubricant are allowed. Additives that produce power more than
    that produced by standard pump gasoline and petroleum base oil shall not be permitted. The list of unacceptable additives includes, but is
    not limited to, alcohol, nitrates, and other oxygen bearing compounds.
    c. No competitor or driver’s pit personnel shall possess power boosting additives or agents upon the race premises of the sanctioned event.
    Violations of this rule shall subject the violator to severe disciplinary procedure.
    d. Aerosol cans of ether are allowed at sanctioned races for starting purposes. No driver will be allowed to carry such cans on their person or
    their snowmobiles during the race.
    e. Driver statements as to their fuel components will be binding and may be verified by various fuel tests. Drivers must allow officials to test
    their fuel at any time.
    f. Youth Oval Racing classes, commercially available gasoline that is reformulated with up to 10% ethanol is allowed, the exception being “Big
    Track” competition for 120, 206 and 200 base class sleds. 120/206/200 and all oval junior classes must use legal fuels containing no ethanol.
    FUEL TESTS
    WARNING: Gasoline, lubricants, additives, and fuel test reagents are all potentially hazardous materials. Anyone handling them should be aware of
    the hazards and act accordingly. Race Rules Committees and ISR establish these guidelines and recommended test procedures, but do not assume
    liability for injury or death caused by the handling of these materials.
  6. #41586
    Sounds like a good case for an intelejet and plug egt back in. Twist more fuel in.
  7. #41587
    LYNX snowmobile
    E10 gasoline did not exist in year 1995 in Sweden,
    and as I mentioned there was no cooling problem in normal winter weather during the whole racing season.
    The engine had good power, so I put my effort in suspension work and focused to be a better rider...
  8. #41588
    LYNX snowmobile
    Case closed in 1995.
    Engine retired.
    My future was to go liquid cooled.
  9. #41589
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Engine retired.
    Viking!
    May i ask which compression ratio and exhaust timing your engine has?
    And your ignition/ timing is from interest too.
    Fix ignition? Timing Curve? Values of timing?
    Ignition without failures and constant when pickup, coil, cdi hot in race?
    Grüße Wolfgang
  10. #41590
    LYNX snowmobile
    Viking!
    Grüße Wolfgang
    I don't have the documentation available at my current location,
    but from my (31 years old) memory I would say CR was 12,2:1 and ED 195°.
    Ignition timing 14° BTDC at 9600 rpm (engine peak power).
    Those values was used the whole racing season - whith no failures.
  11. #41591
    CR seems not to be critical ...ok.
    14 degree at peak power too
    Do you know whats happening after Peak power?
    Value at the beginn of resonance.
    Damaged ignitions sometimes tend to shift ignition timings when hot, wet or both...often very hard to find these issues
    One day everything ok...other conditions and they fail...
    Grüße Wolfgang
  12. #41592
    Team ESE have broken a few gearboxes before but this smashed clutch basket is a first.
  13. #41593
    LYNX snowmobile
    Grüße Wolfgang
    Snowmobiles having CVT transmission don´t rev past peak power, so I don´t know.
    Can´t recall, but the engine had very narrow power curve, max torque 250 rpm below power peak.
    I don´t suspect or blame the ignition.
    Can´t blame the cooling system eather - even with the fact that a factory rider also DNF with a fan cooled engine.
    It was my decision to go racing - with a calculatet risk...
  14. #41594
    Sorry...I was never involved in Cvt engines.
  15. #41595
    Someone with less manners than me would mutter helical gears have no place on a racebike.. I thought you had replaced these a while back....
