Page 297 of 2773 FirstFirst ... 1972472872952962972982993073473977971297 ... LastLast
Results 4,441 to 4,455 of 41594
  1. #4441
    Its impossible to make a statement with any meaning such as " for 8500 rpm the transfers should be open" - as I said, the angle area varies hugely between a short stroke Vs a long stroke, so any calculation must involve all of the elements of the design to achieve any accuracy at all.
    There are several programs available now that can point you in the right direction, reading 30 year old books is OK for background info only.
    The port floor geometry is super critical for any high performance application.
    Fuel/air in the duct is forced to follow the outer wall ,no matter what,but the short turn radius and the floor exit angle combine to keep the flow column "coherent".
    When the inner shape is not matched correctly the flow detaches very early, creating huge amounts of turbulence,this ruins the scavenging streams directional control,and as an aside it then also looses contact with the piston face.
    Keeping the piston cooler is just a by product of the fact that the transfer streams are kept attached to the inner wall - when they dont everything turns to shit.
    Re the PV clearance - I dont know who told you that it isnt critical but thats bullshit.The PV face should be as close as you can get it without snagging the bulging ring face.
    Much more than around 0.5mm and you start to loose effectiveness with too much blowby.
    This is the whole reason that curved and multi blades were developed, to keep the PV edge as close as possible to the piston during its whole stroke length.
    In the RGV you have to modify the valves a heap to get them to work at all.
    Edit - please dont take any of my remarks about 2T technology as personal attacks on anyone's knowledge on the subject.
    Its just that reading Bell, or Cameron and even much of Blairs early stuff is like swatting up a Tube Radio Repair Manual, and then trying to design a Mosfet power amp.
    Even the basic CAD type programs that use STA as a basis for getting the ports in the right place for the rpm,power needed and swept vol are hugely better than the old references.
  2. #4442
    A handy (and cheep $16 USD) Porting Calculator from:- http://www.porting-programs.com/ it is based on Blairs and Jennings work. Use the Blair data for STA and blowdown required for a selected power output.
    Kel gave me this link to a very interesting book. www.prme.nl/download/engine-1.pdf
    The decade pages from p80 have link collections, links to Jenning and Bells books can be found there somewhere.
  3. #4443
    5th June 2008 - 17:46
    Cheers for the explanation re. the reasons for port angles etc Wobbly. Very helpful.
  4. #4444
    31st July 2005 - 11:15
    a shed full of crazy shit
    rather off topic, but enjoy:
    http://rmdmotors.com/kenny-roberts-collection/
    If only lotto would roll out the right numbers
  5. #4445
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    I checked out the price on this little beauty
    http://rmdmotors.com/1980-gp-bike-kreidler-van-veen/
    1,350,000.00 JPY = 20,218.57 NZD
    Bit much to bucket ?
  6. #4446
    ahh the tyre's flat, knock em down a bit.
    Even Husaberg would have trouble justifying that as bucket legal. But yeah hella cool bit of classic kit. Tyres are a bit frightening.
  7. #4447
    I thought we had kissed and made up
  8. #4448
    Trying to make sense of my last few dyno sessions.
Name:	A1 30 hp.jpg
    Blue line, the cylinder with side exhaust ports might be 30hp but its not a very appealing curve compaired to the conventional Suzuki GP125 cylinder.
Name:	A2 Vtec no Vtec.jpg
    Running the Vtec improved the carburation and curve but the extra inlet length of the Vtec seems to have knocked back the over rev.
Name:	A3 Soft-Hard Close.jpg
ID:	242657 Click image for larger version.
Name:	A-New Motor Rotary Valve.jpg
    In back to back tests the soft close rotary valve seems to give a little more power and improved the over rev, we noticed this with our other engines too.
Name:	A4 24-38 Side Carb 1.jpg
ID:	242656 Click image for larger version.
Name:	Aa 24-38 006.jpg
    Both are Vtec soft close. Red line is the 24-28 sticking out the side carb arrangement, Blue line is the 24-38 tucked out of the way arrangement.
    In trying to get the carb tucked in, it has realy upset the curve. There was also another problem, where as I could open the 24-28 up fully at nearly any rpm the 24-38 would stall unless the rpm was 9k or more and I had to be carfull with the throttle to get a good run.
    The 24-38 arrangement has more over rev but dropped power every where else. This must be due to the different inlet arrangements. So I figure if I can loose power then by some carefull work I can recover it and may be use the inlet system to fill in the 6-7k rpm area too.
    The straight inlet seems best but with the Keihin carb its quite long and the inlet tuned length is to long and the carb sticks out to far. I think the next move is to try a straight inlet with a much shorter Kart pumper carb.
    If it wasn't for the 24mm rule, I would actually try something suggested to me by Sonic_V, two carbs with different inlet lengths.
  9. #4449
    Very cool. The last graph 28hp looked really good. Great spread of power really across that range. Looks quite rideable. You would no when to change gear with that big drop anyway. Are there any down draft carb options you could try. Might give more carb position options.
  10. #4450
    I think that you are beating a dead horse a bit trying to get a big positive result from intake tuning.
    The short pumper carb being able to be run "updraft" was one reason I suggested it.
    The rotary valve setup needs the flow to enter the case, moving upward over the crank - not downdraft.
    As the wave action in the Exhaust is WAY more powerful, then the result from a PV or a ATAC setup will get much more dramatic results, relatively easy to implement as well..
  11. #4451
    Its funny I was just thinking the other night about this thread. For the how many pages & pages the main point that has had little discussion is pipes.
  12. #4452
    inlet or exhaust?
  13. #4453
    crack
  14. #4454
    My interest at the moment is elsewhere
Name:	Chambers welding the new Pipe.jpg
    But if you can get Chambers to talk he could tell you about what he is up to.
Name:	New Projects 011.jpg
    I see he has lowered the bike to its max and made a mockup of the planned pipe.
Name:	New Projects 016.jpg
    And checking for clerance on the front tire.
  15. #4455
    Hmm, yeah he may need to run a heavier spring. Not sure that gasket pipe technology has been explored before so I salute you, although I can confirm that my bent wire donuts on No.8 didn’t hold further promise so were dropped early in development, but useful for learning how to snake past linkages on bigger bikes.
    Yeah that pipe is pretty awkwardly positioned, but most MX bikes are worse. Best to strop the front down & assume there will be additional bending in the frame & forks, although in the RS’s case that will be sod all. On a suzi GP125 as she came its probably a good ½” or more.
