Page 384 of 2774 FirstFirst ... 2843343743823833843853863944344848841384 ... LastLast
Results 5,746 to 5,760 of 41610
  1. #5746
    A few years back Kevin Grant (well known Britten owner) apparently had all the 400's here in NZ - I don't know if he still has them.
    Talking to him he was quite keen to get one running and bring it South for the Sound Of Thunder meeting but it hasn't happened.
    Frits - you should be happy they're as far away from you on the planet as they can go....
  2. #5747
    You have no idea what you're asking of me. I refrained from reading the above articles because I want to keep my good mood. But OK....
    The 400 cc twin was entirely Witteveen's idea. He built it in cooperation with Franco Moro (the same glorious cooperation that produced the Maxtra / Haojue 125...). When they realized that 400cc wasn't enough to beat the 500 cc fours after all, they made the pistons bigger and bigger, resulting in a more and more oversquare engine with more and more thermal problems.
    Sorry Frits it wasn't intended to be a mood killer. I had only just read the article and sensed some stuff in it relation to either a lacking of confidence or competence. I had never got the same feeling from other articles relating to the 250. So I will be assuming the later?
    Googled those bikes you mentioned. a few teething problems and a rider revolt and a sacking http://www.crash.net/motogp/picturea...47765/1/photos
    Upside down engine i am assuming the Rumi layout (I am sure you are a little familar with that as well I guess see pic 5)i had posted earlier i thought it was quite trick until i looked at a 1988 YZR500 or for that matter a 1988 Aprilia v twin naked and realised the upside down engine was just so plain logical.The beauty of hindsight for me, Genius for the designers. Who did the Chassis for it?
    oh ok Nico Bakker.http://2stroker.createforumhosting.c...iel-t2652.html
    Grumphs bit. I shouldn't be that surprised knowing of Kevins collection of exotica. But i was about the Aprilia.
ID:	252829   Click image for larger version.
ID:	252830   Click image for larger version.
Name:	yzr500 88 odd.JPG
ID:	252831   Click image for larger version.
ID:	252832   Click image for larger version.
Name:	Some guys behind the Rumi.JPG
ID:	252835   Click image for larger version.
  3. #5748
    4th November 2003 - 13:00
    BSA A10
    Upside down engine i am assuming the Rumi layout i had posted earlier i thought it was quite trick until i looked at a 1988 YZR500 naked and realised the upside down engine wasn't innovative after all.
    I hadn't seen them before but I helped a friend build an upside down NSR250 in a Kart with the gearbox cut off driving through a fluid coupling although that was late nineties
  4. #5749
    As an indicator of the relative genius of the design team, look at the intake on the Rumi - an FCR carb with dead straight manifold.
    Then look at the Maxtra, balls up par excellence.
    I had a job interview with Mr Witteveen at P.I when McWilliams put the Aprilia on pole,short of the story was I didnt take the job, wish Frits had done the interview and then I would maybe have got to meet Jan.
  5. #5750
    A few years back Kevin Grant (well known Britten owner) apparently had all the 400's here in NZ - I don't know if he still has them. Talking to him he was quite keen to get one running and bring it South for the Sound Of Thunder meeting but it hasn't happened.
    Maybe you could bring them just a little bit closer - isn't there a deep spot in the ocean somewhere?
  6. #5751
    Couldn't you just slip on in a 250 engine? I hear they went kind of ok with one in them? (for a 2 stroke.)
    I assume the chassis is nearly identical. Are they?
    Couple of Cobas.
    JJ-Cobas with Autisa engine (designed by Jan Thiel) 1985
    Seen this today regarding Bill Buckley.
    http://www.kiwibiker.co.nz/forums/sh...0-Bill-Buckley
Name:	RSV400 vs RSV250.JPG
ID:	252849   Click image for larger version.
Name:	rsv250 engine.JPG
ID:	252852   Click image for larger version.
Name:	2s vs 4t.JPG
ID:	252853   Click image for larger version.
Name:	JJ-Cobas TA3 80 cc 1989.JPG
ID:	252979   Click image for larger version.
Name:	JJ-Cobas with Autisa engine (designed by Jan Thiel) 1985.JPG
ID:	252980   Click image for larger version.
Name:	upsidedown engine.JPG
  7. #5752
    From what he told me, when he asked about buying them as a job lot, the response was along the lines of "New Zealand ? Yes. that should be far enough away....." Whoever he talked to at the factory just wanted to get rid of them.
    Your bad luck the container reached here instead of falling overboard.
  8. #5753
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    Couldn't you just slip on in a 250 engine? I hear they went kind of ok with one for a 2 stroke.
    Couple of Kobas.
    Kind sir , please stop posting naughty pictures on the internet , my old heart hasn’t seen this much action since Angela Peabody showed me her "etchings"
    Stephen
    must have a lay down ......
  9. #5754
    Quote Originally Posted by Brian d'marge View Post
    Stephen
    The Japanese sure do like their cartoon naughtiness. I guess the fetish has er...rubbed off on you to.
    Tally ho and tootle pip.
    Add Honda RS125 stuff later.... It is after all the for many a day of worship and I bet if he was into bikes (GOD) he would have rode a Honda.
  10. #5755
    EngMod2T
    I had previously built up an EngMod2T model of my existing motor that pretty much matched its real life dyno graph.
    And then added a Pipe designed by Frits, the old plenum and my triple port cylinder and got 40+hp. It exists in theory, now could the race be on to see who can make the first Bucket to touch 40rwhp in reality!!!!
Name:	Tripple port 1.jpg
ID:	253020   Click image for larger version.
Name:	New Engine FittingtheEngine 1.jpg
ID:	253017   Click image for larger version.
  11. #5756
    EngMod2T
    Attachment 253013
    And then added a Pipe designed by Frits, the plenum and my tripple port cylinder. Could the race be on to see who can make the first 40rwhp Bucket!!!!
    Fecking impressive.
    Poor 1970's commuter-bike crank... 13500 sounds like a big ask.
  12. #5757
    Phenolic main brgs with RGV250 rod assembly has proved reliable so far ....
  13. #5758
    I've been playing with simulations a bit.
    In MOTA I've input a model of my current engine, as mentioned earlier It seems around right but perhaps a little optimistic on the outright horsepower.
    Here are before and after curves of the current plan.
    Subject to change as I learn more.
    I found I can get much higher numbers but I think it may be a quirk of the maths behind the sim or something. I don't trust it to deliver in real life.
    I'm especially mindful of wobbly's comments (ages ago) regarding "sucking real hard on crappy transfers".
    I'm probably going to spend a bit of time working out crank case volumes because while I know it is a bit old fashioned I know my motor is too!
  14. #5759
    True, you guys have done very well when it comes to reliability. The odd pop, but that is to be expected considering the nature of your endeavours.
    I've been meaning to ask, has that Belzona remained attached to the piston?
  15. #5760
    You see what I mean about Mota over stating it but I think you will fined the rpm and the shape of the curve will be pretty well right.
    Yes, the Belzona is still there ... and yes, I think the cranks can be made reliable with original Suzuki RGV rod kits and decent main brgs, the same could be done with TF/TS's and then they should be good for 13,000 + too.
Name:	A Phenolic Caged Mains 1.jpg
ID:	253023   Click image for larger version.
Name:	RGV Rod 2.JPG
