Page 438 of 2776 FirstFirst ... 3383884284364374384394404484885389381438 ... LastLast
Results 6,556 to 6,570 of 41630
  1. #6556
    Having some carburtion issues. Does this look too lean?
    no it looks fine but dose have a small crack in the piston skirt
    Looks mint, don't worry about the small crack.
    I'd replace the piston as a precaution, hell you have it out so why not. If you're careful taking the circlip out you could probably use it again.
    I love it! Great way to start a sunday .
  2. #6557
    .... the reason for my confusion about the RSA head shape is that i very recently heard a respected person definitively say that the RSA did not have a toriod design.
    This kept me thinking for a while. Maybe it is a misunderstanding stemming from the way you define a toroid. The decisive factor is that the radius of the combustion dome originates off-centre; its center is offset from the cylinder center line. That may or may not lead to the spark plug intruding into the combustion chamber, depending on the radius, the offset and the plug thread diameter.
    The first two pictures show the Aprilia combustion chamber with a flush plug. The third picture shows a Wobbly-head with a deeply-intruding plug. The last picture shows the turbulence in a toroid head, initially caused by the transfer streams and enhanced by the squish action.
    The intruding plug seemed a logical step but tests at Aprilia have shown that an intruding plug costs power, probably because it causes a scavenging shadow where spent gases are not fully removed by the incoming fresh mixture, so Aprilia-chambers have a flat area around the plug hole.
ID:	258058   Click image for larger version.
ID:	258059   Click image for larger version.
ID:	258060   Click image for larger version.
  3. #6558
    4th November 2003 - 13:00
    BSA A10
    You could build it up with a tig and machine it back, if you do that going by personal experience it could last up to a season being revved to 12500rpm
  4. #6559
    The deep intrusion toroidal head shape was developed using flat top, so called Honda A Kit pistons.
    I would opine that the end result is very similar to the flat roof dome using a convex piston.
    BTW there is still some differing opinions about the circular flow direction of the squish action that is created off the sharp corner
    going into the bowl.
    First logical reaction that would seem to be the accepted norm, and is as Frits has shown, is that the rotation is clockwise.
    But a senior/clever engineer at Yamaha told me that their CFD analysis showed it was the opposite way - and he lead the development of Yamahas 250/500 flat roof chamber when unleaded fuel became mandatory in 98.
  5. #6560
    1st June 2011 - 14:39
    Honda NC50
    Straya
    Ah this is surely the problem... I had made the assumption that a toroid shape always involved an intruding plug. I guess that the comments I read were based on the same incorrect definition of the design. To make this more confusing the flat roof design you posted above is the design I originally thought the RSA had, however that's the one that I incorrectly referred to as a bath tub shape which is what led to this confusion in the first place. My original question therefore should have been worded... Is an intruding plug shape better/worse than a flat roof shape?? But this has now been answered.
    Thanks for being patient and taking the time to explain.
  6. #6561
    I had assumed the intrusion plug would have had most benifit as the cylinder bore & hence chamber had become larger dropping the spark plug further into the chamber where it is closer relatively on a 54mm or smaller bore. Perhaps?
  7. #6562
    And yes thank you all for your kinds words re my poor classic YZ piston.
    I'll go up a jet size & see how it goes, if not I'll order a new one.
    PS I think this was caused by excessive clearance, it did sound a bit slappy. No wear evident on bore, so it might have been bored too big to start with.
  8. #6563
    28th October 2011 - 20:02
    RGV
    Pommyland
    D ports in a 4T are there to speed the flow up on the short turn radius, and prevent serious reversion in the area of least flow velocity,the port floor.
    In a 2T we use the step at the manifold to reduce the Ex duct volume - also keeping the velocity high, and also preventing the reverse plugging wave from buggering the powerband
    even more than it usually does when the pipe is too short for the rpm.
    When they are designed correctly both are a useful tuning tool.
    STEP AWAY FROM THE GRINDER.
    ...further to this, what's the informed wisdom on the half moon projections seen in the necks of these 2002 YZR500 pipes
    http://www.blatawcm.com/redbull/imag...2/DSCN1996.JPG
    http://www.blatawcm.com/redbull/imag...2/DSCN1995.JPG
  9. #6564
    25th August 2010 - 04:40
    RD350 YPVS F2
    Europe
    Here's some pics of rgv500 cylinders and pipes...hhmmm...
ID:	258134   Click image for larger version.
ID:	258135   Click image for larger version.
ID:	258136   Click image for larger version.
ID:	258140   Click image for larger version.
ID:	258138   Click image for larger version.
  10. #6565
    When unleaded became mandatory in 98 most teams had a hell of a time keeping deto under control, having to run very rich and retarded.
    The cylinders with the straighter pipes always gave alot more grief, untill a lowly dyno operator at Yamaha discovered that
    when he stuck a large pressure probe into the header, the deto went away.
    They managed to keep this secret for a couple of years but when teams like WCM got hold of the bikes, and left pipes lying about as you see in the pics,word soon got around.
    The "things " intruding into the header take varying forms,but all do the same thing - the usually bottom "bent "pipes dont have the same issue, so dont need the so called deto buttons.
    I have a couple somewhere from a Red Bull bike - I will pic them and post here .
    Here is a shot of a cylinder I have been working on - its just come back from plating - the duct entry shape looks a bit familiar doesnt it.
    The plating must have more Nickel in it, that would be why some of the previous shots on here look as though the cylinders have a liner, its the colour of the plating process.
Name:	304 buttom-2.jpg
  11. #6566
    RGV
    Pommyland
    What year RGV500 are those from?
    Y2K has more apparatus on the exh side
  12. #6567
    . . .a lowly dyno operator at Yamaha discovered that
    when he stuck a large pressure probe into the header, the deto went away.. .
    . . .The "things " intruding into the header take varying forms,but all do the same thing -
    Now that's queer. My only foray into using EGT probe (on my 50 so small header) but with probe position a good 6" away I fed it in & ran it up on the dyno. Oh dear, lost a lot of power & gee these EGT readings were higer than I thought. Jetting & ign don't help. Hmm wonder if the probe was causing the issue. Block it off & power comes back.
    Thinking about it later I decided to retry with the probe only just inserted, think the metal outer was getting stinking hot & on small header was big issue. that was 2yrs ago & have got distracted since.
  13. #6568
    Quite familiar; the only give-away is the distance between A-duct and stud. And I see no provision for a powervalve. What's it for? A kart engine?
  14. #6569
    What brand of piston were you using?
    Recently we had a close call with a new PROX piston cracking up, only 20min on the dyno, pulled it out after seeing the runs losing power, it could have only been a dyno pull or two away from completely letting go.
Name:	A4 Prox Piston 004.jpg
ID:	258156   Click image for larger version.
Name:	A1 Prox Piston 003.jpg
ID:	258157   Click image for larger version.
Name:	A2 Prox Piston2 005.jpg
ID:	258158   Click image for larger version.
Name:	A3 Prox Piston2 001.jpg
  15. #6570
    it was std Yamaha NOS circa 1980. Think they used ART back then which were good cast pistons. ProX used to be ART distributor under another name I think but I heard they are using Mitaka & quality is up & down. Not totally certain of any of this.
    My crown was fine apart from the peppering from debris, the piston it was hard to tell where the fault started. My Std Honda piston I was running before started cracking the front of the skirt. Usually the skirt goes when there is too much clearance either through wear or incorrect bore.
    But I'm guessing as there wasn't much left, clearly it fell to bits quick as I could pull the clutch.
