Page 448 of 2773 FirstFirst ... 3483984384464474484494504584985489481448 ... LastLast
Results 6,706 to 6,720 of 41591
  1. #6706
    I like to mess with things a lot! Actually, the original idea was to use the whole protractor as is, with a small metal ruler like now. Eventually, it didn't fit the 54 bore and as a waster greek I am, I destroyed the second. (sorry, cynical political comment)
    But sure, I stand corrected Frits. Mine looks more fancy though.
  2. #6707
    quallman1234, husaberg:
    The Bishop (+Illmor-Mercedes) take on rotary valves.
    "To demonstrate the credibility of Bishop Innovation’s new rotary valve technology it joined
    forces with Mercedes-Ilmor to develop the technology for use on their V10 Formula One
    engine only to have its strategy destroyed by a change in engine regulations. "
    "By late 2000 back to back testing with the poppet valve
    single cylinder engine demonstrated a 10% power advantage and improved durability."
    Source: http://home.people.net.au/~mrbdesign/PDF/
    Four-stroke I know, but if you split that rotary valve in half, you basically have what I use for intake valving. -See, I managed give it some two-stroke angle
  3. #6708
    16th December 2011 - 14:14
    Benelli 250 2C
    A couple of questions for comment.
    1) Why do 14mm spark plugs get used. In a 125 twin or 50cc the spark plug takes up a fair part of the head area. Does anyone use 10mm or 12mm dia plugs ?? NGK appear to have a reasonable range of 10mm fine-wire plugs of the desired heat ranges. Assuming they are actually available
    2) Carb primary or emulsion nozzle jets. What type would be better for methanol fuels. Would a shrouded emulsion type give better atomisation for this application with the increased fuel flow requirement of 2 - 2.5 times that of petrol ??
    thanks
  4. #6709
    The Wobbly Pirranha ....
Name:	AB Chamber 2 012.jpg
    Laid out all the pieces in order and the right way round and numbered them so that they are easier to sort when welding them.
Name:	AB Chamber 2 015.jpg
    Cleaned the ends and started a small lead on them so they go through the roller easily.
Name:	AB Chamber 2 018.jpg
    Fed them all the same way up into the roller and rolled them into more or less a circle.
Name:	AB Chamber 2 020.jpg
    Not perfectly round but I made sure the edges where they butt together are sitting flush.
    Next move is to fusion weld and hammer the joints then roll the again so they are nice and round.
    I should have left this job for Bucket, he has more patience than me ......
  5. #6710
    thanks
    14mm spark plugs are the common size for road motors as they are cheaper and less subject to damage from ham fisted owners...
    In NZ there's a good range of 10mm available, probably better available in 12mm, and a limited range of 8mm. Ask Darbi's...
    I can't say from experience which style of needle jet nozzle will suit bulk methanol flow best - I'd think it may depend on the application...ie cylinder size. Plain nozzles have worked fine with meth for me.
    Vizard quotes a problem with fuel not emulsifying in a car carb which he solved by putting a knife edge on the nozzle - the ragged edge acted to break up fuel droplets better than a plain square edge.
  6. #6711
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Im working on my buckets tomorrow night & hopefuly Saturday morning. Pop in and ill weld it up for you if you want
  7. #6712
    Wob, may I ask an EngMod question. I want to simulate a Vforce reed valve.
    What I do, is measure every dimension as a normal reed valve and for the angle I measure & use this one:
    It looks obvious, but I am not sure. Vforce pyramidic triangles are not isosceli (greek plural of greek word isosceles ), like most reed valves.
    The above angle measures 23.5 degrees and eff. diameter is ~41 over 43.5 of the conventional equivalent valve.
    Furthermore, would you care to give an insight on why we don't see vforce on road race bikes?
    Can't wait to see the piranha ready TZ!
    I liked the small description on the manufacturing. Please add more on the next phase.
  8. #6713
    Here is a Banshee VF3, all you can do is measure the angle between the reeds as you say.
    Any small inaccuracy in the geometry isnt worth worrying about.
    VF reeds work really well on road race bikes - an RS125 Honda makes better mid and top end with a CR125 VF2, we have done dozens of tests on this.
    The VF3 for this model isnt as good and chips petal tips.
    All the sprint and road karts here use them, but only a few road race bike riders seem to know.
Name:	Banshee Reed001.jpg
  9. #6714
    I see..
    Me too saw a clear difference in favor of the VF in EngMod, that's why it seemed odd.
    Mine comes from Arctic Cat 500/600 Twins and here's a shot if anybody needs the dimensions:
Name:	Arctic Cat 600 Twin Vforce.png
  10. #6715
    16th November 2006 - 23:46
    Thanking you sir. Next upgrade for my RS then!
  11. #6716
    An advantage i see with the VF reeds is the tuned length of the reeds. In a conventional reed block if the free length is restricted for tuning purposes the effective area is reduced which is compensated for by going wide. With the VF reeds they are stacked so I see a better shaped reed block and port.
  12. #6717
    Resin stuff
    Hey Guys
    What's the stuff you have been using to build up ports etc. I had a look through but could not find it. Am making a manifold and need to match carb spigot nice.
    Cheers Rich
  13. #6718
    Devcon F, you can get it from Blackwood Paykles in small tubes like 5min Araldyte ($25) or big tins of putty ($175). I think Fishy sells it or something similar too, but cheaper.
  14. #6719
    JB weld is good too (bought on TM ages back) & better for self leveling stuff, Devcon better for forming shapes as its thicker. Copes with inlet temp just fine. Not so much on ex side, maybe for several min.
  15. #6720
    RS Components sells Devcon F in the tins for around 1/2 what Paykels want.
There are currently 22 users browsing this thread. (2 members and 20 guests)
  1. JanBros,
  2. lohring
