Page 46 of 2776 FirstFirst ... 36444546474856961465461046 ... LastLast
Results 676 to 690 of 41632
  1. #676
    hey if a bike had 20 HP and you hooked up 20 horses to the back of the bike even if the horse were dead you wont win
    I think that' sthe funniest thing I have heard all year! Can I use that? It's great!
  2. #677
    if I was on poll I bet you would have a hard time getting past
    I'm calling the spca again
    cant have you teasing the dogs like that
    dragging food around the place
  3. #678
    Just getting a horsepower figure doesn't mean anything.
    "It Does" if your MZ has just broken the 100HP per Litre barrier then you can brag about it.
  4. #679
    Spectrum
    The largest suppler of used motorcycles out of Japan.
    100% Kiwi owned.
    Check them out:- http://www.trade.co.jp/index.html
    Get your next super Bucket FXR Aprilia TZR or whatever from here.
  5. #680
    3rd May 2005 - 07:22
    2005 Custom Moped
    where the sun sets
    Sorry guys Ive had a few discussions about horsepower in my life.
    And that was invented some years ago to combat a guy who had a 350 hp chev and the only thing faster was his mouth.
    I was only joking and didnt mean to target it at anybody.
    Sure SS use it I regard you as a friend.
  6. #681
    30th November 2005 - 18:27
    Spectrum
    100% Kiwi owned.
    Good site, but the only "bucket" eligble bike was a CBR150 for $4250.00
  7. #682
    Whattttt the robbing basterds.
  8. #683
    I mananged to get two Germans laughing at that one 5 minutes ago, translating from English to German, quite often the joke gets lost....this one worked!
    After a bit, one guy asked me if racing a bucket was like "floging a dead horse"...... I think he took it too far!
  9. #684
    2005 Custom Moped
    where the sun sets
    sweet as SS ive been enjoying the tailend of summer riding on my big bad 50.
    I get surprised how serious some big bike riders get as they race from redlight to redlight and i sail pass as they are still taking off I just think this bike is that slow the light will be green when i get there
  10. #685
    2005 Custom Moped
    where the sun sets
  11. #686
    From:- http://www.smellofdeath.com/lloydy/p...diag_guide.htm
    Loydys Lambrettas Two Stroke Piston Diagnosis
    PERFECT BROWN CROWN
    The crown of this piston shows an ideal carbon pattern. The transfer ports of this two-stroke engine are flowing equally and the color of the carbon pattern is chocolate brown. That indicates that this engine's carb is jetted correctly.
    FOUR-CORNER SEIZURE
    This piston has vertical seizure marks at four equally spaced points around the circumference. A four-corner seizure is caused when the piston expands faster than the cylinder and the clearance between the piston and cylinder is reduced. Another common problem of this type is a single point seizure on the center of the exhaust side of the piston. However this occurs only on cylinders with bridged exhaust ports. The main causes for this problem are too quick warm-up, too lean carb jetting (main jet), or too hot of a spark plug range.
    SHATTERED SKIRT
    The skirts of this piston shattered because the piston to cylinder clearance was too great. When the piston is allowed to rattle in the cylinder bore, it develops stress cracks and eventually shatters.
    SNAPPED ROD
    The connecting rod of this engine snapped in half because the clearance between the rod and the thrust washers of the big end was too great. When the big end bearing wears out, the radial deflection of the rod becomes excessive and the rod suffers from torsion vibration. This leads to connecting rod breakage and catastrophic engine damage. The big end clearance should be checked every time you rebuild the top end. To check the side clearance of the connecting rod, insert a feeler gauge between the rod and a thrust washer. Check the maximum wear limits in your engine's factory service manual
    Read the rest of it here:- http://www.smellofdeath.com/lloydy/p...diag_guide.htm
ID:	124265   Click image for larger version.
Name:	Multi Point Sezure.jpeg
  12. #687
    2nd January 2009 - 20:18
    Suzuki 125
    FOUR-CORNER SEIZURE
    Didn't TZ have that problem at Taupo?
    Interesting that 4 point seizure, and explination is from a Scooter shop too.
    "The main causes for this problem are too quick warm-up, too lean carb jetting (main jet), or too hot of a spark plug range."
    No mention of studs crushing the barrel.
    TZ don't worry about those 8mm studs, just warm your bike up properly first before racing it!
  13. #688
    Kreidler :- http://www.kreidler.nl fast air cooled 50cc 2-strokes.
    Lots of interesting pictures of go fast Kreidler bits:- http://www.kreidler.nl/forum/viewtopic.php?t=23523
    If you haven't got a PDF of Bells book by now your a lazy couch potatoe.
    Another Graham Bell PDF:- http://www.kreidler.nl/artikelen/per...raham-bell.pdf
    15Hp 50, check the graph http://www.kreidler.nl/forum/viewtopic.php?t=29410
  14. #689
    20th November 2002 - 11:00
    Wellington, New Zealand,
    Quote Originally Posted by Chambers View Post
    That's not their reason for 4 corner seizure, it's their reason for a SINGLE seizure point.
  15. #690
    From:- http://www.kartsport.org.nz/technica...e_seizures.htm
    Four corner seizure: Both sides of the piston will show heavy scoring and seizure marks on each side of the wrist pin hole. The pattern of these four seizure points often appears to be a perfect square, hence the slang term "four corner". The scoring takes place in this pattern because those areas of the piston casting are the thickest. When the piston is seriously overheated, the thick areas will expand and distort the most.
    More piston death here:- http://www.kenoconnorracing.com/Piston%20Death.html
