Page 485 of 2773 FirstFirst ... 3854354754834844854864874955355859851485 ... LastLast
Results 7,261 to 7,275 of 41594
  1. #7261
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
ID:	262360Click image for larger version.
ID:	262361how much would you pay for this bit of rubbish? gt50
  2. #7262
    25th June 2008 - 17:04
    89 zxr400
    Palmerston north
    ummm would a marriage do?? other then that I think your asking to much!!
    Growin' up as a kid, always thinkin', you know If I could ever just race motorcycles and make a living that would be the coolest thing know to mankind.
  3. #7263
    I have been looking at the Trombone pipe again and can see that its best used for extending over rev. So I need a pipe that makes good power at 9,000 rpm with an exhaust opening at 82 deg ATDC and then by shortining the trombone I can keep the system in resonance for a good 4k maybe even 6 at a stretch.
    The down side is the plenum which adds a usefull bit of top end but only works over a limited range, good for a conventional pipe but detracts from a Trombone style pipe as the plenum only works well in one place then reduces the power elsewhere.
    If you take the sim as I last ran it then do a Turbulent Model with your ignition curve,the TuMax will be thru the roof,and the program will probably scream DETO WARNING at you in the mis range.
Name:	EngMod det warning.JPG
    The EngMod det warning that would have told me that I was in dangerus teritory on my earlier engine.
  4. #7264
    I sat my learners on a GT50, Mag wheels and a disk brake It was a mates but i still thought it was bitchen.
    But where they air cooled or water cooled?
  5. #7265
    A nice pic of the latter Roberts Proton V3 cylinders (the one that started to go well before the 2002 4T change ) Spool PV's with a ATAC chamber. Looks as though they had experiments with volumes to.
ID:	262391   Click image for larger version.
  6. #7266
    93 kwacker zxr750
    palmerston north
    was air cooled now water . this one has the nz land speed record for a 50
  7. #7267
    89 zxr400
    Palmerston north
    Who bulit that awesome machine!! hahaha I know where there are photos of it when it had set the record and there was also a matching sidecar outfit to boot!
  8. #7268
    93 kwacker zxr750
    palmerston north
    Quote Originally Posted by worm13 View Post
    better post
  9. #7269
    89 zxr400
    Palmerston north
    better post
    Yup will do, give me a couple of days to sort it all out and il post them! bike looked pretty cool way way way back in the day!
  10. #7270
    I could never beat Pete on that bike but my AC50 was fast enough to keep him honest and he fell off at Whakatane and removed a bit of flesh keeping in front. I think him and Ram turned up in a van full of buckets with a sidecar tied to the roof on the inside to that meeting.
  11. #7271
    Mate I don't remember any of the Roberts Protons doing well at any time.
  12. #7272
    These graphs were drawn using kW's so that the curves might more visualy represent the real DIN or PS hp I might see from the back wheel on the dyno.
Name:	Darcy 0-130  kW.JPG
    I have been looking at the Darcy RG500 pipe that peaks at 10,500 and simulating it with a Trombone header. By shortining the header 130mm It looks like I can get the power spread to extend out to 14K.
    It might be down a little on power but the total amount of power under the curve is much greater than I had before.
Name:	Darcy + Plenum 0-130 kW.JPG
    This is the same Darcy pipe and Trombone header simulated with a 2L Plenum, the combination bumps it into the low 30's.
  13. #7273
    Jeremy McWilliams put one on pole once,can't remember where. So it must have gone well at least that day.
    He would have looked a bit younger than this though.
  14. #7274
    EngMod2T
Name:	1-4 Delivery Ratio.JPG
    I remember there was a bit of a discussion about whether the expansion chamber supercharged the engine when it is in resonance.
    Well at a delivery ratio of 1.4, the pipe must be doing something.
  15. #7275
    Jurgen van de Goorbergh finished 13th in the championship in 2001 (looks like the team sat out 4 or 5 GP's) finished best of 7th and worst 13th. Up against 4 factory NSR500's and 6 factory YZR500's and 2 factory RGV500's with the best riders the factories could afford on a self built bike with a rider they could afford, is pretty good in my books.
