so you will run a TPS on a splitter cable or whatever & anything less than full run a rtd curve. Would like to see how that goes.
The more tec posts from the last ten pages.....
Husabergs post is worth a look.
More work on the triple port cylinder.
Ring ends just meet on the bridge between the boost and B transfer port. The other lines are so I can drill oilers for the bridge between the ex port and main transfers and make a port in the piston for the boost port.
Piston protrudes 1.2mm at TDC.
Lower cooling fin is 2mm thick.
Later on I plan on using a head gasket to thermally isolate the top copper cooling fin and head from the lower copper cooling fin and cylinder so the head can run cooler than the cylinder.
Checking the squish clearance, and yes its 0.8mm.
How the two copper cooling fins stack on the head leaving a (will be) polished alloy combustion chamber.
http://www.youtube.com/watch?v=oVOxa9I2Obs
In reference to the tasty beverage in the last pic
After we get the triple port and Pirana pipe testing out of the way I want to try my hand at one of these Trombone pipes. They look like the key to making an all conqering 2-Stroke.
The plan is to make a pipe that works well down low and then use the Trombone effect to get lots of extension of the working range. Not so much about peak hp numbers, that 2-Strokes can be good at but dramaticaly increasing the area under the power curve.
I need a Trombone section that can collapse 130mm, now there is the trick, how do I make that .....![]()
Have you given any thought on the setup yet?
The dutch racer has a backward facing cylinder and a straight pipe, which makes it quite "easy" to vary its length.
On a curved header it will be challenging to come up with an efficient moving system. I like it! :d
One possibility is to use one of those water cooled after market 50mm big bore kits you see advertised for scooters and fit it backwards on the GP cases and have a 100cc water cooled screemer.
Or I could make a pipe like this one, as there is plenty of room in front of the engine I could use the the first part of the pipe as the Trombone. Or even the vertical bit could slide in and out.
This is one of Speedpros pipes where the muffler comes forward instead of pointing out the back. Its pretty easy to see that if the back could pivot, the front Trombone section could move up and down easily with the pipe pivoting at the back.
A "Real Mans" dyno .....
First run 19.9 hp second run 23 hp.
Actually not to hard to make with a disk brake for an energy sink and a load cell to measure the torqe.
I am sure some pics of the bikes or engines have been added before a British attempt at a prepackaged Rotax tandem twin TZ beater from the 80's made in both 250 and 350cc.
Lozza will be well aware of this When i was looking for pics his name pops up quite a few times.
One thing i have not picked up on is they had mirrored disks on at least one of the bikes.
I always thought the rear disked Derbi or Aprilia was strictly for packaging?
but was it mainly for a better transfer layout with more symmetry as well?
Possible advantages with the twin disk i can see include a symmetrical flow and the inlets would be smaller so less obtrusive to the transfers.
It should also possibly offer better drive-ability( it does of course fail the KISS test though.)
Frits I think posted a twin disk 50 done in the 70's.
oh to fit the trombone pipe in why not tip the motor forward TZ it has advantages being a disk valve with the side sucker carb.
The gearbox breathing and oiling will need work and the ground clearance might suffer a bit.
and yes the selector will be a bit in the way not as neat as the Rumi which was a reverse cylindered design as well.
That dyno run looks more like a Hitler gas chamber than a dyno cell.
With the header leaking like a sieve and the carb sucking dirty air, no way is anything repeatable going to happen.
Here we go, a simple disk brake dyno.
