Page 498 of 2773 FirstFirst ... 3984484884964974984995005085485989981498 ... LastLast
Results 7,456 to 7,470 of 41581
  1. #7456
    Quote Originally Posted by casal-fan View Post
    The back squating, appears to be a manifestation of center of gravity shifting backwards, thus removing weight from the front wheel...???
    Sorry, I´m not getting it.
    Sorry, I hadn't realy thought about it and should have explained that the squating compresses both the front and back suspension. I think the bike basically hinges in the middle at the swing arm pivot and the whole bike squats down. I will try and get a video clip of it next time its on the dyno and then we can see for sure whats happining.
  2. #7457
    for those fans of TT3D close to the edge
  3. #7458
    ... the squating compresses both the front and back suspension. I will try and get a video clip of it next time its on the dyno ...
    Its possible that the front suspension is compressed as a reaction to the bike driving the dyno drum around.
  4. #7459
    Instead of shortening the frame to redistribute the weight , why not move the fuel forward you could put it up by the steering stem just inside the frame rails that would move 2 or 3 kg forward, maybe but the battery in there as well, adjust the bars so you have more rider forward, motor can stay where it was happy
  5. #7460
    my rs would rise up as the back wheel moved closer to the frount wheel pushing the seat and tank up
  6. #7461
    7th November 2011 - 01:38
    CASAL K270
    braganca
    Maybe the piece that is missing is simple.
    Squat alone, will unload the front wheel. But there are countermesures in the chassi design to control squat, and reestablish chassi geometri.
    Simplyfied, these countermesures would be swingarm angle, lenght, and chain sprockets position in relation to each other.
    Saying that squat alone will not unload the front wheel, might cause misunderstandings.
    http://www.youtube.com/watch?v=XflVAlCbIKI
    In this video, the machine is fastened very close to the swingarm pivot point.
    Watch how the front compresses when wheel is under acceleration. In a normal dinamic situation, rear squat would occour.
    Rear squat, combined with chassi contermesures, and chassi tune would have something to say in a out of corner acceleration f.exe.
  7. #7462
    Good video, yes my bike compresses the forks like that, will try and get a video next time.
  8. #7463
    The back squating under power is a function of the top chain pull force vector pulling the rear wheel upwards, not a C of G shift issue..
    But get the front sprocket position in relation to the wingarm pivot correct,and you can reverse this force and produce anti squat.
    This is why many production type class racers convert to way smaller front and rear sprockets, it lowers the top chain pull.
    Look up the many references to anti squat geometry, its easy to understand when you see the forces at work.
    I first saw this at Fast By Ferrachi in USA where he had a 916 on the Dynojet.
    By simply moving the swingarm pivot up or down, they could make the rear drop, or rise under full throttle power runs - the bike effectively didnt move at all to change the C of G - it simply raised or dropped
    the rear due to chain pull.
    Rear squat that cant be dialled out by geometry change, can be ameliorated by adding some rear preload and some more compression damping.
    We did this on Discombes TZ350 , then he went from not just winning Junior Pre 82 , and breaking lap records,to getting to the front of Senior as well.
    An extra 3 turns of rear spring preload and 2 com clicks stopped the rear squat from unloading the front, that even with emulators would go mad as he came off trailing throttle into the power on sweepers.
    With the new setting he can power drift both ends, mid turn, with the throttle pinned.
  9. #7464
    Performance bikes (I think)did a write up on dialing out squat in relation to the Kawa ZX900R.
    The initial 900 suffered a lot from squat it unlike the ZXR750 was not equipped with an adjustable swing arm pivot.
    If we were to take a look at pretty much all the Gp500's and most all the superbikes from the 90's on, the GP500's also had movable engine mounts for the most part had this feature.(they incidentally alleviated the situation with a new shock with more comp damping and and link plus a different counter-shaft sprocket)
    A notable exception was the Honda RC45 and look how long this took to get right and in the end it needed a 5 foot psycho.
    I am not say the bucket needs it as moving the engine is a much better idea.
  10. #7465
    This is cool..
    It confirmes my theories about how 'wheeliehappy' different chassies are.
    I have on my MB5 raceproject made adjustable brackets för swingarm.
    Very very simple and only three different holes to choose from.
    It´s a test this summer.. i´m hoping i´ll manage without wheeliebars just to get the look of the bike correct
    Rgds.
  11. #7466
    2nd bump. I don't want to run thrust washers if I can avoid it.
    ok, a question for the panel;
    So I'm left with the suitability question over 17mm wide MB SE bearing in a Yam piston with 19.2mm between the bosses, so 2.2mm clearance. With a wider rod it should not make it out of the small end.
    I'm not overly happy with the 2.5mm rollers (making for a 14x19 bearing) that only has 11 rollers, but they seem to go ok in std bikes. Most of the 18x14 brgs seem to run 12 rollers.
  12. #7467
    Year: 1991 HONDA RS125R
    Item Specification
    Wheelbase 1,260 mm
    Dry Weight 68 kg
    Half dry weight 71 kg (156 lbs)
    Frame Caster angle 25 °
    Trail length 95 mm
    Suspension-Front Telescopic 90 mm
    Suspension-Rear Swingarm 110 mm
    Fork oil capacity 210 cc
    Fuel system Fuel capacity 12 liter
    1997 Honda RS125 Specifications
    Item Specification
    Wheelbase 1,215 mm (47.8 in)
    Front suspension Telescopic, inverted type
    Rear suspension Swingarm, Pro-link
    Fuel capacity 13.0 liter (3.4 US gal)
    Caster angle 23 ° 30'
    Trail length 84mm (3.3 in)
    NSR MC16
    Wheelbase 1360mm
    Seat Height: 750mm
    Weight: 125Kg
    Castor: 26° chopper like
    Trail: 103mm as above
    My NSR MC21 Frame
    Castor 23° 15'
    Trail: 87mm
    Wheelbase 1340mm
    Seat Height: 770mm
    Some basic data on my FZR250 3LN Frame:
    Caster Angle 24.5 deg which is 0.5* less than a 91 RS125 @25*
    Trail 87mm which is 8mm less than a 91 RS125 @ 95mm
    Wheelbase 1,375mm which is 115mm longer than a 91 RS125 @ 1,260 mm
    Front fork travel 130mm which is 40mm longer than a 91 RS125 @ 90 mm
    Fork Oil 10w
    Front Spring Rate 7.8N/mm
    Rear wheel travel 117mm which is 7mm longer than a 91 RS125 @ 110 mm
    Shock absorber travel 50mm
    Spring free length 173mm
    Fuel Tank capacity, 14Ltrs
    Original dry weight 146kg, oil and full tank 166kg
Name:	3LN Rolling Chassis.jpg
    Some other quickly measured comparisons.
    Rear axle to swing arm, 3LN 510mm 91 RS125 455mm
    Front axle to swing arm, 3LN 860mm 91 RS125 815mm
    Seat Height, 3LN 730mm 91 RS125 675mm
    Foot Peg to Seat 3LN 415mm 91 RS125 340mm
    Front Axle to crank 3LN 630mm 91 RS125 480mm
    And Stearing Head to the front of the Seat, 3LN 630mm 91 RS125 630mm
    So I wont be shortening the chassis rails to bring the front wheel back but I might shorten the forks to lower the front end and steepen the caster angle. Also reducing the height of the tank and implementing some of Yow Lings weight forward suggestions and Richbans rear end lightening ideas could be the go.
  13. #7468
    Caster Angle 24.5 deg 22 deg
    Trail 87mm
    Wheelbase 1375mm 1275
    Fork Oil 10w
    Rear 117mm
    Original dry weight 146kg, oil and full tank 166kgn 75kg
    A bit easier to do with the computer than for real
    NSR MC16
    Length: 2035mm
    Width: 705mm
    Height: 1105mm
    Wheelbase 1360mm
    Seat Height: 750mm
    Ground Clearance: 135mm
    Weight: 125Kg
    Fuel Tank: 16 litre (primary)1.2 litre (reserve)
ID:	263327   Click image for larger version.
ID:	263328   Click image for larger version.
ID:	263329   Click image for larger version.
ID:	263330   Click image for larger version.
ID:	263332   Click image for larger version.
Name:	Waddon frame 2.JPG
  14. #7469
    My NSR MC21 Frame
    Castor 23° 15'
    Trail: 87mm
    Length: 1975mm
    Width: 655mm
    Height: 1060mm
    Wheelbase 1340mm
    Seat Height: 770mm
  15. #7470
    Fork Oil 10w
    I would be interested to see the measurements against the NX4 in the ESE stable.
    I found this on the Speedpro's thread (i hope he doesn't mind) i also seen this Lovely RS50 framed H100
    2001 2003 RS50 Aprilia
    24 rake
    Trail 102mm
    Wheelbase 1280mm
    120mm front suspension travel
    110mm Rear suspension travel
    Coments re Speedpro FZR framed Bucket.
    I've made changes to the riding position. Avalon commented it was like riding a couch with the seat and handlebar positioning. Because of that I've put the original FZR seat back on the bike rather than just sitting on the fibreglass tailpiece and placed the handlebars under the top triple clamp in the original position. Basically it's back to a stock FZR250 riding position. After riding the scooter all week it has a definite head down arse up feel to it. It was OK at the track today and I'm gonna give it a go tomorrow but my thoughts are that the handlebars are going back on top of the triple clamp. For some strange reason I was uncomfortable in the right onto the back straight, running clockwise, and tended to run wide. It also feels like I'd have less chance of saving it if something happened. My right wrist was letting me know about it as well as it's still unhappy after a big crash 30 odd years ago. It "looks" right so I'm thinking it's just me. My son has also commented that I sit upright more than others. could be that I know something others haven't figured out yet though that'd be a first.
There are currently 61 users browsing this thread. (0 members and 61 guests)
