Page 516 of 2773 FirstFirst ... 1641646650651451551651751852656661610161516 ... LastLast
Results 7,726 to 7,740 of 41591
  1. #7726
    no one has got more than 30 H/p from one yet (that I know of)
    and starting over again with a new engine (what would Burt have said)
    Yet
    And Burt had the Velocette as well remember.
    From what i understand it was the Worlds Fastest Vellocette as well.(according to Ivan Rhodes)
    Not bad for a old fella from invergiggle.
  2. #7727
    Yet
    and if you asked anyone they would have asked WHY and said it cant be done
    or thats not the way to do it. you mow the lawn not BURN it.
    I did hear that TZ is now doing somehthing different ( still the same engine )
  3. #7728
    Is that potentially a better all-round configuration ??
    100cc H2O pumper, well thats plan "B" and I have box's of parts put aside just in case I have to go there.
    What would the result be with a 100cc engine ,watercooled, with no carb size restriction.
    Well, its easy to see, here is a dyno graph of the best 100cc H2O pumper that I know of.
    Speedpros 30 hp 100 compaired to several runs of my 28.9 hp air cooled 125 configuration. I like the torqe curve of my 125 better. Reliability, well it did several Mt Welly meetings and ran all day when the Bucket GP was run on the old Taupo track just before last Xmas. All that was before I swapped the cylinder for one ported for 31 hp which failed at Kaitoki.
    I am having way to much fun pushing for a reliable 32-34 with an equally good power spread to want to change tacks at the moment. And if anyone wan'ts to know, those consistant 28.9 hp runs were done with a 24mm HL 360A Tillotson go kart pumper carb.
    Tillotson HL 360A 24mm
  4. #7729
    It's those fancy forks, they've made him go all Honda
  5. #7730
    It normally starts with a few Honda bits here and there and then snowballs until it ends up like (Name deleted) Er... Non Honda.
    where the only Yamaha bits left is the piston.That it seem is even trying to get it self replaced as well.
    Last edited by husaberg; 22nd May 2012 at 23:32. Reason: No offence intended to all those Honda engined, Honda framed, Non Hondas out there.
  6. #7731
    Well here is a dyno graph of the best known 100cc H2O pumper.
    Speedpros 30 hp 100 and my 28.9 hp air cooled 125 configuration, I like the torqe curve of my 125, and it did several Mt Welly meetings and ran all day on the old Taupo track Bucket GP before last Xmas before I swapped the cylinder for the 31 hp unit.
    I am having way to much fun pushing for a reliable 32-34 with an equally good power spread to want to change tacks at the moment. And if anyone wan'ts to know, that consistant 28.9 hp was run with a 24mm HL 360A Tillotson go kart pumper carb.
    That was my experience with the big MB...not a lot more HP but much better torque. This is where you may start to look hard at matching tracks to motors. The better torque of the 125 suits Kart tracks and the 100's work well on big circuits where you're on full noise most of the time - and the water cooling gives them potentially better endurance.
  7. #7732
    not bad for a Yamaha man with a suzuki bike
    now what aircooled rotary valved hondas are out there so he can go all the way
    I did hear that he was going back to suzuki for some bits
  8. #7733
    Totaly agree, its starting to look like the air cooled 125 could be good on short circuits and a water cooled 100 for the longer tracks.
  9. #7734
    Totaly agree, its starting to look like the air cooled 125 could be good on short circuits and a water cooled a 100 for the longer tracks.
    Maybe not.
    Quote from Bucketracer
    The tide might be turning.
    2-Strokes in the points racing at Mt Welly yesterday, and about time .....
    The Dominic Howe was won by Dave M riding an MB100 powered RS50 prepaired by Speedpro with a 25hp 80cc stroker runner up.
    And F5 was 2-Strokes 1-2 all day long.
  10. #7735
    Ok changed the ports and skimmed the top of the cylinder to get the squish closer to 0.6mm
    All this to take 0.35mm of the top of the barrel, we do go to some trouble to get the details right.
    The split ring held the cylinder central and the pull back held it secure and square in the chuck. The pull backs foot is across the main transfer ports and the threaded rod goes right through the lathes head stock and is pulled up with a nut and spacer at the back.
Name:	Barrel Skim 005.jpg
ID:	263993   Click image for larger version.
Name:	Barrel Skim 001.jpg
ID:	263994   Click image for larger version.
Name:	Barrel Skim 002.jpg
ID:	263995   Click image for larger version.
Name:	Barrel Skim 003.jpg
  11. #7736
    So TZ , say you were thinking of making your own barrel , engine or even spacecraft. You could read this thread http://www.homemodelenginemachinist....?topic=18727.0 and steal and adapt some of this guys rapid prototyping ideas.
  12. #7737
    Thats some clever idea, and plenty of links to other casting methods, well worth a very carefull read. Thanks.
  13. #7738
    That is real neat.
    I guess by now most people know that is similar to how some of the patterns for the Britten V twins were done.
    Except the crew used thin plywood sheets they scaled the pieces off the blueprint cross sections and glued them together allegedly
  14. #7739
    Front wire wheel 9.0kg
    Rear wire wheel 9.5kg
    Front FZR wheel 9.0kg
    Rear FZR wheel 12.0kg
    HONDA CBR 400 NC23 FRONT Wheel 3.5X17
    HONDA CBR 250R MC19 2.5X17
    Bare Std RS Front 2.7kg
    Bare Std RS Rear 3.2 kg.
    Complete RS Front wheel 8.0kg
    Complete RS Rear wheel 9.5kg
    Wire complete Front wheel 9.0kg
    Wire complete Rear wheel 9.5kg
    FZR complete Front wheel 9.0kg
    FZR complete Rear wheel 12.0kg
    Complete RS swing arm 3.5kg
    Complete FZR swing arm 4.5kg.
    CBR250r wheels complete with disks tires spockets etc .
    Front spoked wheel:
    11.1 kg 3-spoked cast wheel:
    10 kg 6-spoked cast wheel: 10.5 kg
    Rear spoked wheel:
    13.1 kg 3-spoked cast wheel:
    13.8 kg 6-spoked cast wheel: 13.9 kg
    A std ZXR750 front wheel from the 90's is 4.5 KGs (bare weight)
    Attachment 263841
    RS Front 7kg
    Attachment 263842
    Complete rear with sprocket carrier 7.2kg
    Failing that two matching 3.5"x17" fronts from the Suzuki GSXR range or Honda CBR for adapting to the back of the Beast.
Name:	Suzuki 3-5x17 Front 001.jpg
ID:	264015 Click image for larger version.
Name:	Suzuki 3-5x17 Front 002.jpg
    Bare front GSXR Suzuki 3.5"x17" 4.5kg
  15. #7740
    Hmm, where did that GSXR wheel come from? I sold one last year on TM.
