Page 529 of 2773 FirstFirst ... 2942947951952752852953053153957962910291529 ... LastLast
Results 7,921 to 7,935 of 41593
  1. #7921
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Attachment 264865 Av making us all proud
    Fantastic news :-)
  2. #7922
    golly, they make those Italian wimin tall
  3. #7923
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    And you can watch it here .....
    Stephen
  4. #7924
    Well I got bored & fast forwarded to the end, but Still didn't see any tall Italian wimin.
  5. #7925
    Enfield cr250r
    Tokyo
    How about this one then
    Babay goes BANG
    Stephen
  6. #7926
    ok that was more humour,.
  7. #7927
    [QUOTE=Brian d'marge;1130339424]How about this one then
    Babay goes BANG
    Stephen
    My 50 did that at Ohakea. KERBLAMMO!!!!!
  8. #7928
    and my 50 did that at Foodtown carpark in P.Nth (back in the days of no sunday trading). Leg out of bed & Gossimer cartwheeled over me & landed on top of my bike which was in turn on top of me. His bike made a break for it & continued on.
  9. #7929
    Most FXR owners will at some stage of their bucket career will experience that
  10. #7930
    MARVIC WHEELS
    1989~2009 MARVIC PENTA 17" x 2.5" FRONT WHEEL £425.00 + VAT
    Approx 2.5kg - including tyre valve & wheel spacer
    1989~2009 MARVIC PENTA 17" x 3.5" REAR WHEEL £500.00 + VAT
    Approx 3.0kg - including tyre valve & sprocket cush drive rubbers
    1989~2009 MARVIC PENTA FRONT & REAR WHEEL SET £895.00 + VAT
    NEW MOTARD WHEEL FRONT/REAR 15MM AXLE SLIDE KIT
    it was on aust Ebay a while back DHZhttp://www.ebay.com.au/itm/NEW-MOTAR...item3a6f4d1ac1
    NEW DHZ FRONT & REAR BRAIDED BRAKE CABLE LINE KIT
    Front & Rear Braided Brake Cable Line Kit
    Rear Brake Cable: 60mm
    Front Brake Cable: 95mm
  11. #7931
    No bullshit - but no sigar either, Wob. It is simpler than that. The inhaled air enters the duct from all sides (hence the positive effect of a bellmouth),
    but the blow-back shoots back out in a single column that hits the piece of paper in the video.
    (Of course no running engine can blow back more air than it inhaled ).
    Clever but wouldn't the air passing back through the carb venturi also have an effect when the air is blown back????
    Plus wouldn't it be sucking over a longer period of time (A long deep breath)than it was blowing back (a fart)
  12. #7932
    Yes, but that's all in the game of finding a jetting that makes the engine happy.
    Plus wouldn't it be sucking over a longer period of time (A long deep breath) than it was blowing back (a fart)
    Depends on the rpm; at low revs the crankcase is filled long before a piston-controled or disk-controled inlet port closes. The kinetic energy of the blow-back may even create an underpressure in the crankcase. And if the revs are really low, that underpressure can cause a restart of the induction process so that the engine inhales once, blows back once and inhales a second time, all within one inlet open period.
  13. #7933
    29th December 2011 - 04:14
    rd 350 ypvs 1985
    netherlands
    In the light of this, does it make sense to think this could also happen with a membrane inlet?
    This is the second go on a different RZ with a given carb and its again the same deal, have to use a realy lean pilot jet (because of double dipping ?) but then when opening the throttle the slide needs to be really rich (since no more double dipping, then the pilot shows it's true colours?)
    And, if all that is true... what would one do about it or is it just a case of jet accordingly?
    edit: seems the case only with this type of (modded) carb btw
  14. #7934
    air leaking past those bored 26mm carb slides?
  15. #7935
    rd 350 ypvs 1985
    netherlands
    No, vm28's with dave f mod. (basicly making them like yds7/ yr5) Thing is, I seem to be the only one encountering this as far as I can tell. Prolly something stupid on my side but can't figure out what
