I had some bored out 28s on my RZ (back in the day) & every time I put them on I developed an electrical fault. Ok it was only twice, but enough to make me lose interest in them again.
Page 530 ....
Poly Quad 4 Valve Head .....
Back to det sensors
Well I got a Subi one. But now I pull the munted plug off it only seems to have one wire, so I'm assuming that it just grounds on the base & the piezo generates a voltage & the ignitech senses that.
Hmm, throw it on the scope & give it some quick taps & it can produce ~ 7V p-p.
So there is a 2 wire one? how could it be different? Presumably when you configure the igni input to retard it configures that port to an A-D, so senses the voltage spikes and interprets that as detonation. I guess there is some algorithm to ignore engine vibration. it would have been nice if one could have an output from this to drive a LED indicator so when it is retarding you know about it.
I suspect if you connected a LED to the det sensor there would be enough noise you wouldn't believe (ie no algorithm) it & there may not be enough omph to drive it without extra cctry, though it did sink into a 1k resistor & still produce voltage. However I have no idea how much it will produce under real running detonation conditions rather than me hitting it with a small screwdriver blade.
Can you see on the PC when it is retarding?
Hi Dave, I think it all works on the frequency of the vibration, an engine at 12,000rpm is 200 hz and detonation rings at a much higher frequency, like 1-10kHz. The detector attached to the knock sensor must be responding to the frequency of the vibration, and not the p-p amplitude.
http://www.bosch.com.au/content/language1/html/4563.htm
12k/60, yeah, so just passes out low freq stuff
My subi peizo is a Unisia Jecs, not a Bosch after all, can't find any info, but surely a simple device.
I bought a Subi TPS at the same time for giggles as there is no room for like an RGV splitter box in the RS. I'll have to pull it with a cable, so just have to screw it to a plate & make a pivot arm. Possibly not as simple as I hoped now I have it in my hand, but possible & can hid it under the seat out of the way.
Seems to be some confusion here.
The det sensor has to be connected to the knock gauge I posted the link to on here a while ago.
This has the filter on board as well as led indication.
And if you buy the option of a current sink to ground wire it will drive the retard input on an Ignitech, when deto is seen within the sensitivity range..
Yes any Ignitech input config is shown on the PC screen when it is grounded.
Knock sensor needs to pass through a tuneable band pass filter, seem to remember Jaycar sell a tuneable unit. Will see what I can find.
Yeah, I 'm with Kel; it's about frequency, not voltage amplitude. So, logically, there should be a Fourier transf circuitry and the band-pass filter - all either in physical or pc program form.
I believe it can be done if you know some electronics -and internet browsing-, but the result might not be worthy of the time spent.
The one Wob informed us about has a reasonable price, so why not?
edit :
I don't quite remember at the moment, but there must be some knock signal examples at the Labview website at NI. And some (a little more sophisticated) knock program examples in their forums.
I had the Jaycar page saved in my bookmarks, but it's seems to be no more: http://www.jaycar.co.nz/productView....k&form=KEYWORD
It must have been this one : http://www.rhinopower.org/knock/knock.html
ahh, I see, the inputs aren't as smart as I thought. I have a plan B, but we'll see where that goes.
Heck I should really be in the garage sorting out plates for the engine mounts or I won't even be able to start it once the engine is done. Pretty cold though.
. . . That shit's Nasty.
Just an addition here:
There this "inexpensive" Selettra ignition coil from the IAME X30 karts, here: http://www.ebay.de/itm/ws/eBayISAPI....ht_3433wt_1139
You can ask the seller to send around (he sent mine in Greece at least).
I don't know whether it's a top choice coil, but based on the fact that it comes from a high revving competition engine and that Selettra is a known company, it could be. Perhaps the elders can confirm -or not!
Funny, I've got a few of those too, I guess they are pretty common considering the engine is likely to die well before anything else.
EDIT: I once bought a complete "running with a knock" VT250 for a packet of biscuits. I got it, took of the mirrors and a few other bit I wanted off it then contacted the local wrecker.
I said: come and get it for free.
The reply was: "shoulda kept the bikkies".
There are currently 67 users browsing this thread. (0 members and 67 guests)
