Page 541 of 2774 FirstFirst ... 4144149153153954054154254355159164110411541 ... LastLast
Results 8,101 to 8,115 of 41608
  1. #8101
    4th November 2003 - 13:00
    BSA A10
    Do tell, think Bert had used these guys or similar. Have you sent them cad files & gotten a rad? My 496 could do with something bigger, but I'm getting short of money again. I'd precluded a custom rad until I heard of the prices out of Ch.
    We built our own for the Superkart I ran, think it was an alloy Commodore core for about $120, split it down the middle and welded our own tanks to the ends, Commodore core would probably to long for your bike but it's just a matter of finding the right core
  2. #8102
    1st June 2011 - 14:39
    Honda NC50
    Straya
    hang my head in shame for not getting 100Hp AND 100Kg, just talk as usual it seems.
    How can you live with yourself. Back to the drawing board I guess.
    While the rest of us marvel at those figures!!!!!!
  3. #8103
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    bored
    send pm when something interesting happens
    for example ,,if u want a cylinder designed
    Stephen
  4. #8104
    20th June 2012 - 00:17
    yamaha
    OK - here is the biggest fuck off imaginable to those people that think a 4T is anything but a heavy pig on wheels.
    RZ400 first dyno test - peak torque at 9200, peak power at 11200 - 6th gear run fully loaded, and HOT - and 45% humidity.
    Only 96 Hp in a 100Kg bike - am I still full of shit Mr SV650 Helper.
    Show us your dyno curve - full throttle at 4000 to red line, and how much does it weigh???
    I just bought a set of carbon BST wheels off Aprilia factory bike, just in case we are too heavy,and cant dive under the pigs into the sweeper at Hampton, like Discombe does on my TZ in pre 82 - running wire wheels on a C model,
    breaking the lap record - and he is only 69 years old.
    And your claim to fame is ?????
    No answer - funny that.
    Good effort. Nice wide power band on it. I would love to see some video of it on the track when its all done
  5. #8105
    "Pig on Wheels" someone certainly deserved that, but this is where I have to hold my hand up and say I am very impressed by the frame building and general engineering skills that have gone into some of the 4-Strokes and I think that talent should be appreciated.
  6. #8106
    11th July 2006 - 17:01
    FXR1fiddy
    Albany, Auckland
  7. #8107
    What is outrageous is the 400's curve just seems to go on.
    So that was with the FCRs, you had talked about trialing some of those adjustable pjs, but surely this has a solenoid pj?
  8. #8108
    Re the small end question.
    Sounds exactly like all the RD - RZ Yamaha setup, where they used a very wide small end bearing.
    Only thing is to ensure that the needle rollers cant sit outside the edge of the rod when sitting in place correctly, or they catch, and shag everything in sight.
    The RZ400 was using 39FCR carbs with the DialAJets mounted.
    I disconnected the fuel tube up to them however as I wanted to nail the main size first, after optimising the ignition curve,and the powervalve map.
    Ran into a problem near the end of the session that wasted a couple of hours to diagnose.
    The oil I was using Elf 909 had separated out in the tank while we had a 1/2 Hr coffee break, and at full noise in 5th gear the engine simply stopped dead during the next all gear run..
    Thought I had holes in two pistons, but after hair tearing out, discovered the bowls were full of straight oil.
    This seems to go back to years ago with Castrol R separating from Avgas, but I think with 46% humidity that evening, and having real touble getting it to mix - it
    needs the old trick of adding some Acetone to prevent dropout.
    I love that oil as it was the best I tested in hours of dyno work with KT100, best power and no skirt scratching from running in a new piston
    The straight synthetic 976 made no more power at 20:1 ( down from 30:1) and every synthetic tested left vertical scratches on the piston when running in.
    Anyway the powerjets were never used, the overev characteristic comes from several hours of juggling the main and air corrector ratio.
    Plus of course the ignition curve.
    The twin blade powervalve is fully up at 10500, and the good mid torque comes from the correct intake length,with a trumpet 60mm long on the FCR front end.
    I could quickly go well over 100RWHp by widening the Ex port out from the 68% it is now - but that setup will be kind on the piston and rings - its a customer bike, and must be dead reliable for a whole race season.
    PS - I agree completely re the great engineering and great engineers work on the 4T designs - but this is a 2T forum and when it comes down to it, with a level playing field the ring ding will win every time.
    All I am doing is using some of the technology freely available to everyone, to produce a race winner in a class that allows a 650 - 4T to be mown down easily by a well built 400-2T - as it very well should.
    Even Stoner says the only reason he would want to stay would be to give him a 500 - 2T to kick diesel arse.
  9. #8109
    Anyway the powerjets were never used, the overev characteristic comes form several hours of juggling the main and air corrector ratio.
    I had heard that the biggest main air jet you can get to work will make the most power with that carb. Did you find any truth in that. Apparently bigger main air jet better atomization? More ponies. Yet to test this with mine.
  10. #8110
    I believe that the better fuel atomisation at the expense of the correct fuel curve would work on a 4T.
    But as a 2T will throw its piston toys out of the cot at the first hint of a lean condition you have to correct the fuel curve to get the egt numbers progressively rising then stay stable in the overev.
    Atomisation takes a back seat to A/F ratio accuracy with a well tuned 2T.
    The FCR is a dead cool piece of kit - every circuit is very sensitive and responds immediately and logically to any small change.
    1/4 turn on the idle air or fuel will raise or lower idle by 200 rpm straight off.
    One main jet is exactly 40* temp change every time - great when you are watching everything in realtime on the dyno and data logging screens, for any indication of an issue or needing to correct a small hole in the delivery.
  11. #8111
    Yeah the small amount of time I have been playing with the FCR I am super impressed. Like you say. All the circuits seam to talk to you in a very predictable way.
  12. #8112
    Enfield cr250r
    Tokyo
    To reply to kicka and bracer , its free to upload a drawing to shapeway ,even easier if you know the volume a cr 250 cylinder would be im guessing about 10 000 yen for the mold then machining costs and casting
    Stephen
  13. #8113
    Quote Originally Posted by Brian d'marge View Post
    Stephen
    that's about $150 nzd wow
    Anyone got the program for a Aprilia 125 cylinder
    Scaled to 100cc
  14. #8114
    Enfield cr250r
    Tokyo
    Scaled to 100cc
    sandstone , is 75 cents us /cm^3 so if you get a cylinder dunk it in some water the overflow or level rise will give u the volume
    THEN it has to be finished for casting and cast THEN machined
    ALSO ...u may get the cock up factor when casting and start machining only to find a crack ,
    the costs might be higher ....
    I have a cr250 barrel somewhere, we could try that I suppose
    Stephen
  15. #8115
    31st July 2005 - 11:15
    a shed full of crazy shit
    Scaled to 100cc
    THEN it has to be finished for casting and cast THEN machined. ALSO ...u may get the cock up factor when casting and start machining only to find a crack ,
    I have a cr250 barrel somewhere, we could try that I suppose Stephen
    I've got a couple (or 5) of RS and TZ barrels; Crazyman has access to a furnace.... hummm I see a plan growing.
    (I'm sure this has been posted before; but...)
    Gabriele Gnani on youTube; the basic how to make a 125 GP motor & Bike. Worth a watch.
    http://www.youtube.com/watch?v=I-2rJtnkYq4 (gets better at the end)
    http://www.youtube.com/watch?v=Lj4h9...eature=related
    http://www.youtube.com/watch?v=A50p3...eature=related
