Page 549 of 2776 FirstFirst ... 4944949953954754854955055155959964910491549 ... LastLast
Results 8,221 to 8,235 of 41630
  1. #8221
    4th November 2003 - 13:00
    BSA A10
    Is Team ESE bringing there 30hp GP125 down to Battle of the Buckets then?
    Maybe they want to bring a bike that will last the distance instead?
  2. #8222
    Yes true .....
ID:	265746Click image for larger version.
    I am not sure, but tell me again, just how many people did she lap before changing gear by hand became to difficult.
    Anyway who cares, just getting there and enjoying the racing, the track and everyones company will be enough.
  3. #8223
    BSA A10
    Probably everyone who finished and beat her in the end
  4. #8224
    25th September 2011 - 10:52
    Windle, MoBuilt, Fireblade, RS250, FZR4
    Dunedin
    hehe sounds mint!
    are you allowed 125 2 stroke in buckets? or.. is it a 4str?
  5. #8225
    BSA A10
    Quote Originally Posted by Fast Eddie View Post
    hehe sounds mint!
    4 stroke to 150cc
    2 stroke air cooled 125cc
    2 stroke watercooled 100cc
  6. #8226
    hehe sounds mint!
    F4
    125cc air cooled 24mm carb (give or take a few cc's)
    100cc liquid cooled open carbs (give or take a few cc's)
    As big as you can get away with foul strokes normally aspirated
    and super or turbo 100 cc foul stroke or there about's
    F5 50cc 2 strokes
    100cc four stroke
    Look at this
    100cc 2 stroke twin
    http://2strokebiker.blogspot.co.nz/2...rd-of-ace.html
    http://www.2strokeworld.com/forum/in...topic=13707.30
    Silly bugger rides it on the wrong side of the road
    worth a watch alledgedly a 100 but if it really is it must be very light in the front and well undergeared
    also note it wheelies past a vespa
  7. #8227
    As for 2 Strokers, I am picking that Brendan from ChCh will be the one to watch this year.
  8. #8228
    20th June 2012 - 00:17
    yamaha
    F4
    F5 50cc 2 strokes
    100cc four stroke
    Look at this
    100cc 2 stroke twin
    Its running two 94cc polini cylinders by the look of it.
    So up from 1o0cc to 188cc
    thats why its pulling up the front end
  9. #8229
    That's why its pulling up the front end
    Yeah you would think so (as do I) but the thread where it is mentioned is adamant it is only 100cc.
    Don't think much of the routing on the exhaust though. You think it would/Should be under the seat
  10. #8230
    yamaha
    The 50cc evo polini cylinder doesnt look like that.
    The 94 does however
  11. #8231
    When I was a Tec at Auck Uni Eng dept in the 80's they had a Ricardo variable compression engine in the thermo lab that I used for checking the octane rating and calorific value of fuels.
    There you are TeeZee the Ricardo is still there and there are other dynos there too.
    Check it out .... http://www.mech.auckland.ac.nz/uoa/thermodynamics-lab
    The Engine research facility is located within the Thermodynamics Laboratory of The University of Auckland and is well equipped to conduct a wide range of engine and fuels research and development.
  12. #8232
    RSA vs RSW125 the diak valve position is an obvious difference Frits has also alluded to rod length and primary comp what are the other differences.
    On the Pitlane thread Frits has shared the port timing for the RSA as being Exhaust 202°, A-transfers 130°, B- and C-transfers 132°
    He has also shared the dimensions previously of the exhaust i also assume was the RSA.
    for which i are eternally grateful.
    What were the other major other differences were there, if its not to much to ask.?
    I always thought the change to the rear mounted disk was to narrow the engine up but was that the only reason?
    Thanks Frits for your time and your patience. I see by read another forum a lot of the questions asked can be quite repetitive.
    Last edited by husaberg; 3rd July 2012 at 08:07. Reason: What port layout, oh that port layout whoops a bit early
  13. #8233
    They gained power doing so, I'll try to dig up that post, will take some time though.
    PS, that port layout is from a 6.6cc RC pylon racing engine, or at least the picture of the cylinder.
  14. #8234
    So, I might have read more into it than there was, anyway, this is the post I was thinking about.
    Quote Originally Posted by Frits Owermars @ Pitlane
    In theory enclosed cranks are good. Jan Thiel did some experiments at Aprilia with a kart engine that had its reed valve at the front: the incoming mixture had to move against the direction of crank rotation. And although the crankcase stretched over the crank webs, reversing the direction of rotation brought another HP. So the crankshaft does have an influence.
    But in practice, if you reduce the distances between crankshaft and crankcase walls to less than 1 mm, the viscous friction of the mixture between the surfaces really costs power at high rpm. And if you make the clearances so tight that lubricating oil can no longer reach the big-end and crankshaft bearings, it will also cost engines
    Another negative aspect: any volume with a narrow 'entrance' between the crankshaft and crankcase surfaces acts as an hydraulic damper on the Helmholtz-resonance in the crankcase.
    Aprilia has avoided this by making the space between the crank webs as wide as the big-end bearing. As a result the crankcase volume of the 125 cc RSA engine at TDC is about 650 cc, so the exhaust pipe really has some volume to breathe from.
    So much for the fairy tale of high crankcase compression
    There might be more on this subject over there, will look around a bit more, if I find more I'll add it to this post.
  15. #8235
    Jan stated that they had flow bench tested the RSW setup, and the rod moving past the inlet port had a big detrimental effect.
    That prompted the beginnings of the RSA project at Derbi.
    Having the carb hanging off the side of the RSW wasnt an issue as far as I know, it was enclosed in an air box, and it has been reported that
    due to the required engine position change ( forced by the front pipe exit ) the RSW had better front end feedback than the RSA ,from more forward
    weight bias.
    Thus though the engine was quicker, alot of riders preferred the RSWs handling.
There are currently 68 users browsing this thread. (0 members and 68 guests)
