Page 572 of 2773 FirstFirst ... 7247252256257057157257357458262267210721572 ... LastLast
Results 8,566 to 8,580 of 41594
  1. #8566
    Had a thought that the issue might be carb orientation, when its tipped over the float level may be changing due to the lever arm
    facing across the bike instead of front to rear as its designed to.
    The Dellortos usually have the floats on rods.
    But I did use a pair of TMX carbs on a Rotax twin in a kart that did exactly the same thing, even with the float rods.
    It would not blip to change gears, and would die after the overun into corners.
    I set it up to idle,and played with the air screw, eventually found that the idle jet and slide were a big mismatch.
    The idle jet was way big and the slide was way lean, so the rich idle was masked by horrible lean on the transition onto the needle4 circuit..
    Changed them a couple of sizes each way, and for the first time I could snap the throttle off idle, and it would spin up faster than my hand and hit the limiter.
    Suddenly it would blip on the down change correctly, and spun up the tyres off slow corners.
    So my guess is to ditch the emulsion tube holes and get the snap response correct off idle.
    Re Frits comment about reinventing the Lectron - its been done already..
    I have been working with APT in USA and that is exactly what they have done, developing small carbs for generators etc to meet CARB regulations.
    The first Billet big set was used at Pikes Peak on a 500 version of my 400, same pipes and ports etc, was easily the fastest,with perfect jetting over a 4000 ft elevation rise.
    I have the first pair of die cast 40mm on the way now to test on the next F3 bike.
  2. #8567
    Had a thought that the issue might be carb orientation, when its tipped over the float level may be changing due to the lever arm facing across the bike instead of front to rear as its designed to.
    It happens on the dyno to, same symptoms but depends on how far it is revved out.
    It would not blip to change gears, and would die after the overun into corners. I set it up to idle,and played with the air screw, eventually found that the idle jet and slide were a big mismatch.
    Yes the pilot jet is big #50, air screw 1/2 turn out, slide a number #3, needle diameter rich.
    Also I have shortened the needle jet so it doesn’t protrude into the throttle bore so much and cut the back away like a regular primary jet thinking that would richen up the transition.
    The air correction orifice was to small and had to be drilled out, so it could be the orifices in the pilot jet circuit are to small too and masking the pilot jet.
    Anyway its handy it does it on the dyno, I will get some spare bits and bobs and have a play.
  3. #8568
    re Frits comment about reinventing the Lectron - its been done already.. I have been working with APT in USA and that is exactly what they have done, developing small carbs for generators etc to meet CARB regulations. The first Billet big set was used at Pikes Peak on a 500 version of my 400, same pipes and ports etc, was easily the fastest,with perfect jetting over a 4000 ft elevation rise.
    Thats very clever, great to see new stuff ...
  4. #8569
    1st June 2011 - 14:39
    Honda NC50
    Straya
    Sorry to be the bearer of bad news but it turns out that four strokes are actually good for something after all...
    [YOUTUBE]84Sm9w65dmo[/YOUTUBE]
  5. #8570
    Now that is clever .... thats real bloke stuff ....
  6. #8571
    [/YOUTUBE]
    Gee "At a cost of nothing from the scrap yard" i wonder how much the lathe cost him then?
    Attachment 266969
    OKO Needle Jet .....
    OK........ As i said earlier the PWK28 has a removable needle jet and holder.
    It also (err maybe i should'nt mention it hasa dedicated foul stroke version.)
    If you look at the pics below you will see why i think the OKO carb TZ uses, is based on the PWK 28.
    Why, because it is the only 2 stroke std Keihin that seems to have this feature removable needle jet and holder.(Not counting the FCR and CR and PE)
    Can you see where i am leading with this...............?
    Some info from here http://www.splatshop.co.uk/sherco-lo...keihin-2t.html
    some from here http://www.motorcyclecarbs.com/Keihi...art__C1281.cfm
    MMM... the extra bits on the dedicated foul stroke .....Wallace?
Name:	TZ's OKO Vs PWK28 a.JPG
ID:	267523   Click image for larger version.
Name:	PWK28 parts.JPG
ID:	267520   Click image for larger version.
Name:	PWK28 foul stroke.JPG
    Attached Files Attached Files
  7. #8572
    I reckon Wob's called it on this one...that is a VERY lean slide IMO. Every 2 stroke I've ever tuned has at some point needed the slides machined to reduce the cutaway hence go richer at that point.
    With this done the ide jet comes back to something reasonable.
    As an aside I remember Dick Hurdeman complaining to me that the idle jets he was using in the BMS Ducai on nitro were so big that raw fuel was running into the motor on braking.
  8. #8573
    I've devconned the bottom of a slide with good results. Reduced the cutaway by probably 50% and it made the transition from off - 1/4 throttle work
  9. #8574
    OK........ As i said earlier the PWK28 has a removable needle jet and holder.It also (err maybe i should'nt mention it hasa dedicated foul stroke version.)
    Definatly based on the PWK28 but is it 4 or 2 stroke? is it the 4-stroke version, how do you tell.
    Agreed, also I think I may have cut the protruding part of the needle jet away to much and left to much area exposed to the air stream at idle. I will fit a new one and modify some slides.
    Good idea Thanks ........
    Will get a chance to look at this when I get back to work next week (been away for a few days). Kel has offered to help and Thomas is putting an electronic det sensor stethoscope thing together so hopefully we can setup the IgniTechs detsensor properly and develop the ignition curve some more and sort this hesitation.
    With any luck it will be sorted for Kel to ride at the next meeting.
  10. #8575
    The foul stroke version i posted were for a Scerco trials bike
    the Normal Keihin PWK28 sold were for a two stroke (Cr85 and so on)
    My thoughts are your OKO is a carb made to work on 2 strokes and four Strokes.
    So there is a compromise try getting a needle holder for a PWK28 from a 2 stroke have a go. What can it hurt.(Make sure it flows enough of course)
    But didn't the symptoms only first appear when you set the rev limiter up?
    The other parts i linked may be an option for Wallace (Marsheng) with is Diesel
ID:	267545   Click image for larger version.
ID:	267546   Click image for larger version.
  11. #8576
    My thoughts are your OKO is a carb made to work on 2 strokes and four Strokes. So there is a compromise try getting a needle holder for a PWK28 from a 2 stroke have a go.
    I have a genuine PWK28 Keihin that I was told was from a 2-Stroke, RM125??? is that possible? and the internal parts look the same as the OKO's.
    No no ... by using the rev limiter we found that if the engine was prevented from being reved right out it didn’t hesitate so much coming back on the throttle but if it was maxed out it was a dog to get going again. We need to fix this as we want the widest rev range possible.
  12. #8577
    Def not a 125 but could be a KR1s or cr85 Rm85 etc.
    actually strip a kr1s and have a look one of the threads linked below say the hole are different on a oko (for a Foul stroke anyway)
    http://www.rzrd500.com/500phpBB2/vie...srx250+petcock
    http://www.kawasakitriplesworldwide....55329&start=15
    Not sure i understand what you mean in regards to the limiter though?
  13. #8578
    The problem happens when shutting of from 13500 rpm but not 11500.
    Thanks for the pictures and your help with this.
  14. #8579
Name:	Carb Drawing.JPG
ID:	267549Click image for larger version.
    I was told the original 28mm Keihin I started with was off a 2-stroke, the internal parts look the same as the 24mm OKO.
Name:	3 Neddle Jets.jpg
ID:	267552Click image for larger version.
    Because I have bored the OKO out in the slide area I shortened the needle jet and cut it back to look like jet (1) but may have taken it to far.
  15. #8580
    Just looking at that link you posted. http://www.rzrd500.com/500phpBB2/vie...srx250+petcock
    I see:- Tuning data: Jetting specs and tuning results will be posted as the bike is set up.
    Baseline will be what the KX85 comes stock with ie. 45/#3 NAPE/140 which should be close. (Keihin jetting is different than Mikuni's) Based on what people run on the KR1(125)/KX100, it will prob be around 42/#2 NAPF/135 but we'll see.
    Which is pretty much where I am on the OKO.
