Page 573 of 2776 FirstFirst ... 7347352356357157257357457558362367310731573 ... LastLast
Results 8,581 to 8,595 of 41630
  1. #8581
    Attachment 267549Attachment 267550
    I was told the original 28mm Keihin I started with was off a 2-stroke, the internal parts look the same as the 24mm OKO.
    So they have the same number of holes in the holder in same places?
  2. #8582
    So same number of holes in the holder and in same places?
    I will have to re check that but yes I think so.
    I read through your links and people report that after a bit of a fiddle they did get their OKO's to work well on their strokers so thats encouraging.
  3. #8583
    Bummer it also looks like the CR85 has at least 4 Holes as well. Not sure re the KX100.
    Anyone got a PWK off a KR1s?
    Chucked in the Sudco Mikuni stuff as well.
Name:	KX100 vs CR85 Wow Honda parts are cheaper though.JPG
ID:	267559   Click image for larger version.
Name:	MIkuni needle jet and holder stuff from sudco.JPG
  4. #8584
    Not sure i understand what you mean in regards to the limiter though?
    The soft rev limiter is currently set at 12500rpm. Previously there was no rev limiter allowing the motor to rev through to 14k or so (no rev counter so this is all going by ear and power drop off and knowing the old dyno curve). The delay coming back onto the throttle is noticeably worse the harder the bike is revved, so while the problem existed last weekend it was almost minor compared to how it was with no rev limiter.
    Now before some says "why dont you set the rev limiter at 10500" ...
  5. #8585
    I'll say it i was thinking it before anyway couldn't the rev limiter be set to work to a lower level at a per-determined TPS position (say 25%)
    That way it should only effect over run.
    But my thoughts were there was a excess of fuel (Rich mixture condition)that needed to be burned off before thew engine would respond when coming back onto the power from a slower corner high over-run revs condition?
    Below Bert or Burt 1972 ish
ID:	267612   Click image for larger version.
ID:	267613   Click image for larger version.
ID:	267614   Click image for larger version.
ID:	267615   Click image for larger version.
  6. #8586
    I'll say it i was thinking it before anyway couldn't the rev limiter be set to work to a lovwer level at a per-determined TPS position (say 25%)That way it should only effect over run.
    No, the IgniTec software does not allow for tying the revlimiter to a TPS position and rpm, its rpm only.
    Bummer it also looks like the CR85 has at least 4 Holes as well. Not sure re the KX100.Anyone got a PWK off a KR1s?
Name:	Needle Jets4.jpg
    The OKO has four holes each side.
  7. #8587
    20th January 2008 - 17:29
    1972 Norton Commando
    Auckland NZ's Epicentre
    Unrelated but I bought an Ignitech ignition off a KB member for my BMW R90, had a few questions about why the program would freeze up.....no replies to email or PM.....got it sorted thanks to Ducati forum.
    Nice bit of kit though.
  8. #8588
    What was the answer to yours freezing up? I am still struggling with ours.
  9. #8589
    PM sent.
    Are you the guys with the dyno Darren told me about.....?
    My BMW needs some dyno time to get the jetting/ignition right.
  10. #8590
    I am sorry I didnt reply to the questions about the software freeze ups.
    I emailed Ignitech about it, as I have been having this issue of late, only since Ignitech have supplied a "one for all " Windoze driver for usb.
    Never had a problem previously, except when using USB in real time with the motor running.
    That is always to do with RF noise going down the usb, and is usually fixed easily enough.
    But I have had no real helpful info from them about constant freezing up for no reason, I havnt been able to solve it myself, so if there is a "fix"
    then many of us would love to hear about it.
  11. #8591
    A reply would have been nice......even just acknowledging you were following up...anyway
    OK, fitted the unit , my mate made up a mount for the pick up...set gap to .6-.9 mm
    Bought a usb to serial interface from Jaycar for $34.00
    Set up the base advance, set up the laptop , you could see the crank speed on the screen,
    As soon as the motor started the screen went " no pc connection' and froze.
    Tried all sorts, running unit of separate 12 volts to starter motor
    After what seemed like hours gave up.....
    Next day as a last resort went to Repco and bought 2 RESISTOR plugs.....like that was going to make a difference......
    Well it did and it works.
    Running dual output coils as was going twin plugs....so earthed at the moment as not needed.
    So there you go....its in the Ignitech FAQ but only as an aside....
    Now I just need my FXR 150 to magically transport itself from Napier to Auckland and I'll be sorted...
  12. #8592
    OK, that is what i was saying about it is easy to fix usb communication issues when the motor is running - I didnt realise that was what you were having as its easy to fix.
    I usually tell everyone that you MUST run resistor plugs AND resistor caps, must have forgotten with your project.
    Or I have tested using spiral wound coil wires,this works real well and means you dont have issues with unreliable resistor caps - but you still must use resistor plugs in any case.
    What is hard to figure out is why we are getting freeze ups without the engine running.
    Still dont know.
  13. #8593
    I had no issues with comms engine not running, I bought a jaycar converter that comes with a CD.
    http://www.jaycar.co.nz/productView.asp?ID=XC4834
  14. #8594
    Um yeah, a couple + one meant for a KX80/5. At home I think (Bert has the other one that was in my tool box as a spare for my 50).
  15. #8595
    Took apart the PWK 28 and found the diffuser has the same hole arrangement as the OKO, no surprise realy as the OKO is a copy of the PWK.
There are currently 73 users browsing this thread. (2 members and 71 guests)
  1. Peter1962,
  2. porttiming124
