Page 592 of 2774 FirstFirst ... 9249254258259059159259359460264269210921592 ... LastLast
Results 8,866 to 8,880 of 41608
  1. #8866
    Have you heard Motocross? Its ruined the viewing experience. Bunch of bikes farting.
    Yeah granted (spend a lot if time with the kids at MX) but at least there still is the 2 stroke shrill in the minis, Plus the MX bikes vary the revs a bit more plus bounce of the limiters a fair bit.....plus the two/four mix is sweet. But the Moto3 is drone city er....Motomonodrone
    Maybe I just wait till I water cool it, I can do that on the 100. - Funny I've kept some of the rubber dampers they come with std in the past, - but threw them out as I could never think why I'd put them back in. . . until. . .
    The Rubbers keep the noise down. The same reason Why Honda added them in the first place.
    The quieter the engine the louder the exhaust can be.whist still not exceeding the noise limits (but you already knew that)
    One thing i really want to know about is Friction minimisation
    Wob has shared some worthwhile gains can be made with ceramic bearings and Teflon seals floating mains etc what else i assume the GP bikes had pressure feed gearboxes what else................
  2. #8867
    remove seals from wheel bearings
    single skinny ring
    no cams
    skinny rider (air friction)
    tyres
    plain chain
  3. #8868
    single skinny ring
    no cams
    tyres
    plain chain
    Ok slippery goop on leathers (Tight fitting leathers).
    Slippery fairing even if they are ugly (only Yams)
    Plain as you say skinny but HD chain with proper one piece bushes non stamped links (the old ones were handmade) new ones ?
    Gee that first yam is still ugly even now.....slippery or not.
    This below is what got me thinking re friction yes its Diesel i have seen other stuff similar re F1 and Indycar and so forth.
    So Read it otherwise the puppy doesn't get parole
Name:	Document (215).jpg
  4. #8869
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    Start of something ?
    Thanks TeeZee..
    The blue print of my new and improved cylinder has been.... well er printed on the inside of the cylinder, it's been dialed in and scribed and I have my instructions, I just have to get hold of the appropriate tuning tools and I will be off and running.
    Photo's will be added as i progress
Name:	Cylinder Porting 002.jpg
ID:	268922   Click image for larger version.
Name:	Cylinder Porting 001.jpg
ID:	268921   Click image for larger version.
Name:	Cylinder Porting 004.jpg
ID:	268923   Click image for larger version.
Name:	Cylinder Porting 007.jpg
  5. #8870
    Thanks TeeZee..
    I see beer and powertools. So its off to a perfect start.......
    Below Kevin Vs the evil Honda mounted Eddie.
    The only Suzuki i really liked. Gee Kevin was awesome to watch then. Crash or Burn (trying)
Name:	Document (212).jpg
ID:	268945   Click image for larger version.
Name:	Document (213).jpg
ID:	268946   Click image for larger version.
ID:	268948   Click image for larger version.
  6. #8871
    1996 Buell S1
    Orewa
    [QUOTE=husaberg;1130385916]I see beer and powertools. So its off to a perfect start.......:
    It's Speights but
  7. #8872
    ... it's been dialed in and scribed ...
Name:	Cylinder Porting.jpg
    Calibrating the Verniers !!!!!!
  8. #8873
    4th February 2005 - 07:32
    Rattlecan blue
    [QUOTE=cotswold;1130385957]
    It's Speights but
    Not beer at all then.
    Stock is best
  9. #8874
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    I saw the photo and cried a little inside... At least it's not a Micrometer.
  10. #8875
    1996 Buell S1
    Orewa
    TeeZee reckoned this would get a response but do not waste your tears as they were not my good ones but a pair of Chinese $12 specials .
  11. #8876
Name:	Cylinder Porting 1.jpg
    I know it looks a bit harsh, but sometimes you have to be cruel to be kind.
Name:	Cylinder Porting 2.jpg
    Cut down verniers are an easy and accurate way of checking port heights and for getting the transfer pairs opening at the same time.
  12. #8877
    Been away winning races so will reply now re the deto box.
    Calibration is easy, turn it down real low such that the green lights do come on when doing a full throttle run.
    Keep turning it up till you get a deto indication somewhere in the powerband, going up on full throttle, or as TeeZee found, when backed off on the overun.
    In short - believe what you are seeing, if it shows deto on the overun, then, its got deto in the overun.
    This MAY not be an issue when racing as you MAY not damage anything detoing for a short period under these conditions.
    But,of course if you have a TPS this means you can use a 3D map, and its easy to pull out a couple of degrees of timing at that point, and the deto will go away - simple.
    I found that maximum performance on the dyno meant you had short flickers of deto at nearly all rpm on full throttle,and it lights up when you hit the limiter.
    I do several pulls at 1/4, 1/2 and 3/4 throttle,running up against the dyno load, as well as running down on the overun. to generate the TPS driven curve shape.
    This enables you to dial up the max advance needed everywhere, then go into the software and back the whole curve down 1 to 2 degrees.
    Now you have a good curve shape that the engine actually needs, and any issues on track, can then be taken care of by the box switching the retard input to pull out 2* to prevent unforeseen meltdowns.
    I havnt used the deto setup on an aircooled, but I suspect that the deto ringing frequency signal is much bigger amplitude than a watercooled cylinder,meaning you get a much quicker indication of deto approaching.
    Means its very sensitive to adjustment, but I say again, if it is flashing deto at one rpm and not at another, then believe what you are seeing, just turning it down so it does nothing, is dumb.
  13. #8878
    I haven't used the ignitech yet (still commissioning the new engine with same peripherals as previous so I know where I am). I couldn't turn the knock down enough so it didn't flash up.
    I'm losing a bunch of power somewhere so I can't say that the bike is running well, but I did gain 2hp leaning & advancing the settings so I can't see it in freefall deto at the start of the session despite gauge screaming it.
    Have to strip engine again, I'm losing 6hp from previous, the engine is no longer leaking but I wasn't happy with the crank & it seemingly hasn't settled in. Crank got wider with looser setting & I think its pushing on the bearings. I would imagine it would be discolouring bearings to lose that much power though. Was pushing against time.
  14. #8879
    The piezo sensor will easily show the missfire from hitting the limiter, so it will also show a big end knock, as well as the piston hitting the head.
    Dont know about excessive piston slap , but probably.
    Plenty of "noise" sources in a 2T.
  15. #8880
    20th October 2010 - 20:59
    Rg50 Fxr's150
    [QUOTE=wobbly;1130386088]Been away winning races so will reply now re the deto box.
    What bike was winning the races?
