Page 613 of 2776 FirstFirst ... 11351356360361161261361461562366371311131613 ... LastLast
Results 9,181 to 9,195 of 41631
  1. #9181
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    The pipe probably helps govern the revs too, I think microlights use the pipe to cap the rpm as well
    You can do that without killing or maiming the power output?
  2. #9182
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    True, but would it account for the carbon in the transfer ports on the chainsaw cylinder .
    I think that blow down is used to limit the max full throttle no load rpm seen by a chainsaw, lawn mower, concrete cutter, weed eater etc.
    Where as the Microlight engine is under load all the time its spinning the prop and at WOT finds its happy place on the torque curve as defined by the pipe and that could be a place where blow down is totally adequate and there is no blow back down the transfers.
    2-strokes, so simple, and yet so complicated.
  3. #9183
    l was thinking about putting a 24mm carb on my brothers rs125 just to see what it could put out
    I would be very interested in seeing the result...
  4. #9184
Name:	Knock Gauge and Counter.jpg
    I have just received another Knock Gauge, this one has two extra outputs. http://www.knockgauge.eu/content/blogcategory/22/41/
    YouTube links showing the Knock Gauge in action.
    The two green lights, the orange warning light then you see the red det light. http://youtu.be/aZkZR-JBr_E and http://youtu.be/vFoZyw_sHmA
    Like last time, one that goes to ground for signaling the IgniTec to retard and a new one that pulses from 0V to +5V each time the Knock Gauge sees a detonation event.
    The Curtis event counter can then count the detonations. Now I have the makings of a det sensor, ignition retarder and det counter.
    Attachment 269009
    703TR002N-512D RS part number 183-5952 $63.50 ... 5-12V and less than 10mA so easily self powered and at 500Hz fast enough to count all deto events as seen by the Knock Gauge or similar, as 200Hz in a 2-Stroke equals 12,000 rpm.
    Attachment 269008
    This post links back to various cheap counters that could be used with the Knock Gauge.
  5. #9185
    If I can get a laptop to talk to my ignitech proper I will have a go at setting the ignition with the amped up earphones on the dyno. The computer I was playing with just kept wanting to install stuff. Hate windows. I have a Mac. or 2. Will let you know how I go Rob. Hp might remain a rumor for a while.
  6. #9186
    I will be interested to see how you get on, with mine, all I could hear was noise, maybe I had something wrong.
    I also had a lot of trouble with my computer freezing up when it was talking with the IgniTec on the Dyno, a 5K resistor plug cap cured that.
  7. #9187
    I did quite clearly hear the knock with Andrews phones last time. It was a manifold leak.
  8. #9188
    I must have something wrong on mine, the pickup maybe. I will have another look at it.
Name:	USB Serial Converter.jpg
    This is a USB to Serial converter I used with the IgniTec, it seems to work OK.
  9. #9189
    The computer see's that there is a serial device there but try's to go looking for software to install the device as fas as I can figure. So the USB connection is working I spoz. Last time I just plugged it in and it worked. But that was with a serial cable. Different computer. So maybe I do need to install something.
  10. #9190
    Maybe just have the bike running hi idle have a listen then undo the manifold clip and start to pull the carb off. Should hear it knock as it leans with all the extra Air. I think.
  11. #9191
    Software that I had to install came with my USB/Serial cable.
  12. #9192
    Making progress on my dyno, would have done more but after getting the big wheels out of the car boot Im rooted !
    lClick image for larger version.
ID:	270756Click image for larger version.
  13. #9193
    That looks like the makings of a pretty decent inertia dyno. Is the disk break for slowing it down after a pull or going to be for holding a load on the motor?
  14. #9194
    could be both, havnt got a caliper yet, the disk is off a v8 commodore. I havnt got much experience with dynos yet other than a few quick runs and one session at the Ashvegas dyno. hope to have the drum finished and mounted this weekend
  15. #9195
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Speaking of dyno's, Kyle and I have almost finished our inertia dyno too, did all the machining last weekend and got the frame together this arvo.
    What software you looking at running Yow?
ID:	270758Click image for larger version.
There are currently 103 users browsing this thread. (1 members and 102 guests)
  1. CrizR
