A sad day for a top bloke RIP buddy.
He rang me a couple of months ago re bringing down the RS125 to sort the ignition, I wondered what had happened to that.
More than happy to help out if Av wants it done.
Sad news sorry to hear. All the best to Av will be some toughf times ahead. Keath seamed a nice guy from few times I had spoken to him.
It's a cruel world sometimes, a sad loss to everybody, a real gent !
At the moment the bike does not even have any real ducting, so yes, it might be time to fit some ducts and re visit fan cooling for purging hot air from between the roots of the fins.
I have talked before about using fans and copper for removing waste heat from the combustion chamber and the thermal gradient involved in pushing the heat to the outer fins.
My latest idea is to sandwich a cooper sheet between two heat sinks in such a way that the copper is positioned very close to the combustion chamber shell and the heat is carried away from there to the outer fins much faster and that would keep the combustion chamber much cooler than if it was just an all alloy head.
If the fins aren't too deep then ducting and big CPU fans could be used to assist the natural airflow to move the cooling air along the fins and purge the fin roots of stagnant hot air.
Another possibility is to use a heat resistant gasket to thermaly isolate the head from the cylinder.
Yes, I think your right, some attention to fin spacing, some ducting and a fan or two would greatly improve the cooling.
Pure polished copper is a good reflector and heat conductor but from what I have read, too soft on its own for a head as the plug threads tend to give way and the head studs tend to crush and distort it.
And copper alloys are not as conductive as pure copper and often much worse than aluminum alloys.
Thermal conductivity of metals http://www.engineeringtoolbox.com/th...als-d_858.html
From experience, the other problem with polished copper is that it tarnishes in the combustion chamber and becomes the perfect heat absorber instead of reflector.
1.5mm of copper sprayed on the head to transfer heat from the combustion chamber.
Polished aluminum does not tarnish in the combustion chamber like polished copper does, but a thin clear ceramic coating over the polished copper chamber surface might fix the tarnishing problem.
Actually, at some points it is profitable to try to retain heat whereas at others removal asap is necessary....
There are a number of heat barrier type coatings on the market now which are showing good results for piston crowns etc - some gains could be expected there.
The multi - metal, add a layer of copper approach is flawed as far as i can see, because every time you introduce another layer the juction between different layers is another barrier to heat transfer.
A well designed sunburst type head with the fin roots actually on the chamber does work well but can be hard to cast...
I would like to keep it all in the super heated and expanding combustion products to help push the piston down but once any thermal energy has leaked into the combustion chamber shell, piston crown or cylinder walls through radiation or conduction the cooling system needs to shed it ASAP to avoid over heating the engine.
There are currently 127 users browsing this thread. (0 members and 127 guests)
