http://www.youtube.com/watch?v=BbUll...ature=youtu.be
This is the 50cc scooter on a shake down for the 24hour
question for anybody who has an opinion,
if you cylinder only has a single exhaust port,how soon would you make the transition from the oblong
shape to the round header diameter?
the port from piston face to start of stub is 20mm,also ,would the aprillia flange missmatch work on a single port?
finally,is there an optimum angle for the exhaust port as it exits the cylinder ?
have been reading this forum for a while now,guess that Frits & Wob would be the guys in the know!
thanks in antiscipation,
chalkie,group 4 Lambretta engine,UK
That's a dangerous way of asking, Chalkie; you'll risk getting all kind of stupid answers, including mine.I would take my time. And if the header is curved, as normally found on a bike with a forward-facing exhaust, it will even flow better if you keep the flattened profile all the way through the bend.if your cylinder only has a single exhaust port,how soon would you make the transition from the oblong shape to the round header diameter?
Funny question, that. I never considered Aprilia a dating agencywould the aprillia flange missmatch work![]()
The optimum roof angle is about 25°; the duct floor should be shaped so that the duct volume is minimal.finally,is there an optimum angle for the exhaust port as it exits the cylinder ?
no particular order and so forth click on the arrow after the posters name and it will lead you to the original post for the additional information.
Nothing to do with ducts
I was sent these pictures of another sweet little F5 bike that is coming together, its made for F5, Mini Motard and Flat Tracking and looks like a very good value for money little racer that's been well engineered, I like it.
After the first North Island round I thought I had better take a look at the Beasts piston top and cylinder as Cotswold had reported a knocking from the engine.
Piston crown and bore look Ok.
Transfer side, the clean outer edge corresponds to the squish band in the head. I have no idea what the other flow patterns on top of the piston mean but they look nice and even.
Head looks Ok, no over heating or signs of the piston touching the head even though the squish clearance is 0.6mm
You have to look deep down in the plug to where the ceramic meets the steel shell to be able to tell anything about the mixture, it looks OK.
This was the cause of the knocking a broken front engine mount. The small side mounts have broken off and the screw driver points to where the main spar is nearly broken right through.
Originally Posted by TZ350
[ATTACH=CONFIG
If you need a spare down tube I cut one off one of my donor bikes
thanks Frits & Husaberg for your prompt replies,was able to cut the exhaust duct this afternoon!
just need to make a new improved stub now,will let you know if it makes more power.
cheers chalkie
This was done to death on some other thread but I can't remember what the outcome was.
And it is not one of our bikes so I don't know what all the technical details are, but it could be a perfectly legal XL, SL, CB100 engine/parts in an XR frame, hopefully the owner will fill us in.
Well the MNZ classifies the XR80 and XR100 as a trail bike. So its pretty cut and dry
So anyone who wants to argue that,they can take it up directly with them.............
Ps Rob tell the guy who's building it that i am pretty sure the MB50 transmission will go in without too much fuss.....
There are currently 48 users browsing this thread. (1 members and 47 guests)
