Page 655 of 2774 FirstFirst ... 15555560564565365465565665766570575511551655 ... LastLast
Results 9,811 to 9,825 of 41608
  1. #9811
Name:	Squish Burn X.JPG
ID:	274210Click image for larger version.
Name:	Squish Burn 2x.jpg
    I am interested in knowing why there is a hot area on the edge of the squish band over the exhaust port. The squish opens up at 3 deg, is this to much?
ID:	274212Click image for larger version.
    The piston looks like it has got hotter (same oil and ratio) but the heat mark is not so pronounced on the original copper head and that didn't have any taper in the squish area.
Name:	Squish Shadow.jpg
    And why is there a shadow (clean area) on the piston next to cylinder wall area between the ports? I would have expected the area in front of the transfer ports to be washed clean from the fresh mixture, not between the ports.
  2. #9812
    Because that Naughty pressure hasn't blown down enough pressure so that the symetrical transfer ports flow in one direction. First the hot gasses try to escape out the exhaust & then when more area is presented out the transfers. For a little while at least.
  3. #9813
    Ps Rob tell the guy who's building it that i am pretty sure the MB50 transmission will go in without too much fuss.....
    Don't waste an MB50 g/box on a diesel
  4. #9814
    I thought you used cast Pro X That piston looks esp Wiseco like with the numbering?
    Oh Dave.... surprised it would worry you, Afterall its only Honda stuff and everyone knows you wouldn't get into bed with the devil would you.
  5. #9815
    We favor Wiseco pistons, the ProX ones we have tried gave problems, one new one even started to crack up after less than 20min on the dyno.
  6. #9816
    No no, its you who is being naughty. Take another look at the small area next to the bridge between the exhaust and transfer. There is that same clear patch wherever there is some cylinder wall between ports, maybe its just that the piston runs cooler there???
  7. #9817
    They are not much good for anything else.
  8. #9818
    Some people like to run them in MB100s. I'd run an MB100 before a 4 banger any day (with the manufacturer name ground off the side of course).
  9. #9819
    Some people do ride HONDA MB100 i guess.
    I can't remember anyone posting this on the thread before.....
  10. #9820
    Maybe, even probably. But not certainly. Clear patches on pistons can also be an indication of hot spots. Yeah, those simple two-strokes.....
  11. #9821
    12th October 2011 - 11:14
    RZ350, RD350LC, RG250
    Canada
    I thought I'd ask the smart people here a question if I may. I've been planning to build a dyno and have been working on design and finding materials. Yesterday I happened across this:
    It's an old Heenan Froude water brake. Funny, it's been sitting in my machinists shop the whole time we were talking inertia dyno design ideas and he never mentioned it until yesterday when we were at another shop having one of his race car motors dyno'd lol.
    I was wondering if, say money were no object LOL, would I be better off converting this with a modern load cell, sensors and software or should I stick to my original plan of an inertia dyno. Or maybe there's a third option I haven't thought of?
    TIA
  12. #9822
    My first brake (we're talking 1978) was a Heenan & Froude, same as yours, only a larger version.
    The main problem was that its torque absorbtion curve was less steep than the torque curve of a racing two-stroke. So either the engine rpm would be stuck at a point somewhere in the torque dip, or it would shoot right past max. torque rpm, past max. power rpm and even past max. mechanical safe rpm.
    A partial solution was to triple the water pressure in the whole system, but stabilizing engine rpm via the brake's handwheel remained a hell of a job.
    My advice: stick to your original plan of an inertia dyno.
  13. #9823
    Dead right Frits.
    All the water brake dynos I have seen that worked well with high output 2Ts needed additional inertia,to enable the operator,or the software
    to adjust the valving quick enough to get anything like a consistent load .
    Even the best well adjusted PID loop control goes bananas trying to hang onto the rate of change a good 2T produces.
  14. #9824
    Canada
    Thanks for the input, I've found a manual for it online and now that I better understand how it works I see that automating the sluice gates, as I first thought I'd do, would be near impossible. Oh well, I own it now LOL. Considering I paid 1/10th what one is for sale for now on e-bay maybe it's OK. It sure is cool to look at anyways.
  15. #9825
    Quote Originally Posted by cookie1965 View Post
    I have an article somewhere i will post it tonight about converting a water dyno to computer controled somewhere it is out of FB (so unfortunatly it is a bit long winded and full of bad jokes etc.) i guess you should cope?
