Page 661 of 2776 FirstFirst ... 16156161165165966066166266367171176111611661 ... LastLast
Results 9,901 to 9,915 of 41635
  1. #9901
    ... if the reduction gears aren't straight-cut, reversing the rotation may cause an unwelcome axial load on the bearings.
    True but as I will be using 17" wheels and chain final drive I am not expecting to be able to use the original scooter gears and may need to make my own straight cut ones.
  2. #9902
    Thanks, like Sketchy I was unsure if it was 2 or 3.
    Attachment 274811
    I can see that 3 keeps the motor turning in the conventional direction, the same direction as the wheels, being anticlockwise in this picture.
    Do you know the overall input/output ratio of the reduction box?
    I would like to run the variator clockwise on the right hand side of the bike.
    My guess is that the variator front pully could be run backwards but the shoes and slots in the rear clutch pully mean it can only be run anti clockwise. Maybe the shoe assembly can be turned around and with straight slots the thing could be run clockwise too.
    You like making things hard for yourself. With straight slots, as suggested by Frits and therefore a more or less constant engine speed setup, it won't matter which way it rotates. Clutch engagement may be an issue. You won't be able to use a HIT clutch for instance. As for the axial loads, the only thing that will change with reverse rotation is the load will also reverse. You "might" have to make a beefier removeable gearbox side cover.
  3. #9903
    And the reason you guys are shagging with a new final drive when you cant get the engine to last for a whole meeting is ????
  4. #9904
    I can't wait .
  5. #9905
    Avoidance of Reality ........
  6. #9906
    That has to be the voice of reason.
  7. #9907
    Every generation has to make their own mistakes, Wob. We old farts have had our share; now it's their turn. (Sorry, I forgot: you're younger than me ).
  8. #9908
    Fucking priceless!!!!!
  9. #9909
    Ha ... yes Wob is younger but I think I am older than you.....
  10. #9910
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    Might be the one race I'd have a chance in.
  11. #9911
    Mr Wob can you please pack up Vanessa's engine.
    send us the price and i will transfer the funds..
    I will sort the fitting and send it back after Xmas.
    I am guessing its well past time, i pulled my finger out and actually did something.
  12. #9912
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    next time as I am running out of places to bruise.
  13. #9913
    25th March 2009 - 23:55
    Honda Cub
    Mars
    Well, after being away from KB for years it seems there's a lot of reading to do! Just jumping to the end of this thread to see what's the latest, and flat out reading everythig to date - I'm up to page 80..: I'm knee deep in two strokes (all sizes) and had a bucket once (XL125S in a CB125T frame - only ever rode it at Ohakea, and it went well - apparently had been a very good machine)...anyway, watching with interest, as I might be needing a bucket soon!
  14. #9914
    Whoa there big fellow. -coming up for four years on KB & this is your 5th post already? Don't want to wear it all out.
  15. #9915
    He's been busy on Facebook
