Posted because someone asked where to find it all, so a recap on the basics of the Beasts Engine. Using Thread Tools and the View Thread Images option is a good way of finding interesting posts.
Some old links, to when we were setting up the port timing for the 30hp Suzuki GP125.
You will have to go to the original post to see all of the pictures and the complete text.
Wobbly can provide the pipe dimensions or even one already cut out ready for welding.
All the port timings are in this post
Exhaust timing on this one.
All the basic info for everything is displayed in the EngMod2T sheets.
The single port is short on blowdown STA.
How to clean a rebored and honed cylinder properly and know you have got it right.
The big hp engine has yet to prove itself.......
Okay i alluded to this earlier on as per usual when i put something a side for later i can't find it
It was a piece written about 500 gp's
the FIM had asked two boffins to prepare and present a paper around the mid to early 90's one i think was dutch the other was English i think.
The formula they came up with was that given equal number of cylinders and open carburetors the fair size of engines 2 stroke vs 4 stroke was this.
360cc two strokes.
500cc 4 strokes.
If we were to break this down and compare to the current F4 sizes it gives this.
current rule.
Rule 24.2 3 F4 2 stroke max capacity for rebored engines 104cc
F4 4 stroke max capacity for rebored engines 158.09cc (note this was initially 130.5cc the 145cc then 150cc previously)
So to be fair, it should be 158.09 cc four strokes vs 113.82 cc 2 strokes of unlimited carb size.
Sorry TZ and other aircolled 125cc restricted carb 2 stokers. You can get plenty of 56-57mm pistons at the moment anyway.
As i said earlier this will allow the use of cheap, freely available KT100 pistons that are available in a number of sizes without the need to destroke.
These strike kt100 pistons are readily available in a huge range of sizes and are incredibly inexpensive.
We all should be using them except for the cost of destoking plus the engine will be less efficient as a non close to square bore and stoke.
Simple fact is 50-50.5mm 2 stroke pistons are not really manufactured any more and it is killing wallets and engines.
Dave had what 2 or was it 3 failures with NOS yz100 pistons these pistons have not been listed by Yam since i was at school.
I doubt Suzuki still makes RG400 pistons, either that only leaves kart pistons (but all the usable size ones have Dykes rings)
and other std road bike (not generally up to it)and Wiesco which are f-ing expensive.and not available freely or in oversizes.
Hold fire: you don't start a LC100 project with your eye's shut (it does require a little bit of preparation to resolve this).
Plently of Engines that would allow easy transformation to 100cc.
RG150: Bore: 61.00 mm Stroke: 50.60 mm (truck loads of these around).
TS125x/r: Bore: 56.0 Stroke: 50.6 mm
TZR125 / Derbi / Gilera: Bore: 56.4 mm Stroke: 50.60 mm
TZR150 tzm / dtr : Bore: 61.00 mm Stroke: 50.60 mm
Mito: 56 x 50.6 mm
Silly size more crank work required:
RS125 (aprilia): Bore: 54 mm Stroke: 54.4 mm
KR150: 59 x 54.4
NSR125: Bore x Stroke, 54 x 54.5 mm
these require less work in the sleeve (offering potentially better heat dissipation) but requires more work in the crank... trade-off's..
Piston wise:
Was it really the piston, really??? (only Dave can answer that); and there are truckloads available if one actually go's looking (I just picked up 4 new pistons for $80 total shipped)..
including after market Wiseco & woosner for the vintage clan (early 80's RM100/KX100/YZ100 & even TS100 options); not forgetting they make a 48-51mm piston for new CR80/yz80's (for kart racing); and all these big bore options for scooters....google..... Dealing with the pin size requires finding one that fits your engine....
Yes, you can still order RG400 pistons (but you could buy 4 wiseco versions above). What's wrong with Dyke rings kart pistons??? or the strike pistons (KT100J)..
Online ordering ~70-$150 shipped to your door; while its a little more than a cheap ass Akunar for a FXR (you could order a AX100 and have the same result)....
Maybe submissions on rules should be undertaken via national committee.....
these larger options are already covered off with the 125cc rule and 24mm carb (weld some fins on)....
Because in reality if one was to start on two stroke, they are more likely to start with a TF/TS/DT/RX/GP aircooled engine; not start building a LC engine straight off the bat...
Unless CC reduction is in order ----> MX80's (not necessarily 85's), where there are a F##kload of parts still available cheap... while offers up a near 2:1 ratio between the 155cc four strokes vs. lc 2 strokes; with about the same power outputs (worked).
Last edited by Bert; 24th December 2012 at 12:00. Reason: censored a little; being a bit harsh
Probably figured it out.
2-Stroke running an unsuitable Cam
No detonation.
No charred oil on the underside of the piston, so not running to hot.
Both Plug electrodes look ok, no melting on the edge of the center electrode and the earth strap looks ok too.
To check the mixture one has to look deep down inside the plug and its easier to cut the insulator out of the plug body.
This is what we are looking for, the area above the black line, and it looks neither rich or lean to me so I guess the mixture must have been ok for best power.
I think the seizure is due to using a piston with an unsuitable cam shape.
It looks like water cooled pistons are not that suitable for hotter running air cooled motors and forged pistons that grow more than cast ones are even more of a problem.
The piston is kept in alignment by the skirt, which is usually cam ground (elliptical in cross section) (fig.12-16).
This elliptical shape permits the piston to fit the cylinder,regardless of whether the piston is cold or at operating temperature.
I think I will have to start looking at using a cast piston with a higher silicon content and giving it a bit more of a cam on the sides.
continuation....
A good MX80cc (pre powervalves engines) engine might put out 18Hp if ya really lucky (20-21Hp with some effort), power valve engines ~20hp (26-28hp maybe with some serious effort).
Most people racing FXR's (at the pointy end) are putting on exhausts, carbs & some are doing cams; resulting in around 19-21Hp; serious effort gets to ~24Hp and all the torque under the sun (its nearly always FXRs up the front with less power than some of the two strokes)..
While F5dave (or others) is bound to post "Flogged out MX bikes" the reality is most engines now used by two stroke bucket racers start there life as flogged out anyway (its a lottery).
Stuffed mx80 Bores are the problem (but re-plating by nzcylinders is going to be cheaper for the masses than sleeving a rare 125 down).
The rest of the parts are on par with currently available engines in use.
Anyone serious about building an engine is going to do the mains, rod & piston anyway (no matter what motor it is) and its not much more effort to do the rest of the bearings in the engine (or find another gearbox)....
if people are really serious about rule changes; then I believe (and others have posted this over the years) 80's really need to be considered (with some restrictions)? things that can be measured easily; exhaust duration & carb size. simple.
Sorry TZ for filling up your thread with this...
What about re-profiling/dressing the pistons on the four corners?
reading about old two-stroke race engines; it wasn't uncommon to read about running the engine in (bring it up to temp), then stripping them down to take the high rubbing spots off the pistons (with wet and dry).
Not that long ago there was an interesting article on Hugh Anderson and his time as a works rider; he discussed personally dressing pistons due to their production shape late at night (when he thought everyone was asleep); only to have the suzuki mechanics somehow replace them before racing the next day--- resulting in seizures (due to suzuki's endless quest for tight tolerances for top housepower).
I was surprised with the clearance specs for the Wiseco pistons (YZ100 aircooled pistons) which I assumed was to deal with these issues (well larger than LC specs); forged piston expansion rates etc (I ended up splitting the difference). even then, I still need to dress mine in the TZR around the same spots.
Never would have thought of that but makes sense when you look at piston clearances on old school air cooled motors and compare them to w/c ones.
Just stole this from vintage mx site,
for an iron bore (not nikasil) .0025-.0035" clearance is good, .005" too much. Nikasil bores are .0015-.002" for motocross bikes. Measure the bore with a bore gauge top and bottom, front to back and side to side, 4 measurements to make sure the bore is within .0002-.0004" round. Measure the piston with a mic (not a caliper) at the widest point of the skirt.
Pistons are machined with a taper in the skirt so the diameter at the crown is smaller than the diameter of the bottom of the skirt. This is because when engine is hot the crown of the piston is hotter than the bottom of the skirt so it expands more and the piston becomes more cylindrical as heat removes the piston's taper. That makes it critical that you measure the piston in the correct location.
There are currently 58 users browsing this thread. (1 members and 57 guests)
