Page 668 of 2773 FirstFirst ... 16856861865866666766866967067871876811681668 ... LastLast
Results 10,006 to 10,020 of 41590
  1. #10006
    Hi Haufen, I can't see in the picture where you mean, but will have a very good look at the cylinder when I get back to the workshop.
    No problem, I marked the area for you. The picture might be deceiving, but the area above the inlet port could be kind of a weak spot on side rotary engines.
Name:	Tok R2 Beast 009.jpg
  2. #10007
    Devcon lip
  3. #10008
    Devcon lip
    Very close.
    Well spotted, it is a crack, well sort of, some devcon that I used to fill an earlier stuff up is starting to pull away.
    Thanks for spotting it.
  4. #10009
    Hus - it's all very well to pull out these old articles about equating 2 vs 4 strokes, but....you really should pull up the period responses as well.
    At the time their findings were not accepted either by the FIM or by the factories. Some very clued up engineers went into print decrying their findings. Since then both types of motor have moved on and if anyone looked at it now it would have to be using a totally different set of criteria.
    At present I see no need to change anything but if you wish it to be discussed, go through a club and by all means try a remit....
    I've watched a lot of formula changes in various branches of motorsport and it's rare here that capacity is reduced in any class...but if I had to suggest a change just possibly the 85cc watercooled MXer's run with a spec carb and pipe could be worth a look.
    Whatever is done it should not obsolete existing machinery..
    BTW - met Hans VD Marwitz when he came out to oversee the Britten record attempts - nice guy. Dead now....
  5. #10010
    Did you read it...... it was accepted by the FIM then because of Suzuki and Kawasakis threatening to pull out it was then and only then taken out.......... the maths is hard to argue with..... esp if one of the guys is dead now............
    Simple fact the FIM comissioned them to do it they did it they a few cry babies threw there toys out of the cot the formula is pretty much spot on unless you have a better one.
    buckets started as F4 104cc 2 strokes 130.5cc fours strokes
    then it was 140cc four strokes
    then 145cc fours strokes
    then 150cc four strokes
    now 158cc four strokes
    Now you says the rules shouldn't be altered for a few cc to suit an oversize piston please Greg it less cc then the first change made to suit the four strokes.
    i are quite happy to post the period rhetoric but i don't have any...........do you............????????????????? email i will post em.........
    not interested in MX motors so please stop clouding the argument with them. its a totally separate issue all together
Name:	FIM formula.JPG
  6. #10011
    30th November 2005 - 18:27
    I'm finding the 80cc debate interesting.......it would have been good to see Sketchy's project get off the ground as a benchmark. I probally wasnt the only one to have a look at Tardme.......$500-750 for a shitter MX bike, $300-400 for a motor freshen, sell the roller for parts. That makes a competitive motor for $1kish so bang for bucks it got to be a way to allow the class to grow and you dont have to be a 2t guru to make it happen. I'd look at doing it for my boy to start racing on as a step up from the RS50. Hell some 17's in the MX frame and it could be a weapon for Kart Tracks.
  7. #10012
    ... not interested in MX motors ...
    Me neither
    I feel that in F4 & F5 if anyone wants hp, they should make it the old school way otherwise there are plenty of std FXR's.
  8. #10013
    4th November 2003 - 13:00
    BSA A10
    I didn't think they were ever offically 145cc although people were running the GL145
  9. #10014
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Me neither
    As opposed to 80cc derbi motors?
    I still feel that 80cc mx motors would make a big appearance and if ruling governed them to a "stock" 20hp level that is what I would be running while the 40HP supercharger bike is finsihed
  10. #10015
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
    you will need 40 hp to help learn you how to get of the mark(-; lol
  11. #10016
    Personally I don't see a problem with the basic idea of running an mx80. Standard they only make 20ish hp. Once freshened up they should be reasonably economical to run. Possibly even the 85s as well. The way they make power would be the interesting thing rather than how much power they make. Could be a reliable fastish option for the people who aren't fond of the dark side. Possibly keep them stock apart from the pipe. They'd probably fit nicely into a RS chassis as well. Cost to purchase and rebuild in comparison to stuff we run now would be interesting.
  12. #10017
    Pukerua Bay
    Don't have to get off the mark with 40hp, I'll still drag race everyone to the line haha.
    Yeah my idea is that they reliable,and parts are easily obtainable. If power levels are governed to 20hp its not going to make anyones hot rod motor that they have worked hard to build redundant, I feel it will just add more riders to the battle at the front, because with the people out there now, unless you have 20hp you may as well go home if you want to try win.
    For what it is worth, a piston kit is $99 and will be at your door the next day (www.motocrossparts.co.nz)
  13. #10018
    ... mx80. Standard they only make 20ish hp.
    Took me 3-4 years to start making 20ish hp.
    80cc derbi motors?
    And what flaver of source do you want me to swallow with that dead rat sir.
  14. #10019
    Stock CRF150R motors are about 20. You would have to let them in to.
  15. #10020
    Pukerua Bay
    I don't quite understand this comment but please know I wasn't meaning to be rude before, just a little tongue in cheek.
    Go away Rich, no one wants your 4 stroke rubbish...
