Page 694 of 2776 FirstFirst ... 19459464468469269369469569670474479411941694 ... LastLast
Results 10,396 to 10,410 of 41626
  1. #10396
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Hey guys,
    I noticed earlier you have knock sensors hooked up to you bikes, I was wondering if they are also suitable for 4T engines and where I may source one?
    Cheers,
    -Glen
  2. #10397
    Its a bit of a pick and mix so I highlighted the dollar amounts so you can see where the prices come from.
    $63.50 NZD for a counter from RS components
    http://www.ebay.com/itm/Knock-gauge-...b8220d&vxp=mtr
    Knock Gauge $49.99 plus option 1 switch to ground for the IgniTec ignition retard add $20 plus option 3 pulsed 0v to 5V for the counter so add another $20
    $90 USD for the Knock Gauge part off Ebay.
    Less than $200 NZD should cover it.
    Attachment 263051Attachment 263052
    Good luck with the Deto sensing TZ. I like the little warning instrument!
    My sensor has a PN 0-261-231-001, what's yours?
    According to this http://www.phormula.co.uk/KnockCalculator.aspx , deto freq for 56mm bore should be 10.2kHz.
    According to Bosch datasheets for PN -047 & -120, sensors are able to catch frequencies from 1 to 20 kHz.
    I assume all Bosch sensors can sense knock within this range (?)
    edit: As for the pick-up voltage, I think it won't be more than +-10V. I had a voltage test yesterday with a data acquisition device in real time! I spinned the crank by hand and recorder the voltage waveform from the pick-up in the PC. As RPM increase, amplitude (and freq of course) of the pulses increase - by hand-spinning it didn't exceed 3~3.5 VAC. Sure it was a lot of fun to watch!
    Its funny you say that. I have presactly the same Subi deto doofer & knockgauge. I connected it yesterday & went to the dyno. Rang up like a tree. I ended up ignoring it & feeding in smaller jets & advanced timing increased the power so I can't believe it was setup right.
    My sensor is on the side of the cylinder. I wonder it it is just getting too much vibration? Not that it vibrates that bad. . . I turned the dial to try calibrate it & didn't get much change. maybe it is in a sensitive plane to operate the piezo.
    I have just been putting on my knock gauge on the bucket and when I run her in the drive with the sensitivity set half way, reving the bucket up the gauge went off like a christmas tree and I am wondering what others have there gauges set to?
    The gauge is from http://www.knockgauge.eu and the sensor is off a subaru car. It's mounted on a 100cc LC two stroke on a head stud straight onto the head with nothing inbetween if that is any help.
    Attachment 263028
    Ok mine turned up today.
    Attachment 263027
    And a couple of two wire sensors I picked up cheap from the local garage.
    Forget the homemade bullshit, get one of these with the extra wire to ground.
    When it sees deto it can ground an Ignitech input and retard the timing automatically.
    You get flashing lights and engine protection all in one shot, and cheap as chips - made in Czech so it likes being connected to an Ignitech - same lingo..
    Works perfectly - when you get it trimmed correctly it will tell you where to manually pull out timing, then it just operates as a failsafe.
    http://www.ebay.com/itm/Knock-gauge-...ht_1582wt_1297
  3. #10398
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
    Our sidecar was 10kg heavier than the Griffiths chair, swingers about the same, riders we made our 10kg back with interest
    so your saying l'm a fatty
  4. #10399
    4th February 2005 - 07:32
    Rattlecan blue
    In a word, yes. Don't you weigh more than your rig?
    Stock is best
  5. #10400
    31st July 2005 - 11:15
    a shed full of crazy shit
    That might be tooo close call
    it could be the next poll (though it could be a close call between a few members of team GPR)
  6. #10401
    Rattlecan blue
    Bert, I'll give you a clue, there is 2 kg in it, you decide which way.
    Stock is best
  7. #10402
    I weigh as much as the Beast, do I get a chocolate fish?? ....
  8. #10403
    ... it could be the next poll ...
    If you are going to run a new poll, I suggest you don't do it on your own thread as polls are real hard to get rid off, I needed the Mod's help to clean up the ESE thread after the Sidecar/Beast poll.
    Next time a poll sounds like a good idea I am going to start a new thread just for it and when its run its course, I will let it float off into the distance and post the results here.
  9. #10404
    Attachment 263028
    Attachment 263027
    Knock Gauge.... $49.99 USD plus $20 for option 1 "As switch to ground;"
    I found some steel head bolts and faced one off, then drilled and tapped it. And made a standoff that was carefully faced off as the knock sensor likes to be securely mounted on a very flat surface. The black goop (silicon glue) on the blue wire is there as a strain relief and hopefully it will stop the vibration breaking the wire where it is attached to the copper head fin.
    Attachment 269009
    703TR002N-512D RS part number 183-5952 $63.50 ... 5-12V and less than 10mA so easily self powered and at 500Hz fast enough to count all deto events as seen by the Knock Gauge or similar, as 200Hz in a 2-Stroke equals 12,000 rpm.
    Attachment 269008
    Knock Gauge and Det Counter ..... $49.99 USD plus $20 plus $20 for option 1 "As switch to ground;" and option 3 "As 0v + 5v output;" frequency output for the Det counter to count.
    Attachment 270747
    I have just received another Knock Gauge, this one has two extra outputs. http://www.knockgauge.eu/content/blogcategory/22/41/
    YouTube links showing the Knock Gauge in action.
    The two green lights, the orange warning light then you see the red det light. http://youtu.be/aZkZR-JBr_E and http://youtu.be/vFoZyw_sHmA
    Like last time, one that goes to ground for signaling the IgniTec to retard and a new one that pulses from 0V to +5V each time the Knock Gauge sees a detonation event.
    The Curtis event counter can then count the detonations. Now I have the makings of a det sensor, ignition retarder and det counter.
    I have yet to try the Knock Gauge come Det Counter, but it looks promising.
  10. #10405
  11. #10406
    Pukerua Bay
    Thanks for the info guys, sorry I was too lazy to search for it, busy making superchargers an all
    Once I get the supercharger performing I will invest in one of these as I'm sure you can imagine boost will encourage det.
    Actually, a question for who may be in the know - Fuel, would AV gas be better fuel to run in an forced induction motor? Detonation is going to be the killer of my little chinese motor so I would have thought that Av gas will help this?
    Cheers,
    Sketchy
  12. #10407
    I must imagine Av would be the safest when lots of boost is required. You can have a guernsey at my knock gauge. I have to get it reattached when the bike is watercooled, perhaps you can try it out till then.
  13. #10408
    Totally Legal Good Part.
    TeeZee no need to make one, here is a rear pulley sheave with curved slots like you were talking about.
    NCY describes some of their parts as "Race".
    But there are none of the naughty race words on the manufacturers web page for this sheave, or the sheave itself that would make it an illegal race part.
    In spite of what the re sellers might love to call it, it looks like it was manufactured by NCY to be just a better part for a gy6 street bike/scooter.
Name:	NCY 千葉興業有限公司.jpg
    http://www.ncy-motor.com.tw/product3...page=1&pid=449
    A Totally Legal Good Part.
  14. #10409
    Now if you could find a sheave with axial slots, that would be someting....
  15. #10410
    5th June 2008 - 17:46
    Hey TZ,
    What do you reckon the beast is capable of in a straight line? Maybe F5 Dave would stand a chance on his 50.
    http://www.flyingmile.co.nz/
    Held on Goudies road between Taupo and Rotorua.
    It does mention invite only, but then goes on to list the cost of entering, so don't know what your actually chances would be of entering.
    I believe the current record stands at;
    50cc
    17/3/84
    P.D. Sales (Im guessing that is Pete sales)
    80.212 MPH
    Suzuki
    Waihopai Vally, Blenheim.
    125cc
    16/9/95
    RH Bleach
    119.06 MPH
    Honda
