Page 70 of 2774 FirstFirst ... 20606869707172801201705701070 ... LastLast
Results 1,036 to 1,050 of 41607
  1. #1036
    24th September 2006 - 02:00
    Lol -- here I am scratching my head trying to work out what will happen when I add a 350 piston onto a 250 single (with balancer shafts, no less) -- and I'm the guy who uploaded Tuning for Speed to Scribd in the first place
    Came out before balancer shafts though... but still useful theory.
  2. #1037
    Thanks for doing that xwhatsit.
  3. #1038
    14th June 2009 - 15:13
    suzuki
    europe
    Squish Velocity
    Here is an online Squish Velocity Programme. There is also a few other useful programmes.
    http://www.torqsoft.net/squish-velocity.html
    http://www.torqsoft.net/piston-position.html
  4. #1039
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Good Stuff, thanks SonicV, had a play with them, very usefull.
  5. #1040
    Links.
    Terminolagy:- http://www.2-stroke-porting.com/terminology.htm
    MSV Mean Squish Velocity Calculator:- http://myweb.tiscali.co.uk/teamsparr...rheadsv2_3.xls
    Simulation video clips of 2-stroke scavenging:-
    http://video.google.com/videosearch?...um=4&ct=title#
    A catalog search engine, pistons, rod kits etc.
    http://www.who-sells-it.com/r/mahle-...-2-stroke.html
    Using only one ring:- http://www.vintagesleds.com/library/...ing_effect.pdf
    The effects of higher compression ratios in a 2-stroke:-
    http://www.vintagesleds.com/library/...ompression.pdf
    From, Yow Ling. www.zeeltronic.com has fully programmable cdi's about 100 euros.
    Stan Stevens RGV Tuning:- http://www.stanstephens.com/rgv.htm.
    A MacDizzy Blaster Engine Rebuild with Photos:- http://www.macdizzy.com/1989hhopup.htm
    MacDizzy's:- http://www.macdizzy.com/
    Modifying a Suzuki open chamber to a squish head:- http://www.ozebook.com/compendium/t5...organ/head.htm
    Dispelling 2-stroke tuning myths:- www.fatbaq.com/RS125_dispellingmyths.doc
    Gordon Jennings:- http://www.vintagesleds.com/library/...20Handbook.pdf
    An assortment of Gennings Articles:- http://www.edj.net/2stroke/jennings
    Graham Bell:- http://www.kreidler.nl/artikelen/per...raham-bell.pdf
    Yamaha SAE Paper on Porting:- http://www.2stroke-tuning.nl/media/pdfjes/porting.pdf
    Gold Mine 1:- http://www.2stroke-tuning.nl/media/
    Anyone can open a free account with Scribed where they can download "Tuning for Speed" by Phill Irving.
    http://www.scribd.com/doc/15392252/T...rcycle-Engines
    Phill Irving talks about CrankShaft Balancing and Balance Factors on pages 107 to 110 of the book which can be found on page 61 of the PDF.
    Rate of Fuel Burn:- http://www.factorypro.com/tech_tunin..._vs_power.html
    Reading Plugs:- http://www.dragstuff.com/techarticle...ark-plugs.html
    Engine formulas:- http://members.bellatlantic.net/~vze...es/engine1.htm
    A Handy Coverter:- http://www.mr2ownersclub.com/converter.htm
    Detonation:- http://www.factorypipe.com/t_deto.php
    Dale Alexander. The Art Of Squishing Things Until They Make Power:-
    http://www.aircooled-rd.com/default....ge=squish1.htm
    http://www.aircooled-rd.com/default....ge=squish2.htm
    http://www.aircooled-rd.com/default....ge=squish3.htm
    A preview of Kevin Camerons book “Sportbike Performance Handbook”:-
    http://books.google.co.nz/books?id=L...esult#PPA81,M1
    TUNING VESPA'S THE NORRIE KERR WAY.....
    http://www.scooterhelp.com/serial/tuning.books.html
    Crankcase delivery ratios and inlet timing for rotary disk motors:-
    http://www.edj.net/2stroke/jennings/delivery_ratio.pdf
    The effects of crankcase volume on the delivery ratio:-
    http://www.edj.net/2stroke/jennings/...ase_volume.pdf
    Piston pin offset and what it means for extra power:-
    http://www.motorcycleproject.com/mot...ws-offset.html
    4-Stroke stuff but very interesting about porting and combustion.
    http://www.gofastnews.com/board/technical-articles/
    Supercharged Honda 50 http://www.elsberg-tuning.dk/the%20bikes.html
    Drop your engine in liquid nitrogen:- http://www.iwt.com.au/cryogenics.htm includes dyno charts to prove the theory. Thanks Yow Ling.
    The Big Tuning Manual from Piper Cams:- http://www.bgideas.demon.co.uk/tmanual/ it talks about combustion chamber shape and swirl patterns, and are PDF's that can be down loaded.
  6. #1041
    SonicV would you mind if I add you'er links to my list?
  7. #1042
    I had a bit of a quick squizzy at The effects of crankcase volume on the delivery ratio:-
    & must admit I'd never heard of the test engines. Then noticed they spin out to the dizzy heights of 4500rpm at best. One can imagine that the pressures involved are not proportional compared to time areas due to gas flow at up to 3x the revs.
    ok here's one to send people down the garden path with a nice but difficult idea
    http://www.muller.net/mullermachine/docs/slippy1.html
    Borut makes Zeeltronics stuff for mainly RGV, NSR etc but could be possible to adapt to a bucket but you'd have to talk to him, you need 3 boxes to get programmable & will cost a site more than 100 euro. (I have a setup on my 500).
  8. #1043
    IBorut makes Zeeltronics stuff for mainly RGV, NSR etc but could be possible to adapt to a bucket but you'd have to talk to him, you need 3 boxes to get programmable & will cost a site more than 100 euro. (I have a setup on my 500).
    I have a Zeeltronics ignition controller on my lc, it works with the stock cdi because there is no curve in the lcs cdi. Rzs need a zeeltronics cdi to replace the yamaha one to get rid of the stock curve. i think thr controller was 100 euro and the programmer 50euros. the third box is the powervalve box ?
    he also has a 12v cdi so you dont need exciter windings on your stator and want to run total loss
  9. #1044
    20th November 2002 - 11:00
    Wellington, New Zealand,
    Wow, I knew if I waited long enough some more info I can use would be forthcoming (rather than questions), but I never expected that bonanza!
  10. #1045
    suzuki
    europe
    SonicV would you mind if I add you links to my list?
    Fire ahead
  11. #1046
    Yeah but it means you have to have a battery at the least. If your cdi was straight curve then you don't need the 3rd (CDI) box (4th is powervalve if you call then programmer a box).
  12. #1047
    There is a bit of a spat going on, on the two stroke tuners thread over this question and no one will chance their arm.
    Which is heavier, (A) the reciprocating weight of the rod piston assembly or (B) the counter weight of the crankshaft.
    This is a test (A) or (B).
    The answer is (A) as the counter weight only counters a % of the reciprocating weight and is lighter than the reciprocating portion of the rod/piston assembly.
  13. #1048
    There has been a bit of talk about Crank Shaft Balance Factors on the Two Stroke Tuners thread, resulting in more heat than light. As there is a bit of a rowdy crowd over there I am going to make my posts here.
    I intend to keep it simple, so for what its worth, this is our interpritation of Phill Irvings work.
    "xwhatsit" is the guy who uploaded Tuning for Speed to Scribd in the first place, thanks xwhatsit.
    I will use a 2-Stroke single cylinder TF100 crank to demonstrate my explanations and I need to break it down into sections as I can't cover it all in one or two posts. Thomas gave me a hand, taking the photos and gave me a few tips along the way.
    My plan is to:-
    (1) Post photos of all the cranks I have lying around and quickly describe the features I can see on them.
    (2) Describe how to find the reciprocating weight.
    (3) What the "Balance Factor" really is.
    (4) I will answer this question, Which is heavier, (A) the reciprocating weight of the rod piston assembly or (B) the counter weight of the crankshaft.
    (5) Why there is a "Balance Factor" and what changing it does.
    (6) What to do with your "Balance Factor"
    (7) A simple but very effective jig for staticaly balancing a crank, that you can make yourself in 10min's. (Thanks Thomas)
    (8) What a rocking couple is, and how the term is used in crank shaft balancing.
    (9) Just for Skunk, Some of the problems associated with balancing a V2 90 degree twin with one horizontal cylinder.
    This is going to be a very simple "KISS" look at single cylinder crankshaft balancing, based on Phill Irvings book. If anyone thinks I've missed something or wants a more in-depth treatment they are welcome to explore the internet for what they can find. Or dust of data from their own experiments and post it themselves. Then we can all enjoy reading their interpretation of what they have learnt.
  14. #1049
    Thank you - I need edjacukating, and the two stroke tuning thread has really lost it in egos. Thank you Rob for taking the time to post information.
    (9) Just for Skunk, Some of the problems associated with balancing a V2 90 degree twin with one horozontal cylinder.
    I'm doing a 90° firing RD400 though...
  15. #1050
    17th November 2002 - 11:00
    dam.. i move too much
    this is a thread i am interested in!!...
    what a ride so far!!!!
