Page 71 of 2776 FirstFirst ... 21616970717273811211715711071 ... LastLast
Results 1,051 to 1,065 of 41630
  1. #1051
    These Posts started, Page 70, 17th June.
    (1) Post photos of all the cranks I have lying around and quickly discribe the features I can see on them.
    Pic-1 Yamaha RD400 with lead balance weight.
    Pic-2 Yamaha RD400 without lead balance weight.
    Pic-3 Suzuki T500 with asymmetrical balance holes which means the counterweight is not directly opposite the big-end.
    Pic-4 Yamaha RX125 with hollows forged/cast into the flywheels.
    Pic-5 Suzuki RG50 which clearly shows the counterweight portion of the flywheel.
    When the flywheel is drilled the counterweight part is not as obvious as in the RG50 (pic-5) you just have to imagine its there.
Name:	Crank 1-RD400.jpg
ID:	132279   Click image for larger version.
Name:	Crank 2-RD400.jpg
ID:	132280   Click image for larger version.
Name:	Crank Suzuki T500.jpg
ID:	132281   Click image for larger version.
Name:	Crank Yamaha RX125.jpg
ID:	132282   Click image for larger version.
  2. #1052
    Pic-1 Suzuki GP125, hard to see but the front hole is a little smaller than the rear one.
    Pic-2 80's Suzuki RM125
    Pic-3 90's Suzuki RM125
    Pic-4 Yamaha KT100 Kart
    Pic-5 92 (I think) Honda RS125
    Pic-6 Honda MB100 and is what I think the RS crank would look like with the tin covers off.
Name:	Crank 1-GP125.jpg
ID:	132289   Click image for larger version.
Name:	Crank 80's RM125.jpg
ID:	132290   Click image for larger version.
Name:	Crank 90's RM125.jpg
ID:	132291   Click image for larger version.
Name:	Crank KT100.jpg
ID:	132292   Click image for larger version.
Name:	Crank 92 RS125.jpg
ID:	132293   Click image for larger version.
Name:	Crank Honda MB100.jpg
  3. #1053
    how on earth are you typing all this? One handed? My posts got very brief for a month.
    In Skunk's case he doesn't want a Vtwin with a horizontal cylinder, but a parrallel twin 270 deg TRX style.
  4. #1054
    Just had a PM from Skunk, Interesting project.
    I am lucky, my right hand is OK, and I have all day.
  5. #1055
    17th November 2002 - 11:00
    dam.. i move too much
    and AJ just wants the RG50 to go a little bit faster.... but stay reliable
    and for the GT to friggin FIRE
    what a ride so far!!!!
  6. #1056
    Lose weight. Turn throttle to open position, keep there, don't back off unless you really need to & even then count to 4 before doing so & only for a second
    Set alight.
  7. #1057
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Set alight.
    Haha good advice Dave..
    Your up late, baby keeping you up?
  8. #1058
    14th June 2009 - 15:13
    suzuki
    europe
    Reducing Reciprocating Mass
    One of the first port of calls should be to reduce reciprocating mass. If there are limited piston kit options for a particular engine and the gudgeon pin is of the parallel wall type, I like to obtain a tapered wall gudgeon pin from a different engine. In the worst case scenario you may have to shorten the pin slightly.
    It is surprising how much mass can be saved with a tapered pin. I have found suzuki motocross engines to be a good source of gudgeon pins.
  9. #1059
    Set alight.
    the 4 second rule.... that's where i have been going wrong.... all these years i thought it was 2 seconds...
  10. #1060
    29th September 2003 - 20:48
    2008 DRZ400E & 1983 CB152T
    Alexandra
    Yeah but then you end up with a broken wing, not very good advice dave
  11. #1061
    ALSO.. i have NEVER heard HIM count!!!
  12. #1062
    Personaly, I close my eyes.
  13. #1063
    These Posts started on Page 70, 17th June.
    TF100 crank on the left 80's RM125 on the right. I've heard that the TF cranks vibrate real bad when rev'ed and that Speedpro fixed his by plugging the big hole with aluminum.
    I have noticed that the TF is a-symmetrical and the motocross cranks are symmetrical (even sizes). The small hole on the TF crank could be opened up to, more like the RM and then plugged if you wanted to go to the extra work.
Name:	Crank TF100.jpg
ID:	132315   Click image for larger version.
Name:	Crank RM Balance.jpg
  14. #1064
    Interesting advice with the tapered pin. But also grey area from the rules. Pistons are free. So are the gungeon pins? hmm.
  15. #1065
    Yeah a bit, but mainly self inflicted.
