You can almost see the shiny mark to follow on the barrel.
Before I found this pic I was imagining you may have been moving the rear of the C transfer back further still which I thought was ambitious but interested to see if it was a target (not that I want to develop my 496 any, its hard enough to get it roadworthy with the time I have anyway). PS the bypass thermo & rad modifications seem to have done the trick lowering operating temp on a decent roadride.
Yeah that's the guy. I haven't seen him in a long time but in the past you could find him by responding to one of his threads there, I guess he has auto notifications and can't help himself but reply to anything and everything.
I've put the PFI on the backburner again, built new pipes and did some porting getting my old RZ ready for this season, working on a stroked YPVS motor in a TZR chassis, building a dyno and just picked up a loaner Ape RS125 to get ready to race this season too. Busy.
I was there as well till they banned me for exposing him lol Iluvtwostroke was my name
He doesnt do them anymore anyway he found it to hard and decided that it as no good. after telling every one how good it was and if you disagreed you were just misinformed. He mainly sticks to the aprillia forum now where is a moderator and he simply bans you if you disagree
I am banned
Something from the modeling world that might be of interest, even though it's a bit dated.
Sources:
http://www.go-cl.se/castor.html
http://modelenginenews.org/faq/index.html#qa5
A bit redundant, but some additional pieces here:Originally Posted by http://www.go-cl.se/castor.html
Originally Posted by http://modelenginenews.org/faq/index.html#qa5
Makes me feel a little better about this weekend's experiment to drown my engine in R30 in an attempt to get some decent ring seal that has bean eluding me. (excuse the pun)
Done a heap of dyno work on this for KT100, where 1/10ths of Hp are valuable.
Short story is the testing proved what was being said above.
The modern full synthetic race oils were designed for unleaded as used in FIM since 1998.
Best example is Elf 976.
Unleaded makes best power with no com, high advance and running rich - perfect for the synthetic.
Avgas or leaded race gas is dead opposite, the hotter the better.
In the tests the synthetic made alot less power when run lean ( as the KTs do to make them rev past 16,000 )
and made no more power at 16:1 than 30:1
Semi synthetic works best in the situations where high temps are seen
Maxima 927 Elf 909 Motul Kart etc all made more power the more oil added.
The oldest and the one that made marginally the best power was partial bean oil Castrol A747.
Other people would have a better handle on this but i seem to remember sealing issues with the Britten i think they in the end had to do a complete change the liner material so the sponsor’s oil (Mobil 1) would work. I seem to remember it wasn't an issue with the same materials and the non-sponsors oil.
People often moan about castor gumming stuff up but i have never found it an issue, IMO if you are getting gumming you really need to take a good look at your maintenance intervals.
PVs are a game changer for clean running, but not on most buckets.
I've run Motul 800 for years & had good results in the 50.
I used to run Golden Spectro in the H100 & although it reved less the wear was astronomically minimal. But since I decided the MB100 would rev further I would run same 30:1 800 for both 50 & 100 (in Av). Introduce the KT parts into the MB engine & I get ring seal/bore polish issues.
Either my bore is unstable & can't hold still despite a few attempts reboring/honing. Or it just isn't running-in that combination of materials & 800.
I've bought a ring leak tester so hopefully with a couple of careful load variation practise sessions & a days racing on R30 15:1 (& unleaded so it will mix) I'll see an improvement & can switch back to Av & 800 (after using the R30 up to be sure).
Dumb question time but why are trying to run your motor in on synthetics and/or castor? Surely mineral oil should be used for bedding in the rings?
A question for the experts -
I was planing on running my new motor in on the dyno. I figure a couple of minutes at moderately high revs then a single flat out run then dump the fuel and mineral oil mix and switch to kart oil (synthetic castor mix). I realise this is a fairly agressive approach but is it an acceptable way of running in a race motor?
That used to be a good idea on the old synthetics.
But bean oil and the new semi synthetics have no trouble bedding rings etc during a short run in period.
But its just as much a matter of getting heat cycles into the piston, as it is about surface bedding, so 10 minutes of hard accelerations,up and down the gears,without hard reving is the go.
In my testing Elf 909 was the best all round, it looked like a run in on castor, with NO scratching of the new piston, and made good power - almost the same as A747
no matter how lean you were.
Motul 800 was crap when up at 650* EGT, so was the trick shit Elf 976.
As the big shpeal about castor was basically saying - pure synthetic "oils " are shit at lubricating anything when the combustion temps are thru the roof ie 650*C in the header.
This is the perfectly normal situation on pump gas with the air cooled KT100, and perfectly normal when running AvGas in a properly tuned race engine of any sort.
In my KT100 dyno tests I had resolution down at 1/10s of a Hp, with a rigorous test procedure that had every run with EXACTLY the same case and head temp at the
beginning of each run, ( probes on the case and under the plug - logged continuously ) combined with EXACTLY the same egt in the pipe at run end.
The pure synthetics made a HEAP less power when running lean at 650* C , the worst dropping 1.5 Hp in 18.
Adding more oil made NO difference - still shit.
You MAY not seize the thing, but for sure you are making nowhere near the power potential of the engine when run that way.
The bean oil derivatives were completely the opposite, run hot and no loss of power, run more oil = more power, every time.
Understand THAT.
Like I said - pure synthetics are fine when run with unleaded at conservative combustion temps - abuse them and everything turns to shit - real fast.
Thanks Wobbly. Just so happens we are using Elf 909 (something to do with "Wob says its the trick shit"). I've been told 30:1 is a good ratio in the water cooled 50's, would I increase the oil ratio for an air cooled motor on avgas? I understand more oil = more hp as per your post above but I was hoping theres an acceptable ratio that wont empty the wallet too quickly.
Thanks Wob that sorts out the oil. Now about the fuel
seeing as unleaded runs with a particular set of conditions and Avgas runs runs with different conditions, is there a blend of avgas and unleaded that provides the best of both worlds like a faster burning fuel that is not prone to detonation. Are there any gains to be made here in either helping with engine durability or additional power from extra com etc. People have been doing this since time began , is there any scientifically backed or dyno proven testing on this?
thanks
There are currently 111 users browsing this thread. (0 members and 111 guests)
