Should probably put some oil in Rob's gearbox then going by the noises it was making when Av came into the pits.
Bit of that going around, my 50s clutch bearing was looking pretty dry, sadly I'd drained the oil into a large sump container so not sure how much came out (it was pouring out then I walked away). Time for crank seal leak test.
sorry i couldn't resist
Welcome aboard Nigel tell us about the bike, RG125 sleeved to 100?
My brain is not big enough for this, but there are people here who have brain mass to spare
Borrowed from another place in the ether
"I found some very excellent software at Autodesk. It is a beta test of Computational Fluid Dynamics (CFD) software. It is a wind tunnel simulation. This is a stand alone program so you don't need anything else. Very unfortunately the beta test runs out on March 15 next month. Fortunately there are still almost three weeks to play with it. This is very easy to use software with no math required at all. You may insert models in 2D as simple JPEG or PNG shapes or as full 3D models from just about any software. I use Sketchup and export the 3D model as an STL file. There is a free plugin for that. It works perfectly.
The program is Falcon and is available here: http://labs.autodesk.com/utilities/falcon"
Here is a link to the source http://bbs.homeshopmachinist.net/thr...tion-using-CFD
Should be good for keeping you up at night
RG150 with a RG250 barrel to get it down to 56mm then a steel sleeve to get down to 50mm
currently 98cc
motor is six years old now
numbers by Wob ( port timing, head shape, pipe dimensions)
assembly by me (when its broken, or Wob when its taking lap records apparently)
have had i bit of bother with nippin up on tracks where you spend a long time wide open, But I (if it fails, or Wob if it doesent) reckon its cured now
been on dynos anywhere between 23 and 28.3 hp, power from 8500 to 1200, nice flat easy to use neddies.
mid eighties RS125 chassis with standard rear end and undermaintained front end
Nomates
The headsmack come from me knowing this BEFORE I WENT OUT!
I had checked the plug, looked a bit hot, asked Dave for his experienced opinion and he said go richer.
I knew it, I dismissed it thinking; ahhh it's not that far off and BOOM!
I've always bee conservative in jetting and timing but was starting to push things further as I thought I was too prudish.
Lesson learned!
@ Koba - what plug were you using ?
Thanks for your detailed explanation!
Well of course the '75% rule' depends on the shape of the exhaust port...it is obvious, it could be too much or too little but I think that the ideal size could be determined only by testing.
As I didn't have my own observations I have shaped the blowdown according to Blair's recommendation. It seems that it works, but I haven't tested it yet. If you have any experience or result please let me know, I'd be grateful!
Koba's piston brings back memories. Many suzuki TS and Honda MB pistons of mine have ended up looking like that.
There are currently 175 users browsing this thread. (0 members and 175 guests)
